Old 11-06-2021, 01:33 PM   #1
Missourifrs
Drives: 2013 FRS
AVO Turbo leaks and troubleshooting
I have an AVO turbo on my 2013 FRS. I bought the car turboed from an aftermarket company that used it to test new products. The car has 11k miles and I'm not sure how many are on the turbo kit. I have owned the car for about a month. I'm having smoke on startup and just over the last week began to have an oil leak on my driveway. There seems to be some oil on the turbo oil tank as well as on the exhaust coupler behind the turbo. I'm thinking this indicates a bad turbo but I'm not an excellent mechanic. Does anyone have experience with this kit that could help me troubleshoot?
Missourifrs is offline   Reply With Quote
Old 11-06-2021, 01:34 PM   #2
Missourifrs
Drives: 2013 FRS
https://imgur.com/a/eDfi72w
Old 11-07-2021, 10:14 PM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Either there is a leak in the oil feed or drain lines, or there is an internal leak in the turbo, so you are right that a bad turbo is likely, since it was burning smoke. You might be able to get it rebuilt if a bearing failed, but maybe not. Check for shaft play in the turbo. It doesn’t sound good. Better the turbo than a piston ring or something else that could cause smoke.
Old 11-08-2021, 12:34 AM   #4
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
A kinked of plugged oil drain line can also cause smoke.
The Following User Says Thank You to Kiske For This Useful Post:
Irace86.2.0 (11-08-2021)
Old 11-09-2021, 02:47 PM   #5
Missourifrs
Drives: 2013 FRS
It looks like whomever installed the turbo capped off the oil tank breather. sounds like this is causing my problems according to AVO. Ill attempt to vent the breather and see if it fixes my issue
Old 11-11-2021, 10:45 PM   #6
Grady
Grady's Avatar
Hard to tell everything from your pictures but yes the oil tank needs to be ambient pressure the same as the crankcase. AVO has an adapter that goes on the oil fill cap. I have one if needed. I redesigned the breather system on mine and can send you what I did if you want. It turns the catch can into an air oil separator. I have about 20K miles on it with no issues.
Old 12-03-2021, 02:17 PM   #7
Missourifrs
Drives: 2013 FRS
that would be incredible. I have been trying to get one from AVO but after a few emails they went radio silent. I have been asking how to make the purchase and nobody will respond. I am currently just venting into a bottle and its stopped it from smoking at least.
Old 01-14-2022, 10:19 AM   #8
Grady
Grady's Avatar
Sorry missed this post earlier. You get it worked out? If not PM me.
Troubleshooting a Leak with OFT Lakitu Software Tuning 27 06-22-2018 03:31 AM
Turbo issues troubleshooting SirSpectre Forced Induction 10 05-23-2018 01:08 AM
BRZ DRL Troubleshooting MaximaZero Issues | Warranty | Recalls / TSB 2 11-17-2015 04:31 AM
Troubleshooting with a KW c38 pgranberg11 Forced Induction 7 10-13-2015 08:05 AM
Need troubleshooting help. Camop82 Scion FR-S / Toyota 86 GT86 General Forum 6 10-14-2013 02:16 AM
