Old 09-07-2021, 08:35 PM   #1205
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Question, will you sit through a match?? I remember the last match I attended, it rained, and rained and then rained some more.. I think the teams managed about 30 minutes of play over the whole day!
So, what song do you sing in the 7th inning stretch?
Old 09-07-2021, 09:29 PM   #1206
Strange how much turn in he has there. I'd expect to see much less bar input. Is that a really sharp corner or just the angle making it look like more then it is?
On his way to coming up for air
NoHaveMSG (09-07-2021), soundman98 (09-08-2021)
Old 09-07-2021, 10:20 PM   #1207
Mates?
Old 09-08-2021, 02:50 PM   #1208
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
And the digital camera damn near pushed the target over!
Just goes to show how much the equipment and riding styles have changed over the decades.
90 degree right. (see image)
The Following 2 Users Say Thank You to Stephen W. For This Useful Post:
NoHaveMSG (09-08-2021), Ultramaroon (09-08-2021)
Old 09-08-2021, 03:01 PM   #1209
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Ah, makes total sense now.
Old 09-08-2021, 04:28 PM   #1210
JD001
JD001's Avatar
Drives: Subaru BRZ
Oh, we sing this ..
Oops wrong sport..
The Following User Says Thank You to JD001 For This Useful Post:
Old 09-08-2021, 04:50 PM   #1211
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You've definitely burning your bridges, what if he gets back with her?
They are already back together lol
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
JD001 (09-09-2021), soundman98 (09-09-2021), Ultramaroon (09-08-2021)
Old 09-08-2021, 07:15 PM   #1212
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Oh, we sing this ..
Oops wrong sport..
Neil Diamond and soccer!? Will the excitement ever end?
Old 09-09-2021, 04:55 AM   #1213
JD001
JD001's Avatar
Drives: Subaru BRZ
"Excitement" does sadly come to an end, as the England team nose dives very quickly...
Dadhawk (09-09-2021)
Old 09-11-2021, 04:14 PM   #1214
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
TIL - Actually, today I was REMINDED - - Small engines (think Briggs and Stratton) will run seemingly no matter what abuse you heap on them. My 25 year old snapper with a B&S engine quit starting. Took it apart and found the plastic intake "manifold" had broken. Same thing happened about 10 years ago and one of my son's buddies at work offered to fix it. Got it back and it ran fine until last week.
Looking at it closely, when my son's bud worked on it he apparently broke one of the bolts that hold the carb bracket to the engine. There had been two. So, he left both bolts off and fabricated a tab to attach the carb bracket to a head bolt. It ran like that for 10 years.
I decided to do it "right," so I tried Kroil on the stub of the bolt and and let it sit- hammer - punch - chisel no dice. So I cut off the bolt flush with the cylinder boss it threaded into with a Dremel. Drilled a small hole through the bolt and squirted more Kroil in the hole. Waited. Tried an easy out. No Dice. So I drilled the whole bolt out and installed a 6x1 helicoil. As I was tapping the casting for the helicoil I looked down the bolt hole and noticed I could see the piston. Sure enough, turn the crank, and it goes up and down. WTF!!
Shit. Well, I've been waiting for the Snapper to die so I could go electric - today must be the day. But, why not finish the job and see what happens. So, I
- installed the Helicoil
- installed the carb bracket with a shiny new stainless 6x1 bolt with a large blob of blue loctite to seal the threads.
- installed the other (formerly missing) bracket bolt
- installed the carb, air filter, blower housing, fuel tank.
primed it a half dozen times and it started on the second pull. Mowed the yard figuring some of the clag from drilling and tapping the mounting bracket hole would get into the cylinder and kill it. Nope. Not so far.
These things seem to be thermonuclear bomb proof. Have to wait a few weeks to go electric.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post:
MuseChaser (09-11-2021), soundman98 (09-12-2021), Ultramaroon (09-11-2021)
Old 09-11-2021, 06:51 PM   #1215
Originally Posted by Capt Spaulding View Post
TIL - Actually, today I was REMINDED - - Small engines (think Briggs and Stratton) will run seemingly no matter what abuse you heap on them. My 25 year old snapper with a B&S engine quit starting. Took it apart and found the plastic intake "manifold" had broken. Same thing happened about 10 years ago and one of my son's buddies at work offered to fix it. Got it back and it ran fine until last week....
If you are going to wait until that engine can't be resurrected for a few cheap parts, you are likely going to be waiting a while. I have a cousin who as a B&S Majestic 20 crank start mower purchased by my Grandfather in the 1960s, and has been used as a mower by my Grandfather, then my Uncle and now his son.
In fact it looks about like this one....
Dadhawk is online now   Reply With Quote
The Following 4 Users Say Thank You to Dadhawk For This Useful Post:
Capt Spaulding (09-11-2021), MuseChaser (09-11-2021), soundman98 (09-12-2021), Ultramaroon (09-11-2021)
Old 09-11-2021, 07:17 PM   #1216
JD001
JD001's Avatar
Drives: Subaru BRZ
Today I learned that Canadians are sore losers!!
Old 09-11-2021, 07:40 PM   #1217
Save it for when the electric one dies.
Dadhawk (09-12-2021), soundman98 (09-12-2021)
Old 09-11-2021, 07:44 PM   #1218
crank start mower
We had one of those. I think I broke the big clock spring.
OFT KC learned Nah Software Tuning 3 03-17-2016 01:52 AM
Learned some interesting things about my car today... SisterBlue22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-09-2015 03:23 PM
Everything I know, I learned from the internet. Chillswitch Cosmetic Modification (Interior/Exterior/Lighting) 17 01-09-2015 03:31 PM
KC learned, what does it mean? wparsons Software Tuning 4 08-16-2014 12:37 AM
Today I learned (TIL) IloveBaldEagles Off-Topic Lounge [WARNING: NO POLITICS] 5 03-16-2013 09:15 PM
