Old 10-18-2021, 02:43 PM   #4313
bokehmon
Drives: 2014 DMG BRZ
Originally Posted by BirdTRD View Post
A vacuum leak will do this. Have you tested your bypass valve to make sure it's not the source of the leak?
I replaced the bypass valve with the new style one on install - I'll check it tonight though, good call. It does look like the crazy LTFT only starts around mid-throttle around 2.5k.
Edit: just checked - held it at -10 in/hg for a few minutes with a vacuum gauge and it's rock solid.
I'm wondering if I bungled the intake mani gaskets, but that should show up on an intake manifold smoke test right?
edit: probably the dumbest question ever - I have the dual radium catch cans with my edelbrock setup - are you guys running the stock PCV also? I'm running lines directly from the catch can from the breather port -> can, and the other hose goes to the intake manifold directly. Also wondering if this is causing the weird issues im having.
edit 2: nvm, just realized the pcv is on the block. there is a bit of oil seepage, but I'm assuming that's normal.
bokehmon is offline   Reply With Quote
Old 10-18-2021, 04:14 PM   #4314
haohmaru
Drives: Red 2024 GR86 Trueno
Finally finished installing my Edelbrock and had it tuned. Gained over 120WHP from stock, VERY happy with the results, totally worth it.
The tuner kept the torque lower so I wouldn't snap any connecting rods.
Tuning day at PerryTuned in Tiverton RI
Results:
Powerband:
haohmaru is offline   Reply With Quote
The Following 5 Users Say Thank You to haohmaru For This Useful Post:
BrahmaBull1990 (10-20-2021), CallmeDave (04-25-2022), CSG Mike (10-18-2021), HlfpriceWngs (10-18-2021), Swolzee (10-18-2021)
Old 10-18-2021, 11:22 PM   #4315
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
I have/had similar issues. Have you checked your port injectors? Try cleaning them they may be clogged if you're at a higher mileage like mine were.
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386
Flickr: brandonblt567
brandonblt2 is offline   Reply With Quote
Old 10-19-2021, 04:05 PM   #4316
bokehmon
Good call - I'm at 85k now, I'll send em out for cleaning.
edit: Just had em cleaned - they tested perfectly. Injector guy is just putting it all back together now.
edit 2: anyone had to clean their direct injectors before? I'm wondering if that's the issue (or the seals going out)
Old 10-20-2021, 01:30 AM   #4317
FrickingReallySlow
Drives: 2015 FR-S
Nice, any other mods? headers or exhausts etc?
FrickingReallySlow is offline   Reply With Quote
Old 10-20-2021, 06:41 AM   #4318
haohmaru
Yeah, HKS catless headers, overpipe and Corsa exhaust. I'm keeping the stock catted midpipe as I got all the power I think the stock motor can safely make.
Old 10-20-2021, 02:44 PM   #4319
Swolzee
Swolzee's Avatar
Drives: Honda Insight
How difficult is changing injectors once the SC is in place?
Also, who all is tuned over 400whp+ on the E-force?
I've seen countless stock internal sub 300 builds, and a handful of 300-350 tunes, but I think I've only seen 2 documented tunes of over 400 or even close to that. I'd love to get some more information on some of the builds around this power level.
Swolzee is offline   Reply With Quote
Old 10-20-2021, 05:27 PM   #4320
bokehmon
Very easy (port injectors anyway) Literally 4 bolts + a couple for the black metal ecu bracket on the passenger side.
Just pulled mine to test, took less than 30 min.
Old 10-20-2021, 10:01 PM   #4321
CSG Mike
CSG Mike's Avatar
It takes a built engine, which is why it's rare. Furthermore, the stock trans is a ticking time bomb at that power level, so you'd want to have a spare on hand, or build/swap the trans as well.
You can take some measures to keep the torque down to make things last longer, but it won't be forever.
Old 10-20-2021, 11:20 PM   #4322
dpfarr
Drives: BRZ ts
What’s involved in building an FA20? I understand the rods are strong as ramen. I don’t think I’ve seen this platform get sleeves.
dpfarr is offline   Reply With Quote
Old 10-21-2021, 12:00 PM   #4323
Hurricane Nate
Drives: 2020 BRZ (Black)
It get's even easier on the passenger side if you get a new injector controller bracket. Everything on mine is exposed, and super easy to get to (also, I think it looks way better under the hood with the new bracket)
Hurricane Nate is offline   Reply With Quote
Old 10-21-2021, 02:30 PM   #4324
CSG Mike
CSG Mike's Avatar
Therein lies the problem. Everyone tries to "only do what they need" aka what they think is the bare minimum (typically rods and pistons), blow up, and then abandon the project.
They forget everything else. Heads, machining, studs, cooling, transmission, etc.
dpfarr (10-21-2021)
Old 10-21-2021, 03:20 PM   #4325
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Talk to engine builders who have experience with Subaru engines and they'll tell you how much more they love the EJ engines. The FA20 engine is more complicated with more parts, more screws, more gaskets and sealant. The FA20 engine is 55kg heavier compared to an EJ20 engine, which is an indicator of the increased complexity. Not an issue for the factory to assemble it with all the modern automation, but a more serious problem to hand assemble it with higher points of failure ...
The Following User Says Thank You to nikitopo For This Useful Post:
dpfarr (10-21-2021)
Old 10-21-2021, 06:02 PM   #4326
dpfarr
Drives: BRZ ts
Looked up some articles about creating solid fa20 fi platforms.
Seems like keeping it well under power threshold, our cars can be wringed out without issue. Divorcing the more more more theory from car modifying is something I haven’t suffered from greatly. I’ve always preferred the solidifying approach that I can do whatever all the way to the limit of the car and still drive the next day. Going to have to keep this not so deep in the back of my mind.
The Following User Says Thank You to dpfarr For This Useful Post:
nikitopo (10-21-2021)
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
