Old 08-23-2021, 10:17 AM   #15
knapper
knapper's Avatar
Drives: '13 Scion FR-S - Whiteout
A lot of the time, if it keeps happening after checking normal issues mentioned above, it is the gears themselves inside timing cover. Getting the cover off is the worst part. Watched this video to help:
I had a P000A for a few weeks, replaced all of the solenoids for each bank and no issues at all now.
knapper is offline   Reply With Quote
Old 10-19-2021, 05:54 PM   #16
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Originally Posted by tadeon View Post
Had a similar issue on my Toyota GT86, 2013 EU. I was getting P0017 and P0019 when checking for error codes. Usually CEL showed up on a faster drive up a mountan pass but wasn't reproducable on each drive. Took it to a dealer where they suggested a ECU rom update (had calid 700G installed is an older version). For some reason the dealer wasn't able perform software update–long story short–I bought a Tactrix adapter and update ECU to A01G myself without any issues. No CEL, no rough idle since updating (~6 months).
How did you know which ECU rom to go with ?
irax is offline   Reply With Quote
Old 10-20-2021, 04:12 PM   #17
tadeon
Drives: Toyota GT86
I recommend starting here https://www.ft86club.com/forums/showthread.php?t=62332
Basically got a Tactrix cable and used Ecuflash to read rom from ECU.
tadeon is offline   Reply With Quote
MY15 Idle Dip and Misfires Tectoniic Software Tuning 18 10-08-2019 02:26 AM
Stalling at idle after startup (see logs) Eazy-V Software Tuning 18 04-15-2018 08:33 PM
OFT Stage 2 UEL Help. Rough Idle Stalling shellslinger Software Tuning 11 03-05-2017 10:33 AM
engine misfires on rough road PabloN Engine, Exhaust, Transmission 22 02-15-2017 02:40 PM
Stalling, Misfiring, poor idle.. Car is at Toyota, hopefully some results soon WTF Issues | Warranty | Recalls / TSB 12 06-14-2014 11:40 PM
