Drives: Scion FRS
I just finish installing new exedy oem clucth and flywheel. Also install mtec shifter spring. Atfer installing i tried to shift every gear and i can’t shift on 2nd gear. But everything else is fine 1,3,4,5,6,R are doing fine. Shifting like a butter. Except 2nd. I also try to put on 1st without gas pedal, it engage smoothly wheels are running. I feel so frustrated im working by my self so. Need some help
#2 |
Have you tried adjusting your clutch pedal a little?
Sent from my ONEPLUS A5010 using Tapatalk |
#3 |
Drives: Scion FRS
No i don’t adjust just doing clucth. Im going try if that work.
#4 |
#5 |
Drives: Scion FRS
Update..
i inspect clucth pedal and i got leak on clucth line on the slave cylinder so hope fully this work also how to check if my slave cylinder has leak i saw clucth line wet but maybe it was from the line. And since im going to adjust clucth pedal im buying mtec clucth spring. |
| The Following 3 Users Say Thank You to Currentwar For This Useful Post: |
#6 |
Did you remove the gearshift lever? If so, did you properly align the the top plate when reinstalling it? See service manual link in my sig line.
If you don't have it aligned properly, it'll keep you from getting into either, or both first and second gear.
#7 |
Drives: Scion FRS
Thank you for all your help it finally... i can drive it smooth.
| The Following User Says Thank You to Currentwar For This Useful Post: | Wally86 (10-29-2021) |
| Stiff to engage 1st/reverse from a stop after clutch install | mhiscott | Engine, Exhaust, Transmission | 94 | 07-19-2020 08:11 PM |
| Clutch Engage Whine? | PDM 2 | Issues | Warranty | Recalls / TSB | 12 | 10-25-2016 04:11 AM |
| Transmission won't engage any gears.. Diff/Axle is done. | Rifle | Issues | Warranty | Recalls / TSB | 35 | 03-29-2016 01:36 PM |
| Automatic transmission hard parking engage and disengage | nos145 | Issues | Warranty | Recalls / TSB | 21 | 09-18-2015 08:30 PM |
| clutch won't fully engage/8000 miles small dent | stockscionfrs | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 10-14-2014 12:06 PM |
