10-07-2021, 05:06 AM | #351 |
Drives: BRZ, WRX
For those not on Instagram here is a sneak peek of the turbo exhaust manifold fabrication.
The Following 7 Users Say Thank You to DIY For This Useful Post: | Ash_89 (10-07-2021), Busybee (10-07-2021), Code Monkey (10-07-2021), flippy (10-29-2021), Irace86.2.0 (10-10-2021), Jdmjunkie (10-07-2021), RedReplicant (09-17-2022) |
10-07-2021, 04:46 PM | #352 |
Drives: 13 White MT FR-S
do you know if the EPS will run with just the power and signal wires like a prius EPS?
10-07-2021, 08:27 PM | #353 | |
Drives: BRZ, WRX
There is a guy selling a cheap kit on ebay that allows you to add a dial to adjust the amount of assist but I'm not confident it will work after talking to another guy on Instagram who is running his through his Motec ECU. Either way I will have a powerful enough ECU to control it.
The Following 2 Users Say Thank You to DIY For This Useful Post: | ML (10-09-2021), RedReplicant (09-17-2022) |
10-09-2021, 05:31 AM | #354 |
Drives: BRZ, WRX
More progress on the manifold, finished making the runners and tacked it all together for test fitting on the car.
It's been a challenge for sure but I'm very happy with the progress so far!
The Following 10 Users Say Thank You to DIY For This Useful Post: | ACT86 (10-09-2021), Ash_89 (10-09-2021), Busybee (10-15-2021), Code Monkey (10-09-2021), DustinS (10-14-2021), Dzmitry (10-20-2021), flippy (10-29-2021), Irace86.2.0 (10-10-2021), Jdmjunkie (10-09-2021), RToyo86 (10-29-2021) |
10-15-2021, 09:13 PM | #355 |
Drives: RX-7 / BRZ
What merge collector did you use?
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
10-16-2021, 09:03 AM | #356 |
Drives: BRZ, WRX
The collector and elbows are all Hypertune Hypex.
The Following User Says Thank You to DIY For This Useful Post: | Kiske (10-16-2021) |
10-25-2021, 04:04 AM | #357 |
Drives: BRZ, WRX
The turbo manifold is finished.
There are so many hours in this, such a small piece but so complex to fabricate. If I had my time again I may have just bought one but that is not in the spirit of this build. Having never welded stainless steel before, this was probably not the best starting point and I was certainly outside my comfort zone. I have followed best practice throughout the fabrication, everything was back purged during welding, fit up was tight, some of my welds probably got a little hot but nothing too extreme. I am confident the manifold is going to hold up to many years of abuse even though it is never going to get featured on weldporn.
The Following 12 Users Say Thank You to DIY For This Useful Post: | Ash_89 (10-26-2021), Boomerang (10-25-2021), Code Monkey (10-25-2021), DustinS (10-25-2021), Dzmitry (10-28-2021), flippy (10-29-2021), Irace86.2.0 (10-30-2021), Jdmjunkie (10-25-2021), NoHaveMSG (10-25-2021), RedReplicant (09-17-2022), RToyo86 (10-29-2021), TunaNoCrust (10-25-2021) |
10-27-2021, 04:00 AM | #358 |
Drives: BRZ, WRX
I've started on the exhaust system, its SuperGT inspired side exit.
The Following 11 Users Say Thank You to DIY For This Useful Post: |
10-29-2021, 02:58 AM | #359 |
Drives: BRZ, WRX
A video showing the exhaust. I will be adding more to it later, I just needed this bit done so I can start on the steering.
https://www.instagram.com/reel/CVmGa...dium=copy_link
10-29-2021, 09:18 AM | #360 |
I'm not understanding the idea behind the exhaust.
10-29-2021, 04:39 PM | #361 |
Drives: BRZ, WRX
It will be something like this.
11-02-2021, 11:35 PM | #362 |
Drives: 2015 Scion FRS Release Series 1.0
I assume the main reason you are doing the side exit is to have a uninterrupted flow for a proper rear diffuser?
11-03-2021, 12:28 AM | #363 | |
Sent from my Pixel 5a using Tapatalk
2013 Series 10 FRS #553
11-05-2021, 12:41 AM | #364 |
Drives: Q5 + BRZ + M796
I added you to our k-swap owners thread
