Old 10-09-2021, 06:23 AM   #337
SonnyMod
Drives: 2013 Scion FR-S (949 Racing)
Country: USA
State: California
Track Name/Configuration: Sonoma Raceway
Time: 1:48.847
NA/Forced Induction/Swap: NA
Driver: Sonny Watanasirisuk
Video:
Xida 600/600 with 949 Racing billet coaxial mounts
22mm Perrin front sway, stock rear
Renderos Racing 4-point roll bar
DIY Alumanite front splitter
APR GT250 wing + Singular endplates
-5.0° front camber
-2.5° rear camber
265/35R18 Goodyear SC3R (7 heat cycles)
18x10 +40 XXR CNC forged wheels
Delicious tune, 186whp on E85 (sick motor, down from 205whp)
SonnyMod is offline   Reply With Quote
Old 10-14-2021, 03:13 AM   #338
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Country: Canada
State: ON
Track Name/Configuration: Grand Bend Technical
Time: 1:15.899
NA: Yes (Stock #1)
Set up:
Ohlins MP20
245/40/17 RS4
Gloc R12/R6
Bride Zeta IV
Stock tune, stock drivetrain
villainous_frx is offline   Reply With Quote
Old 10-14-2021, 04:42 PM   #339
bellwilliam
Drives: 16 FRS
Country: USA
State: California
Track Name/Configuration: ACS Roval
Time: 1:58.095
Driver: William Chen
car mods:
Tires: Advan A052 245/40-17 on 949racing 6UL 17x8 wheels. Tires are way too wide for the wheel, steering is unresponsive. Difficult to find tire limits.
stock Sach suspension
Perrin 22mm front and 19mm rear sway bars
front camber plates
rear Moog lower control arm
Jackson Racing oil cooler
DTC60 brake pads
Tire pressure: 41psi front / 35psi rear hot
Alignment: Camber: -3.2 front and -2.2 rear. zero toe front, tiny toe-in in the rear. Pyrometer says front needs more, close to 4 to be ideal, but that could affect braking.
This was a super windy day, it would of been a 1:56s without wind.
Video:
bellwilliam is offline   Reply With Quote
The Following User Says Thank You to bellwilliam For This Useful Post:
949 Racing (10-14-2021)
Old 03-07-2022, 05:43 PM   #340
ozafar
Drives: 2015 Scion FRS Release Series 1.0
I had a VERY similar time!!
FI 2015 Release Series 1.0 Automatic
Track: Waterford Hills Michigan
Time: 1:17.77
Driver: Omer Zafar
Date: July 25th 2020
Mods: 17x9 RPF1s on RE71Rs, SBD turbo, Full Blown oil cooler, Spal fans, Bilstein shocks, Eibach springs, Verus plates, Winmax W4 pads, Verus diffuser, APR splitter, Seibon wing & vented hood, Whiteline bushings
Video:
ozafar is offline   Reply With Quote
Old 03-07-2022, 05:45 PM   #341
ozafar
Track: Nelson Ledges Ohio
Time: 1:18.88
Driver: Omer Zafar
Mods: 18x8.5 MR140s on Michelin PSS’s, SBD turbo, Full Blown oil cooler, Spal fans, Bilstein shocks, Eibach springs, Verus plates, Winmax W4 pads, Verus diffuser, APR splitter, Seibon wing & vented hood, Whiteline bushings
Old 03-09-2022, 02:18 PM   #342
ozafar
Track: Road America (with chicane)
Time: 2:57.83
Driver: Omer Zafar
Date: August 24th 2020
Old 09-06-2022, 10:06 PM   #343
gallucci86
Drives: 2014 FR-S
USA/Colorado/High Plains Raceway/Full Course/2:03.9/FI/Mike Gallucci/Turbo FA20
https://drive.google.com/file/d/1loO...?usp=drive_web
gallucci86 is offline   Reply With Quote
Old 09-13-2022, 11:48 AM   #344
deca
Drives: Halo 860
