Old 08-16-2021, 11:33 AM   #15
Originally Posted by Skot View Post
I just went through the same thing. The $439 glass is probably not OEM Subaru glass. I ended up requesting OEM from Safelite and using my insurance. It was something like $850 for the OEM glass.
Why OEM glass? Is it made from something special somehow? Primarily just curious since I'm of the "whatever is cheaper" variety.
Old 08-16-2021, 12:07 PM   #16
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Not sure if it has anything to do with being OEM glass or not, but anecdotally...
Our '93 325i had the original windshield for it's entire life and it didn't start to get that "sandblasted" look, especially noticed on misty nights in oncoming headlights, until it was over 200K miles.
Our '88 SL560 had what I believe was the original windshield when we bought it with 86k on it. It was badly fogged, i.e., the protective film layers had failed somehow, and it was very scary to drive at night; oncoming headlights pretty much blinded you from all the glare. We replaced the windshield at a typical windshield vendor, maybe safelite. Don't remember. 50k miles later, it's already showing some sandblasting symptoms.
The '13 FRS w/ 93K miles on it, original windshield, is currently in better shape than the SL's 50K windshield, and slightly better shape then the 220K windshield on the 325i, but does have some grit wear visible. Whether it's relative longevity compared to the SL's cheap replacement windshield is due to OEM glass or not, I have no idea. Anyone?
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
The Following User Says Thank You to MuseChaser For This Useful Post:
Dadhawk (08-16-2021)
Old 08-16-2021, 12:32 PM   #17
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Getting a used front window will be a crapshoot.
Mine has micro pitting all over. I wouldn't want to have it replaced with one that has worse.
I'd much prefer a minty fresh one.
marky (08-17-2021)
Old 08-16-2021, 03:42 PM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
It's at least made to oem specs. Aftermarket is like everything else- it's cheaper because they don't need to maintain much of any standard. In this case, the fit could be a little off, or the hardness could be lower. Or any special coatings might be more thinly applied.
I went down the aftermarket part hole once on a previous car. The fit was horrific(huge gaps everywhere), and that was after the high end body shop spent a full day making it better than it was out of the box... It was like stretching a thong over a gorilla ass. Move it one way to fix this seam, and the other side opens up too far...
Old 08-16-2021, 04:12 PM   #19
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
And no, I don't want to know how you arrived at this conclusion.
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
soundman98 (08-17-2021)
Old 08-17-2021, 09:13 PM   #20
Skot
Skot's Avatar
Drives: 2016 BRZ
Originally Posted by marky View Post
yeah my local subaru has new oem for like 680 and said a rubber seal gasket was like 80.... so your total was about 850 installed with safelite?
ill have my neighbor install mine ill buy it from subaru and pick it up
Yeah it was something like that. The insurance said they'd cover it regardless of what glass I selected. I just had to special order it from Satellite.
I replaced my Forester glass with aftermarket and I wasn't really happy with it. The fitment looked odd and it seems to be missing some sort of anti fog treatment or something. The inside gets dirty so quickly. Just didn't want to take that chance this go around.
Skot is offline   Reply With Quote
The Following 2 Users Say Thank You to Skot For This Useful Post:
Dadhawk (08-17-2021), marky (08-17-2021)
Old 08-17-2021, 10:39 PM   #21
marky
marky's Avatar
Drives: 2020 BRZ tS #54
im looking at getting OEM ... did you have to order any other seals ? or just the windshield ? im looking a the parts number and theres other seal parts ...i think they will need to be replaced also as the rubber glue sealant is likely caked on the rubber seals and cant use that anymore
Old 08-18-2021, 12:04 AM   #22
Skot
Skot's Avatar
Drives: 2016 BRZ
Honestly I let Safelite handle it all but it looks like new seals were needed for the install.
The Following User Says Thank You to Skot For This Useful Post:
marky (08-18-2021)
Old 08-21-2021, 06:55 PM   #23
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
OEM glass is a better quality than the China glass your replacement will be. I went through this twice. China glass will have a weird fishbowl effect too.
It's not exactly a seal, it's just a dam for the sealant used.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
Dadhawk (08-22-2021)
Old 08-28-2021, 04:37 AM   #24
saltywetman
Drives: 2020 Toyota 86 GT 6M
with how expensive oem glass replacement is, has anyone looked into the new windshield protective film they have out nowadays? it's pretty pricey but should help protect against anything smaller than a larger pebble kicked up from a truck.
saltywetman is offline   Reply With Quote
Old 11-10-2022, 02:39 PM   #25
davenunez
Drives: BMW
I had also faced the same issue recently. I am checking with my insurance company and hopefully I don't have to pay from my own pocket.
davenunez is offline   Reply With Quote
Old 11-10-2022, 02:59 PM   #26
Where is your link?
x808drifter (11-11-2022)
Old 11-10-2022, 03:36 PM   #27
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
See if you can get the OEM glass cheaper...$644 is the MSRP, dealers cost is $386.50
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 11-10-2022, 07:34 PM   #28
There is a 98.86% probability that Daven is just a bot or spammer.
Windshield Replacement Wyattkb Arizona 17 04-23-2016 01:01 AM
Windshield replacement in GTA f0rge CANADA 10 07-04-2014 11:17 AM
Windshield Replacement? 2pt5RS Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 19 01-26-2014 08:34 PM
Windshield Replacement shellslinger Southern California 7 07-26-2013 01:48 AM
windshield replacement ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 28 02-17-2013 04:08 AM
