| Northwest AK, ID, OR, WA |
Drives: 2014 DMG BRZ
Maf for testing
Hey NW crew - I've installed my edelbrock supercharger, but have been having some weird fuel trim issues (+/-30), and believe that it may be a sensor issue.
I've smoke tested the intake for leaks, but haven't found any. I've also replaced the o2 sensor with no discernible difference, which leads me to believe that the maf or wiring may be faulty (can't see/feel any leaks in the exhaust either) I've got a 2014 brz - not sure if there's a difference between years and mafs though. Does anyone in the larger Seattle area (I'm in Lynnwood) have a maf that I could borrow for testing? |
#2 |
Drives: Crapcan
I’m too far to help though I have a suggestion. I would log the car at a steady state. Look at what the maf voltage is reading. If the car is idling for a minute and the maf voltages are all over the place it’s probably the maf.
#3 | |
I'm actually seeing the issues around 2700 rpm at steady state (stft goes to +30, and ltft goes to +40 max). It's definitely concerning. I'm going to go back to stock header and try to eliminate things one by one. I'm wondering if i just have a dirty injector or something. |
#4 | |
Drives: Crapcan
#5 | |
Here's a 60~MPH cruise - you can def see the LTFT and the STFT spiking ![]() https://datazap.me/u/bokehmon/log-16...&data=31-34-35 |
#6 | |
Drives: Crapcan
#7 | |
I think I'm going to slowly remove variables, hopefully I won't have to re-install the supercharger.
#8 |
Drives: 2016 BRZ Hyper.Blue
Did you get this sorted out? I have MAF sensor that you can borrow, but you'll need to either pick it up today or wait until the 10/15. I'm in Renton.
#9 | |
Master Collaborator
#10 | |
I didn't - i just checked the header for leaks - looks fine, so probably some thing top side (maf, vacuum leak[?]) Messaging you my # if you're in Renton still - I can drive down today. Update: got an appointment with the Drift Office guys - they're taking a look at it on Saturday. Thanks everyone! Last edited by bokehmon; 10-05-2021 at 11:14 PM. |
#11 |
Drives: Gt86 2013
Hi did you fix the issue? I have similar LTFT and when I’m in neutral flooring the pedal there’s a lag especially at around 2k rpms… I noticed there’s no lag when I remove the maf sensor and accelerate in neutral… my maf sensor voltage fluctuates between 1.15 and 3.90.
| Testing of me new car :) | FishMac | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 04-20-2013 05:38 PM |
| just testing sig | mrlewistan | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 02-25-2013 04:13 PM |
| testing | FT-MH | Announcements, Contests, Giveaways | 14 | 07-31-2012 11:00 PM |
