#5027 |
it happens... Also I would not try to daily drive these tires. Your really going to eat into the amount sessions you can run. If you need a full time tire IMO there are better and cheaper tires out there.
2013 Series 10 FRS #553
#5028 | |
Drives: 2020 Subaru BRZ PP
FWIW, my car is technically a daily, but I average around 250-300mi a month because my wife and I both WFH and we mostly take her Durango everywhere. |
#5029 |
Drives: 2016 Scion FRS
I've autocrossed several sets of RE71R's. It isn't uncommon for them to groove like that early on. It tends to even out as the tire wears more.
| The Following User Says Thank You to steverife For This Useful Post: | strat61caster (08-20-2021) |
#5030 |
Drives: None
Do people run the same pad compound front / rear on these cars, or is staggered the norm?
#5031 |
#5032 |
Drives: None
Thank you, I wasn't sure if there was anything specific that angered the electronics.
I'm coming from land of turbo Miata with R18/R12 on the big Trackspeed Engineering Wilwood front and Sport rears with a bias valve. E46 M3 ABS is currently going into it. I don't intend to track the BRZ a lot but I figured I should have a set of pads for the occasional event where I don't need to run the Miata for TT.
#5033 | |
Gloc pads are available for this platform, although based on your post, I suspect you'll find yourself wanting more. |
#5034 | |
Drives: None
Trying to keep it realistic when swapping between a competitive TT4 car versus a TT5 street car, but we both know how that goes.
#5035 |
Capacity. Based on your turbo Miata description, sounds like you're pretty quick, and will need the equipment to support your pace.
#5036 |
Drives: None
Thank you, sounds like I have some reading to do. I appreciate it!
#5037 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | RedReplicant (08-23-2021) |
#5038 | |
At the track
Drives: '14 FRS - Former e92 M3
If you're going to track it, even a little bit, the BBK may be worth it if you're used to running a TT4 miata. On the stock brakes on these cars, depending on the track, you can eat up a set of pads in 2-3 weekends. If autocross only and occasional track use, get a compound you like and keep the calipers stock and you'll probably be fine for a while unless you decide that bolting 245 R7's on the car is fun (it is) and that you want to run TT5 some lol |
#5039 | |
Drives: None
The Miata is the competitive car, but I still want to be able to take this thing out to a few casual events a year. I'm leaning towards buying a set of F/R pads and sticking to places like Chuckwalla that don't eat brakes (just tires).
#5040 | |
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Considering a tire change...
I do about 6 HPDE's a year, just for fun, and run stock power levels.
I have TRD lowering springs and Pedders offset tophats so I am just about -2 camber all the way around. I currently run Pilot 4s tires (225/45/17), however I find them a little slippery as my times have improved... I am looking for recommendations on a compromise tire for dual use... is there something better than the 4s? Price does not matter much, however I don't want to be buying new tires every year if I am only street driving under 5000 miles/year... Is it practical/reasonable to street a 200 treadwear tire in a warm, dry climate (e.g. San Diego)?
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 10:54 AM |
