Old 09-29-2021, 02:04 PM   #1163
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by ojuniour View Post
New Owner here.. Bought straight from Irace86.2.0
Running on 17 Auto + e85 ( ~ e70).
Anyone experiencing very rough idle ..almost like it's starving for fuel..
Make sure you have no air leaks post MAF and the MAF is clean and the injectors are clocked in the right direction and aren’t leaking/seated well. Small air leaks might show up more on idle than at WOT. If it doesn’t run well at speed either then that is more likely injectors that could be clocked wrong. I wish the aftermarket injectors locked into position like the OEM ones.
What is the rpm at idle? Typically the idle will be raised to 850-1000 from the stock 650-800.
How is it running at speed?
Old 09-29-2021, 02:49 PM   #1164
ojuniour
ojuniour's Avatar
Drives: Subaru BRZ 2017
it seems to be all seated normally.. now the inject clocking..I wonder what the margin of error regarding the alignment direction.
I have the full idle logs if anyone is interesting in helping diagnosing it..
ojuniour is offline   Reply With Quote
Old 09-29-2021, 03:03 PM   #1165
Irace86.2.0
Maybe 5-10 degrees at most. If it sprays on the manifold then it isn’t atomized. I zip tied the harness once positioned, so it didn’t move.
Post the datalog.
Old 09-29-2021, 07:13 PM   #1166
ojuniour
ojuniour's Avatar
Post the datalog.
here it is:
https://datazap.me/u/ojuniour/harrop-cold-start?log=0&data=15
Old 09-29-2021, 08:28 PM   #1167
Irace86.2.0
Who is your tuner?
I'm not a tuner or the best at reading these things. It is possible to interpret something wrong that is normal or normal for the conditions and not the cause of the problem. My idle is pretty flat and smooth, so any comparison might not be correct. Like I have zero direct injector duty at idle, but you have a combination of both, but is that because you have a fluctuating idle or is it just a difference in tuner and is it bad or is it fine?
My throttle angle at idle says 14.5 and your sales 0, so I don't know if my tuner had set up the idle to be higher than stock. My port time at 900-1500 is 1.0-1.25 ms and my direct is 0. Your port time at 1500 is 1.25 to 1.35 ms, and your direct time is 1.65 to 1.85 ms, which means you have more fuel going. Your afr is not hitting close to the target, fluctuating up and down, but I don't know what is causing that situation. My vacuum at idle around 900 rpms is 0.32 bar, which is 0.68 away from 1 bar of atmosphere, which is 20 inHG of vacuum. Your 900-1000 rpm idle was fluctuating around 4.5-5.5 psi, which is around 18-20 inHG, so I don't think you have a leak in the manifold, or I feel like that value would be much closer to atmosphere.
What does your tuner say?
Old 09-29-2021, 09:18 PM   #1168
kg17
Drives: 2015 BRZ Crystal White Pearl
any check engine lights ?
kg17 is offline   Reply With Quote
Old 09-29-2021, 09:20 PM   #1169
Irace86.2.0
Long term fuel trim is 20% at idle, adding fuel. Short term is 0 and then goes negative, trying to remove fuel to fight the long term fuel maybe. Then the long term drops out and the short term takes over and is widely fluctuating. I think there is a vacuum leak somewhere or there is a fuel leak, or the injectors are clocked weird. Both could cause long term trims to be so high.
Old 09-29-2021, 11:22 PM   #1170
ojuniour
ojuniour's Avatar
Yea P050B and P0300...
But my tuner sorta send a different tune after that.. no longer getting that but still getting that jerky idle..
Suggestion was that could be a vacuum leak...
I'll be checking tomorrow.
Old 10-02-2021, 08:26 PM   #1171
kg17
So was there a vacuum leak or check engine lights still on ?
Old 10-08-2021, 11:21 PM   #1172
YCK
Drives: Toyota 86 GTS 2019
Hi Brain Trust,
I am after some long-term reviews and recommendations for the Harrop Supercharger kit from people who track their car. I am hoping to join the gang once Harrop starts selling those again.
I am an enthusiastic beginner and attended about 25 track days on my first year. I put a maximum of 15,000 Km max / year on my facelift Toyota 86, subtropical weather (Australia).
I’d be keen to have some basic data from previous owners, how long they had their kit for, what track usage it gets in what kind of weather, and what broke during that time.
In term of recommendation, what would be a conservative / reliable setup and things like pulley size and other supporting mods? I would be running e85 most of the time. And do I really have to cut air vents in the hood…
Thank you!
YCK is offline   Reply With Quote
Old 10-10-2021, 02:18 AM   #1173
FunnyGopher
Drives: 2015 BRZ Limited
Originally Posted by YCK View Post
Hi Brain Trust,
Hello! I'm in the same boat as you, waiting for Harrop to start selling kits again. I have a good set of exhaust pipes, e85, and an oil cooler, and I was told by Zach from CSG (my tuner) I could easily make ~320 from the stock pulley, and that's just the beginning. Start stepping down sizes from there for more power. From my research on the kit, and from others in this forum, my confidence in the reliability of this kit is fairly high, especially if you're not running too small of a pulley.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 10-10-2021, 07:05 AM   #1174
Sam86
Can you not buy it from FAF Auto? Still looks available on there, would have purchased myself but I think i'll wait for HARROP as I live near their HQ and would prefer to have it installed by them.
Harrop claims 335 crank on their dyno tune for e85 and uel headers.
Just saw you aren't from AUS... Don't know how you'll go with shipping costs for that
Sam86 is offline   Reply With Quote
Old 10-10-2021, 10:09 AM   #1175
grumpysnapper
grumpysnapper's Avatar
Hi Brain Trust,
Thank you!
Im in Brisbane, and had a Harrop now for over 5 years.
Started with a 90mm pulley, headers, bigger single exhaust and 98ron.
About 222hp at the wheels on 98ron.
I uprated the radiator and added an oil cooler. Ran it like that for 3 years, with %100 reliability.
About 2 years ago went the whole hog with the 65mm pulley, flex fuel, motec and a built motor.
About 346 hp at the wheels on E85.
Great fun.... but huge costs.
Been very reliable so far (after I solved the belt issues with the smaller pulley).
You really don't need to put vents in the bonnet... the car spends a lot of time in hot weather doing this with no dramas temperature wise:
grumpysnapper is offline   Reply With Quote
The Following User Says Thank You to grumpysnapper For This Useful Post:
bhmax (02-23-2022)
Old 10-10-2021, 08:41 PM   #1176
Sam86
222whp sounds a little underwhelming... Harrop claim 235kw crank with headers on 98 so 95hp loss seems a lot.
I would have expected 280 wheel on 98 and 320 on e85, then 350+ when you started upgrading the pulley and other components based on HARROPs info and in comparison to other kits
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 05:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 03:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
