Old 09-28-2021, 01:12 PM   #71
SUBADRU
Building à DRIFTER
SUBADRU's Avatar
Drives: 2013 Subaru BRZ limited w/HKS Super
I have a 2013 BRZ fried my wiring harness under the hood
I hear that the wire harness in the 13_14 brz is a fail point. I infact have cooked my harness from the main plug wires to my injectors. Ive heard that its not uncommon to be replaced with a 2015 2017 harness. Where would i get one of these? And is there any aftermarket support for an upgraded version.
My car has the following installed hks supercharger/hks flash editor/ afe twisted header/invidia full titanium catback/ aem 340lph fuel pump/
Parts not installed but owned ecutek programmer will be tuned oct 12 if i fix my harness and e85 with ID 1040
Dual catch cans and a Grimm speed boost controller waiting also on my ACT extreme clutch n flywheel
SUBADRU is offline   Reply With Quote
Old 09-28-2021, 01:35 PM   #72
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Have never heard that before. The main reason people upgrade to the 15' wire harness is to use the updated coil packs.
Old 01-13-2025, 09:43 PM   #73
zeal86
zeal86's Avatar
Drives:
Direct Injectors Question
I am trying to acquire definitive information about reinstalling direct injectors (Ds) out of the original order into the FA20. Does it matter? I've read varying opinions on this...it matters and it doesn't matter. Some of the opinions were not necessarily about the FA20 but in general. Some stating different positions have varying spray patterns. Some things I read stated disconnecting the battery/pulling fuse so that the ECU can adjust to new injectors or in my case, possibly the wong positions.
If it does matter...I have my (DIs) ready to reinstall but I've lost track of which ones I pulled from which cylinders and/or position on DI fuel rails. I think I know which two came from the passenger side vs the driver side fuel rails but not a 100% on that.
All injectors have the same part numbers minus the serial numbers. They are the original OEM ones with the stratified number 2 printed on them. I just cleaned them and changed all the seals.
Any help will be appreciated!
www.instagram.com/zeal.eightsix
zeal86 is offline   Reply With Quote
Controlled Information Leaks groupb Scion FR-S / Toyota 86 GT86 General Forum 27 02-12-2013 09:20 PM
A little information about the Automatic ryude Engine, Exhaust, Transmission 2 12-03-2011 10:13 AM
Dimman's technical stuff. Dimman Other Vehicles & General Automotive Discussions 74 10-17-2011 02:15 PM
New Information, 8/5/11 1660 Scion FR-S / Toyota 86 GT86 General Forum 214 08-17-2011 03:33 AM
Condensed Information Heimer Scion FR-S / Toyota 86 GT86 General Forum 43 07-23-2011 01:43 PM
