#883 | |
Drives: 2017 toyota 86
300,000 deaths a year could be prevented by abolishing obesity alone un related to covid, then factoring in the profound benefit to helping reduce covid cases, reduce covid mortalities, and improving outlook on top of that. Same goes for smokers. Far greater bang for buck to end obesity and/or smoking than a vaccine. Even if vaccine had 100% success rate which it doesn't. All things equated its probably closer to 40-60% success. Mandate a vaccine, ok fine. Then mandate ending obesity and smoking too, if you really care about peoples health and well being, the cost and burden on the medical system etc... then you would have no problem with mandates that helped end smoking and obesity. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | funwheeldrive (09-13-2021) |
#884 |
#885 |
Drives: what
#886 |
| The Following 2 Users Say Thank You to 86TOYO2k17 For This Useful Post: | funwheeldrive (09-13-2021), Ultramaroon (09-13-2021) |
#887 |
If you believe that 1 year can fix obesity "at the extreme" you have never had to deal with weight loss. Think of it as alcoholism without the ability to stop cold turkey. As someone who has basically fought the "good fight" against it personally all my life, it just ain't that simple.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 7 Users Say Thank You to Dadhawk For This Useful Post: | Irace86.2.0 (09-13-2021), Kaotic Lazagna (09-13-2021), MuseChaser (09-13-2021), soundman98 (09-13-2021), spike021 (09-13-2021), wbradley (09-13-2021), weederr33 (09-13-2021) |
#888 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
| The Following 3 Users Say Thank You to weederr33 For This Useful Post: |
#889 | |
Also, I'm in pretty good shape and cardiovascular health with no known problems, and I still got a pretty bad sinus infection recently. Not being overweight does NOT prevent you from getting a virus let alone prevent it from transmission. While your solution is wonderful for those affected by CVD, diabetes, and other problems associated with poor health, it's not a proper solution.
| The Following 4 Users Say Thank You to weederr33 For This Useful Post: |
#890 | |
Drives: what
i'm not going to waste my time giving a rebuttal to someone who is clearly arguing in bad faith, but i will mock you |
#891 | |
The Dictater
Drives: '13 Red Scion FRS
The vaccine is 95% effective against vanilla covid. And 80+% effective against known variants. Obesity being a factor for 30% of covid hospitalizations is still nowhere near the effectivity of the vaccine against covid. Then there is the problem of success rate. Getting the vaccine is easy. You show up, you get inoculated, and you leave. Twice if it's the mRNA. It's a lot harder to lose weight. Many (possibly the majority) try and fail. Whereas there is nearly 100% success in administering the vaccine. |
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | Irace86.2.0 (09-13-2021), soundman98 (09-13-2021) |
#892 | |
Sarcastic SOB
Obesity is 30% BMI or greater IIRC. How long would it take someone to lose 50 lbs, a year? And what is the typical success rate for large weight loss attempts? And how are you going to actually enforce this when many people simply can't lose a lot of weight? And lastly how can weight loss of an entire population prevent transmission, infection and mutation of the virus? Whine about mandates for vaccination and masking. Mandate set for a 1500 calorie diet and obligatory 30 mins cardio, 30 minutes strength 6 days per week. Ya, everyone would be on board. So glad you thought of an easier solution. �� Let us know if/when your head clears. Here's how we mandate anti-smoking at around $14/pack with taxes.
| The Following User Says Thank You to wbradley For This Useful Post: | Spuds (09-13-2021) |
#893 | |
Drives: Q5 + BRZ + M796
Collateral deaths…
His family tried to find him an ICU bed—43 hospitals turned them away
https://www.washingtonpost.com/healt...hospitals-icu/ Quote:
#894 |
As a former personal trainer/manager with a BS in Exercise Physiology, I can say that the notion of ending obesity or trying to mandate it away is nonsense, but no one needs a degree to know that—just a few brain cells can figure that out.
There is 3500 calories in a pound of fat, so a pound of fat loss per week requires a 500 calorie deficit a day. Eating less than someone’s BMR leads to muscle waisting and a slowing of the metabolism and a compromising to regeneration and to the immune system, and losing more than two pounds a week typically means some muscle is lost too, so people need to eat enough to be at or over tgeir BMR, but still in a deficit. Walking a mile burns about 100 calories or more, depending on weight, so burning enough to eat enough while still being in a caloric deficit isn’t easy, unless someone has an active lifestyle or job. Unlikely if someone is obese to begin with. Weight loss isn’t easy. Obesity is more often defined by BMI than body fat percentage. BMI is not a percentage score; it is a ratio of height to weight. Most obese people have over 50lbs to lose, but at a pound a week, that is almost a year of perfect weight loss. ![]() Obviously it is ludicrous to expect a vaccine to compare to weight loss or smoking cessation or anything else that requires behavior modification. Getting a vaccine is the easiest thing anyone could do and provides the most to gain, even over masking or other continuous behavior modifications that often are not consistent or fail. We expected breakthrough cases and deaths because the efficacy of the vaccine was only 95% to initial variants. That means 5% would develop no immunity or weak enough immunity to get COVID. Five percent is a lot of Americans, but had we reached 95% of society vaccinated, we would expect herd immunity to drop the transmission rate for that 5%. As is the case, we have failed the 5%, and other variants have dropped the efficacy for not getting COVID, yet the vaccine is still really efficacious (99%) at preventing hospitalizations and deaths. Nevertheless, we have so many people who are unvaccinated that hospitals are overwhelmed, so we are seeing 1500-2000 deaths from COVID a day now and more collateral deaths from a constipated healthcare system. It is too bad. I’m for mandatory vaccine mandates.
| The Following 4 Users Say Thank You to Irace86.2.0 For This Useful Post: |
#895 | |
~~~~~~~~~~~~~~ Oh, and healthy young adults are dying. Healthy kids are dying. Most people are fat not because of simply eating too much, it's because they eat shit food with empty calories because they can't afford real food. Arguing that everyone should simply go on a diet is not only unrealistic, it's downright callous.
Last edited by Ultramaroon; 09-13-2021 at 12:55 PM. Reason: And another thing... |
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | soundman98 (09-13-2021), spike021 (09-13-2021) |
#896 | |
Drives: 2017 BRZ
And I still have no idea how you think this is an alternative to the vaccine. Also, obesity is not contagious.
| The Following User Says Thank You to cjd For This Useful Post: | soundman98 (09-13-2021) |
| Dating during Covid | Impureclient | Off-Topic Lounge [WARNING: NO POLITICS] | 143 | 08-22-2023 12:33 PM |
| Covid 19 origin(s) | Lantanafrs2 | Off-Topic Lounge [WARNING: NO POLITICS] | 280 | 08-29-2021 12:38 AM |
| Covid Lockdown Activities | Boomerang | Off-Topic Lounge [WARNING: NO POLITICS] | 1471 | 09-29-2020 03:38 PM |
