#85 |
Drives: 2015 BRZ Turbo (K-Swap soon)
When you get a chance, could you explain (or show) where your oil&water lines for the turbo will be going? Reading through your earlier posts you said "The K20Z3 water pump and housing will be used to supply the coolant feed line for the turbo." I thought that the barb on the front of the water pump was for the oil cooing on the stock engine. Maybe I'm misunderstanding or there is another line that I'm not seeing.
Thanks for the help! |
#86 | |
Drives: Q5 + BRZ + M796
The K20A2 or k20Z3 has a port on the water pump for the supply. The return goes into the block near the oil pressure sensor as pictured. The feed line will go to the low side of the turbo, which will be clocked at 20 degrees, and the return will leave the high side of the turbo. This is designed to create a thermal siphoning effect when the car stops to cool the turbo down. If someone was dead set on using the stock oil cooler then they could run the feed to the cooler, and then run the oil cooler return to the turbo as the feed to the turbo, and then run the turbo return back to the block. This will cool the turbo less effectively, but it should still do something. The alternative is to run the feed directly to the cooler, and then run the turbo return into the oil cooler, and then out, but the turbo will heat the water so much that the oil cooler will be far less effective. In the other way, the differential in temps is so high, warmed water from the oil cooler is probably still no where near hot enough to ruin the cooling effect. Clear?
#87 | |
BoostedBRZ
Drives: Turbo BRZ
#88 |
poor man's evora
Drives: Turbod BRZ
nice progress!
| The Following User Says Thank You to malubawla For This Useful Post: | Irace86.2.0 (08-16-2021) |
#89 |
Black Market Fab. Name of each part is in the build list on the first page.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | pgranberg11 (08-16-2021) |
#90 |
BoostedBRZ
Drives: Turbo BRZ
apologies, missed the 1st page since i just went to recents. appreciate the pointing me in the right direction!
| The Following User Says Thank You to pgranberg11 For This Useful Post: | Irace86.2.0 (08-16-2021) |
#91 | |
Water line from K20A2/Z3 water pump --> Turbo Water Feed Water line from Turbo back to block --> Turbo Water Return Oil line from Jackson Racing Oil Cooler --> Turbo Oil Feed Oil line from Turbo back to Greddy Sandwich plate --> Turbo Oil Return |
#92 | |
#93 | |
| The Following User Says Thank You to BWS_86 For This Useful Post: | Irace86.2.0 (08-17-2021) |
#94 |
I just finished the first week of nursing school.
At this point I am waiting for KPower. I have a crash bar coming in sometime next week hopefully. I’ll finish making brackets for the FMIC to the crash bar, and maybe use the crash bar to mount the horn, and then paint it, but free time is very scarce working in the ER full time and doing school. When I get the kit I’ll finish ordering the AN lines; the rest of the order is in the cart, and then I’ll buy the rest of the downpipe and the IC pipes.
#95 |
Drives: 2007 Mazda 3, New Raven FR-S 6mt
Good build man, i am going the same route just waiting for kpower kit. My engine is 130k miles and really dont want to FI to have blow up fast, also used engines are going for 2k still
| The Following User Says Thank You to Carlysh For This Useful Post: | Irace86.2.0 (08-25-2021) |
#96 |
So I haven’t had the best luck with getting items, having delays and shipping issues with receiving and with some items I’ve sold—pandemic problems. Specifically recently, I haven’t had the best luck with this drift bar. First, I end up waiting 2.5 months only to get a refund from Drift Armor when a delivery date couldn’t materialize. Then True Focus Fab comes through, saying they will ship in a week, and they do. In fact, they may have done FEDEX Express or next day because the label was created Friday, the package was picked up Friday night, and it said Sunday it would be here with a Monday delivery, but it never came. Tuesday it was found in Oregon from Montana saying the label was damaged and subsequently replaced, and it would then be delivered Wednesday, today, but that didn’t happen. No fault of True Focus Fab at all, but now it says delivery date unknown. I’m hoping for Friday. My wife says I wasn’t meant to have a drift bar.
#97 | |
Drives: 2018 Subaru BRZ
True Focus are awesome. I had the same issue with FEDEX and their delays or not updating the shipping info at all. Enjoy your Fruit snacks from True Focus because they send you some goodies with every purchase. Saving up for a front bash bar.
| The Following User Says Thank You to spcmafia For This Useful Post: | Irace86.2.0 (08-26-2021) |
#98 |
Drives: Crapcan
Fedex Sucks. Don't get me started on those clowns.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Irace86.2.0 (08-26-2021) |
| Tags |
| worst.build.ever. |
| KPower Industries K24 swap | PulsarBeeerz | Engine Swaps | 1801 | 04-15-2025 12:54 PM |
| Irace86.2.0 Build | Irace86.2.0 | Member's Car Journals | 195 | 03-25-2024 01:29 AM |
| Turbo or swap | Fastend | Forced Induction | 35 | 06-11-2020 08:12 PM |
| Built Turbo K24 Swap? | Calmwhiteguy | Engine Swaps | 31 | 02-13-2018 06:07 PM |
| IRACE86's Build | Irace86 | Member's Car Journals | 25 | 01-10-2017 05:35 PM |
