Old 11-11-2021, 12:59 PM   #15
ripper
ripper's Avatar
Originally Posted by timurrrr View Post
I don't know how much time you have left, but "SPC 81305" bolts are $22 on Amazon with Prime.
You can get -1.7º...-2.0º with them, and they will surely pay for themselves by extending the life of the outside shoulders of those expensive A052s, even if you pay $100 on top of the $22 to an alignment shop (assuming you install yourself).
Speaking of the A052s, are you sure you need that much grip for your first track day in a long time?
Are you sure your fuel system and oiling system can handle those G's?
I don't know what is the limit of stock systems in good condition, but I've seen one track-proven engine spinning a rod bearing on its second high-grip tire track day.
Stock tires or 260 TW GT Radial SX2s are still plenty of fun on track if you're not looking for absolute minimal lap times. And you probably aren't looking for those on your first track day after a long break.
Camber bolts ordered. Thanks for that!
Do I need that much grip? More is better in my book, but you're right; I don't know if my stock oil and fuel system can handle the A052's grip. I'll be taking it easy for sure on this first time out and see how it goes.
Late note add if it makes any difference, I'm running my car on an e85 OFT tune. I'm bringing a few extra fuel cans with e85 as it's a bit rare between my house and the 180 trip to the track.
Thanks for inputs, keep them coming. Just three days left before I head out!
ripper is offline   Reply With Quote
The Following User Says Thank You to ripper For This Useful Post:
timurrrr (11-11-2021)
Old 11-11-2021, 01:15 PM   #16
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Just put stock wheels and tires back on and send it
You'll probably have more fun and will learn more about the car that babying those Yokohamas.
From what I understand, there's not much feedback the car gives on oil starvation until it's already too late.
The Following User Says Thank You to timurrrr For This Useful Post:
ripper (11-11-2021)
Old 11-11-2021, 01:15 PM   #17
ZDan
ZDan's Avatar
Drives: '23 BRZ
Also you could get offset top mounts for a bit more negative camber up front (you're gonna need it!):
https://www.ftspeed.com/part/580096-...E#.YY1PdGDMJPY
ripper (11-11-2021)
Old 11-11-2021, 01:17 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can generate enough lateral G's to oil starve on SX2's as well in certain situations. I have been watching my oil pressure hit single digits for the last 5 years in specific corners. Still ticking, UOA came back clean.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
ripper (11-11-2021), timurrrr (11-11-2021), villainous_frx (11-11-2021)
Old 11-11-2021, 01:22 PM   #19
ripper
ripper's Avatar
"Sticking" with the A052s lol.
Going with what I got for the limited time I have before I leave, but excellent suggestion for the next time...... OMG, next time. See what's happening?!?!
Old 11-13-2021, 07:06 PM   #20
jflogerzi
jflogerzi's Avatar
Your car looks pretty well setup. After this day your gonna be hooked. This car is so much fun to drive aggressively. Your gonna want at least -3 degrees up front for those tires. If your on stock suspension. IMO those tires are going to mask mistakes. Get some SX2's in 245/40/17's cheap and a great learning tire for next time.
2013 Series 10 FRS #553
Old 11-13-2021, 08:17 PM   #21
treedodger
treedodger's Avatar
Drives: 2022 GR86 (was 2013 BRZ)
Yeah, exactly, consider me here as a counterpoint to peeps who actively or passively suggest that you HAVE to have an oil cooler to track these cars...
Interesting.
What oil are you running?
How many trackdays on this car?
2022 GR86 / 2013 BRZ
86drivechallenge.com/
treedodger is offline   Reply With Quote
Old 11-13-2021, 08:31 PM   #22
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by treedodger View Post
Interesting.
Ran Total 5w30 for a while (that's what local shop carried), but this year started running Redline 5w30. 1st year tracking it I did run 0w20 a couple of events...
40 track days (~1 hour track time per day in ~15 minute stints) since 2018. Coming up on 60k miles on the clock.
treedodger (11-13-2021)
Old 11-13-2021, 09:14 PM   #23
treedodger
treedodger's Avatar
Yeah, I wouldn't recommend 0W20 w/out an oil cooler. 5W30 seems like a safer choice.
I got 46 trackdays and 115k miles on my 2013 before #3 rod bearing went. I ran an oil cooler and 5W30. But, it was an 2013 w/ the valve spring recall 15k miles prior, so who knows...
For the new engine I've switched to 5W40 and a homebrew Forester oil/water/air cooler. Check back w/ me in 5 years to see if this helps.
The Following User Says Thank You to treedodger For This Useful Post:
ZDan (11-17-2021)
Old 11-13-2021, 09:31 PM   #24
ripper
ripper's Avatar
@timurrrr, threw the camber bolts in today which netted about (-) 5mm in at the top of the rotor. Took the car out for a couple big 180 degree big sweeping onramp turns in both directions and it got a little hoppy in the front when I pushed it hard under load. We'll see how she does at the track as is.
Loading up and heading out tomorrow.
Old 11-13-2021, 11:44 PM   #25
jflogerzi
jflogerzi's Avatar
You really need or should get an alignment. Camber bolts can net about -1.5 degree's of camber
Old 11-14-2021, 03:54 AM   #26
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I got -1.8º from SPC, and I've seen more than -2º who did SPC and put the bottom OEM bolts in the top holes (iirc).
Old 11-17-2021, 12:06 PM   #27
ripper
ripper's Avatar
Track day went flawless. Car felt great and yeah, the tires were a bit overkill, but a great crutch to help me get back into it without putting her in the dirt. Thanks to everyone for the inputs, advice, and help. We'll see where this goes......
The Following 3 Users Say Thank You to ripper For This Useful Post:
timurrrr (11-17-2021), treedodger (11-21-2021), ZDan (11-17-2021)
Old 11-17-2021, 12:24 PM   #28
downshiftxlr8
downshiftxlr8's Avatar
Drives: 2020 86 Hakone
Excellent !!! That track looks like tons of fun.
downshiftxlr8 is offline   Reply With Quote
2017 BRZ 60k miles, 360whp turbo, track prepped and proven CSG Mike Cars for Sale/Trade 2 09-03-2020 11:14 PM
WTB - track prepped BRZ in New England area CHUD Cars for Sale/Trade 3 09-23-2015 11:01 PM
Track-prepped FRS for sale mav1178 Cars for Sale/Trade 27 09-12-2013 02:30 AM
FS: Feeler Track Prepped FR-S over 20k just in parts. track_warrior Cars for Sale/Trade 27 08-27-2013 02:48 AM