Country - USA
State - Michigan
Track Name and Configuration - Grattan Raceway
Time - 1:29.732
NA, Forced Induction, Swap - NA
Driver - David Best
Setup -
OFT Stage 2+ 93
Borla UEL header
Tanabe Concept G catback
Jackson Racing dual radiator/intercooler
Fortune Auto 510 Coilovers (8k square, rebound at 20F 18R)
SPL Rear LCA
-4° front camber
-2.2° rear camber
0° front toe
0.18° rear toe in
~5.15" ride height at pinch weld
245/40R17 Hankook RS4
17x9 +35 Enkei RPF1
CSG pads (C1 Front, C2 Rear)
Country - USA
State - Michigan
Track Name and Configuration - Waterford Hills
Time - 1:16.507
Driver - David Best
Setup -
OFT Stage 2+ 93
Borla UEL header
SPL Rear LCA
-4° front camber
-2.2° rear camber
0° front toe
0.18° rear toe in
255/40R17 Falken RT660
17x9 +35 Enkei RPF1
deca is offline   Reply With Quote
Old 09-14-2022, 10:56 AM   #345
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
Show the proof!
Originally Posted by gcranston View Post
You got a build thread and/or a video? This I've got to see!
REALLY!
The WGI lap record, set recently, for a spec Miata is 2:14
The best I'm certain of is a buddy's 2:18, in a tuned (190HP) 2017 PP BRZ.
I equaled that time, in a rolling lap, with my stock engine/stock exhaust 2022 BRZ on 8-29-2022.
Scargod is offline   Reply With Quote
Old 09-14-2022, 11:57 AM   #346
lutfy
lutfy's Avatar
Drives: 2022 LR Defender, 2015 FRS_ST5/TT5
Originally Posted by Scargod View Post
REALLY!
Another fellow competitor did a 2:08.08 in a NA 86:
2015 FRS NASA ST/TT5
2022 LR Defender
2023 BMW M2
lutfy is offline   Reply With Quote
The Following User Says Thank You to lutfy For This Useful Post:
Scargod (09-14-2022)
Old 09-15-2022, 08:33 AM   #347
Scargod
Track Day Junkie
Scargod's Avatar
[QUOTE=lutfy;3547076]Another fellow competitor did a 2:08.08 in a NA 86:
Whatever the weight, power and tires, that's amazing for TT5. Really fast for a NA BRZ, period!
Old 09-15-2022, 10:42 AM   #348
lutfy
lutfy's Avatar
[QUOTE=Scargod;3547181]
I have actually driven that car. Nothing special, just stripped down to be around 2650lbs (weight will go up once caged), PP Brembo, MCS, swaybars, rear wing (header/e85). But Nick is a heck of a driver and will run 1/2 to a full sec ahead of others.
Back to the drawing board
Lutfy
2022 LR Defender
2023 BMW M2
The Following 3 Users Say Thank You to lutfy For This Useful Post:
CSG Mike (09-15-2022), ML (09-19-2022), Scargod (09-18-2022)
lap record, lap time, race track, track record
Anything going on with 86/brz platform? Vr4gasmtt Scion FR-S / Toyota 86 GT86 General Forum 19 06-12-2016 02:55 PM
Indigo Dash cam that records you? Packofcrows Electronics | Audio | NAV | Infotainment 3 08-23-2015 08:54 PM
FS: 2004 Toyota Matrix - Dealer Serviced, Full Records! that_guy Canada Classifieds 1 09-23-2014 11:43 AM
Can Toyota use the 86/FR-S/BRZ platform for anything else? gymratter Scion FR-S / Toyota 86 GT86 General Forum 83 04-24-2014 07:41 PM
You don't break track records by settling! Custom Valved BC Coilvers and Carbotech XP Element Tuning Brakes, Suspension, Chassis 24 07-23-2012 10:35 PM
