Old 08-23-2021, 06:27 PM   #1
daniloneil8
Changing my gearbox fluid. Redline MTL or Redline MT-90 ?
GL4
Spec is
Toyota MT Gear Oil Spce.II GL-3
75W-90
Redline MT-90 vs. MTL
• MTL is a low 75W, almost a 70W, at very low temperatures and a high 80W, nearly an 85W, at elevated temperatures, providing adequate viscosity to prevent wear and deaden gear noise.
• MT-90 is a thicker 75W90 version of MTL. ... MT-90 is a 75W90 GL-4 and also satisfies motor oil viscosities SAE 10W/15W/40.
So, should I go with 70W85 or 75W90 ?
Easier cold shifting with the lighter MTL?
daniloneil8 is offline   Reply With Quote
Old 08-24-2021, 04:00 AM   #2
Thefalls
Thefalls's Avatar
Drives: Corolla GT
MT-90.
Tried and tested by many over here.
Thefalls is offline   Reply With Quote
Old 08-24-2021, 11:17 AM   #3
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
If the car is only a daily, MTL. If you track it, MT90.
Ive been running Pentosin MTF-2 (75w-80) for years now with no issues. So much better in cold weather. I think it might fall short when its REALLY hot out. Like 95F+ and I start driving harder.
Also, the new GR86 lowered the gear oil viscosity in the manual transmission. Couldnt tell you what, but I read it on the internet.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 08-24-2021, 11:48 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
I just replaced my factory fill at 54k street miles and a few years track duty with MT90. Didn't see any reason to deviate from factory viscosities. Shifting is great so far, a bit better 1-2 vs. heavily used factory fill, see how it goes this Winter but not really worried...
Old 08-24-2021, 12:31 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Mt-90 is still pretty decent in the cold. I have been using it for quite a while.
Old 08-24-2021, 12:34 PM   #6
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
MT-90 is preferred by many in Canada. I've only used it in like 8C (46F) during a fall track day. Not as notchy as stock/OEM fluid or Gear 300.
villainous_frx is offline   Reply With Quote
Oil Filters, ENEOS Oil, Redline Oil, Brake Fluid and Air Filters @ OAKOS.com OAKOS Automotive Mechanical Maintenance and Tools 50 11-02-2015 11:03 AM
Oil Filters, ENEOS Oil, Redline Oil, Brake Fluid and Air Filters @ OAKOS.com OAKOS Automotive Mechanical Maintenance and Tools 144 01-20-2015 12:37 PM
FS: Redline MT-90 BMWDavid Transmission and Driveline 3 01-07-2014 09:52 AM
Transmission fluid blending Redline MTL and Motul Gear 300 okay? imom Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-01-2013 09:03 PM
FS: Redline GL-4 70w80 Transmission Fluid Tt3Sheppard Mechanical Maintenance and Tools 0 10-22-2013 01:37 PM
