Old 09-16-2021, 09:04 PM   #1
YELLOW
Drives: 2017 Subaru BRZ
Does anyone Rebuild PP Sachs struts?
Why would I ask?
Just for purposes of playing in the Stock RallyCross class.
Or what's the best way/option to comply with this rule for RallyCross:
Are all shocks/dampers unmodified OEM or unmodified mass‐produced aftermarket replacement units intended by the manufacturer for the specific year, make and model with the same number of adjustments?
Yes, probably a dumb question...
YELLOW is offline   Reply With Quote
Old 09-16-2021, 09:40 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Even if you could find someone to do it most shops charge >$200/corner for a rebuild. I doubt it's possible due to the crimp seal design in most dampers. New looks to be about $1,300/set which ouch.
Rule feels written to favor Bilstein B6's, Koni orange might not suck either, KYB if you're desperate.
ineedyourdiddly
Old 09-16-2021, 09:57 PM   #3
Racecomp Engineering
Use Bilstein B6, they're fantastic for exactly that.
- Andrew
Dzmitry (09-17-2021)
rallycross, suspension
Sachs struts/shocks, Swift BRZ springs, factory springs ZDan Brakes, Suspension, Chassis 8 03-26-2021 03:22 PM
PP Sachs suspension vs tS Sachs supspension FindOphion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 05-24-2020 04:35 PM
LF sachs dampers jhalagian Canada Classifieds 0 07-10-2019 12:31 PM
FS: Goodrich SS Brake lines, TRD spring/Sway bars, Sachs struts Tacticalpanda Brakes, Suspension, Chassis 6 01-25-2019 05:21 PM
Airlift performance air struts (only struts) RavenFR-Sowner Brakes, Suspension, Chassis 1 11-01-2015 05:51 PM
