| Software Tuning Discuss all software tuning topics. |
Drives: 2015 FR-S
Idle MAP reading ~4psi but P3Gauge reading -20inHg
Looking for some help on this weird discrepancy between ECUTEK logging of MAP reading vs my P3Gauge.
I have a Edelbrock SC with Delicious tuning with D-Box smoothie. If you see my below log during idle the MAP sensor is reading ~4psi instead of vacuum. interesting enough my P3gauge reading ODB2 sees ~ -20inHg which is more in line. I'm wondering why there's this discrepancy. Is there something in Delicious tuning that offsets the MAP during ECUTEK logging? which one is correct? https://datazap.me/u/s0007/2k-6k-pulls?log=0&data=7-23 |
#2 |
LMGTFY
Drives: 13 FRS, 91 Miata
Stock MAP sensor?
#3 |
Drives: 2015 FR-S
The edelbrock SC kit includes a 2 bar Bosch TMAP sensor. Even though both the P3Gauge and ECUTEK is reading from ODB2 I'm wondering if one is relative while the other is absolute. Spoke with P3 and they said even though the gauge is digital, vacuum is always displayed in -inHg while positive is in PSI
-20inHg is roughly -9.8psi. So if that's -9.8psi relative to atmospheric then 14.4-9.8 is roughly 4.9psi absolute. Not sure if this is correct assumption but welcome feedback here. |
#4 | |
Drives: FT86
Turn ignition full on , but engine off, map srnsor or guage should read 14 psi or 1 bar ie atmospheric if absolute or. 0 psi 0 bar if reliative Also depends if your looking at reliative pressure or absolute id say your reading reliative on one and absolute on the other |
| The Following User Says Thank You to steve99 For This Useful Post: | FrickingReallySlow (09-30-2021) |
#5 |
Drives: brz 2017 hksv2
yep looks ok
| The Following User Says Thank You to tomm.brz For This Useful Post: | FrickingReallySlow (09-30-2021) |
#6 |
No discrepancy, engine computers calculate from absolute pressure. Relative pressure means nothing when calculating amount of fuel needed.
| The Following User Says Thank You to Grady For This Useful Post: | FrickingReallySlow (10-08-2021) |
#7 | |
Drives: 2015 FR-S
Thx got the gauge to stay on with engine off and it reads 0 PSI.
| Need Help Reading ECU | Eddy98 | Software Tuning | 1 | 12-21-2020 04:59 AM |
| OFT not reading ECU | Gray Fox | Software Tuning | 12 | 08-02-2017 07:44 PM |
| What is the expected vacuum reading at idle? | qtwre | Forced Induction | 20 | 05-03-2017 11:27 PM |
| Reading Vin # | Knightmare | BRZ First-Gen (2012+) — General Topics | 2 | 11-16-2012 02:26 PM |
