#15 | ||
It is nice to see other opinions though, but I have mineI was only concern about if it was the right cooler. And I think you are right, the small length must be negligible, even I will use a 13 row setrab instead of 16 Quote:
Interesting. In the end I was and I will be always worried about the oil at those temps...
#16 | |
Sent from my ONEPLUS A5010 using Tapatalk |
| The Following User Says Thank You to Ashikabi For This Useful Post: | J95 (11-09-2021) |
#17 |
TRACKBREAD
#18 |
Separate feature entirely. Closing the thermostat essentially means you don't have an oil cooler. So that doesn't improve the usefulness of a small core. It's better to have too much cooling and work backwards because you can't work forwards
#19 | |
Oil will always follow the path of least resistance, so even when you are at say 130F the door will partially closed and you’re oil will be like “oh shit, that door is starting to close, but that open outlet port is look appealing…I’m gonna go into both until the door fully closes” |
| The Following User Says Thank You to norcalpb For This Useful Post: | Ultramaroon (10-29-2021) |
#20 | |
TRACKBREAD
If your cooler is too big and it’s not on a thermostat you can fail to reach operating temp. That’s a problem too. |
| The Following User Says Thank You to Yoshoobaroo For This Useful Post: | Ultramaroon (10-29-2021) |
#21 | |
| The Following 2 Users Say Thank You to Ashikabi For This Useful Post: | Ultramaroon (10-29-2021), Yoshoobaroo (10-29-2021) |
#22 | |
Drives: '23 BRZ
Also don't most thermostat setups allow *some* oil to circulate through the cooler? Seems like a lot of peeps with coolers have run into issues getting oil up to temp in the winter, I think it's a legit concern that would be affected by how overkill you choose to go. All this begs the question, what max oil temperature is acceptable? For me, for my usage, with the oil I run, 275F is acceptable. So I already have the correct size oil cooler. And oil gets up to 190F after a short drive even just at low speeds in town. Yay! |
#23 | |
To my knowledge thermostatic plates flow approximately 10% when closed. I'm pretty confident that this small level of flow will not see significant temp difference between a large and a small cooler in the winter because both coolers will overcool that small volume. And it's only 10% of the total. I am for having a thermostat, but that's not what the discussion is about, and it's a separate part of the system Sent from my ONEPLUS A5010 using Tapatalk |
| The Following User Says Thank You to Ashikabi For This Useful Post: | Ultramaroon (10-30-2021) |
#24 | ||
Drives: '23 BRZ
Regarding "if it's not big enough, you're *screwed*", it begs the question, how cool do you think your oil needs to be kept? What max temp is acceptable for the oil you use and your usage? What are the real-world consequences if you exceed this assumed "max allowable oil temp" by, say, 5-10F? If you're doing "casual" track days and this happens after say 5-6 laps, I'd hardly say that means you're *screwed*. This kinda happened to me this year. I kept getting what I *thought* was fuel-starvation after a handful of laps but lo it was my custom tune I got this year when I installed a header, it was cutting power at 275F, which would limit me to ~5-6 laps. I didn't consider myself "screwed", though it was a bit of an inconvenience and source of confusion... Time trials are 3 laps so they were unaffected
| The Following User Says Thank You to ZDan For This Useful Post: | J95 (11-09-2021) |
#25 | |
You can't just tape cardboard to your cooler and get another 10 degrees of cooling. But you can reduce cooling. And if the climate is so cold that even with a thermostat your oil can't get to temp, then a small oil cooler isn't going to be any better than a large one. Covering your cooler completely regardless of size will be more effective at reducing cooling than a thermostat ever could be. And it's not uncommon at all in winter regions to block all or part of your grill in the winter. Your radiator affects oil temps too. Much more than an oil cooler will simply because of it's much larger size. An oil cooler is simply a supplementary radiator adding to the over all sum of the cars cooling capacity. Again, if you can't get your oil up to temp then you should be taking other steps to remedy that. Sent from my ONEPLUS A5010 using Tapatalk |
#26 | |||
Drives: '23 BRZ
Also worth noting that these failures have happened both *with* an oil cooler as well as without one... If a reliable supply of oil isn't making it to all the bearings, you're gonna have trouble, whether you're running 225F oil temps or 275F with appropriate viscosity and HTHS... Curious, what oil temps *were* you running with the Mishimoto cooler? And what oil? Regarding whether another 10 degrees of cooling would have "saved" your motor, it might have gotten you another session, maybe another track day or two, but I have to suspect you had oil delivery issues and it was just a matter of time... Did you rebuild existing motor and if so were any possible oil delivery issues addressed? Quote:
For my usage, particularly with tires chosen for time trials (i.e. need very quick 3 laps from cold, don't need 30 or even 15 minutes of grip), 275F doesn't bother me for a few laps at a time, running 5w30 with 3.7 cP HTHS @150C. I don't see a need to further discuss problems with oil coming up to temp in the winter, I have no experience there, I just know it has been an issue for some people with oil coolers (except for the Forester oil cooler/heater). I do like the fact that my oil gets to 190F very quickly as I daily through RI winters (which aren't *that* cold but still). |
#27 | |
Suggesting 200 degrees or ambient as a possible oil temp is simply being petty as there is no oil cooler you could run that would achieve a temperature close to that. I believe common sense would dictate that running a second radiator as an oil cooler was never being suggested. Sent from my ONEPLUS A5010 using Tapatalk |
#28 | |
![]() ![]() With this setup, at about standard ambient temp, NA engine running full bore, it will start riding the thermostat at about 3/4 capacity, and still not over-cool when wide open. I turn it down to a smidge under half and still get up to temp in a few minutes when dailying in PNW winters where it occasionally gets below freezing. My goal was to build an endurance setup. #achieved Now I just have to consider transmission and diff. But I'm probably wasting my time and money because you don't need an oil cooler.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | MrSkubi (11-02-2021) |
| Air to Oil Cooler or Radiator with Integrated Oil Cooler? | George Rosebush | Tracking / Autocross / HPDE / Drifting | 7 | 02-17-2020 03:49 PM |
| SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge | tws98 | Engine, Exhaust, Bolt-Ons | 0 | 05-28-2019 10:50 PM |
| AT Trans Cooler: Performance cooler vs Standard | Faulkner | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 04-30-2018 11:34 AM |
| WTB: Perrin Oil Cooler vs Jackson Racing Radiator/Oil Cooler | TheMedakaBox | Northern California | 4 | 08-09-2017 10:16 PM |
| Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 05:46 PM |
