Old 09-10-2021, 04:26 PM   #15
Grady
Grady's Avatar
If you get around to checking the voltage drop on the ground wire here is a reference to verify your readings. This is a normal start of mine. Measurement was read between battery negative terminal and engine(alternator).
As you see during start there is about a .41v drop on the negative lead. My guess is about a 150 amp spike(I did not measure amps). If your starter was shorted and put a 300+ amp load you would get around a 1 volt drop.
Old 09-10-2021, 05:27 PM   #16
Originally Posted by RZNT4R View Post
He just changed it.
my bad -
Old 09-10-2021, 06:40 PM   #17
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
So yeah haha a few hundred mV Sure would have been a shame to come up with a BS number like that to begin with huh?
Surging/stalling when accelerating. intermittent issue scarysquash Issues | Warranty | Recalls / TSB 17 09-09-2025 12:16 PM
Power steering issue with slicks? owenxguo Tracking / Autocross / HPDE / Drifting 59 02-06-2024 12:05 PM
Intermittent power steering loss nextcar Issues | Warranty | Recalls / TSB 2 06-01-2021 02:54 PM
Intermittent Starting Issue Jdmjunkie Issues | Warranty | Recalls / TSB 2 08-04-2020 06:07 PM
Intermittent power steering FencebusterTDI Issues | Warranty | Recalls / TSB 12 12-31-2017 05:01 PM
