| Software Tuning Discuss all software tuning topics. |
#15 | |
Drives: Crapcan
#16 |
#17 | |
Drives: 2022 MT Neptune GR86 Prem.
So do you think running occasional tanks of petrol will help that? What about occasional off-the-shelf additives? Or is the solution just to change your injectors after a certain period of time (and get advantages of higher flow aftermarket injectors at that time). |
#18 | |
Drives: GEN-1-86-MT-FI / 2022 KTM RC 390
Or is the best course of action to get a flex fuel kit and upgrade fuel pump and injectors? |
#19 | |
Drives: Crapcan
No need to upgrade fuel pump or injectors unless you are FI. I am running all stock fuel system.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Dzmitry (08-16-2021) |
#20 |
I plan to get a FF kit. But I just wanted to feel the difference in power with E85 now haha
#21 |
Drives: 2017 BRZ Series. Yellow
Haven't seen anyone mention this but if your fuel pump starts to go and you go and do a pull and lean the motor out it could lead to a very large vent being added to your block. Likelihood of that happening is low and I wouldn't worry about it much but I did go ahead and add a fuel pressure safety switch that would yank timing and try to save the motor in the event of fuel pressure loss.
#22 | |
Drives: FT86
NA car unlikely on any fuel to go bang. also far less likely to be an issue on E85 due its much higher octane rating and knock resistance. Leanout manily issue with boosted cars and fuel pressure safety is good idea As previous ive run E85 full time for 8 years stock fuel system no issues no additives added to fuel. ive tuned countless cars to E85 only, our country we have guaranteed 85% ethanol at pump never varies , maybe out E85 better quality. Many tuners here tune E85 full time no flex many track cars as well , due to the availability of consistent pump E85 that always 85% lots of boosted cars as well. the only issues ive seen is people adding additives to E85 which i suspect were for petrol and it caused clogged fuel filters with a jelly like substance. |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | Capt Spaulding (08-17-2021), CincyJohn (08-17-2021) |
#23 | |
Drives: 2019
#24 | |
Drives: FT86
Occasionalky hpfp fails on petrol, we have a lot of people on e85 long term here no noticable increase in hpfp or any other tupe of failure on E85 86/brz I dont know about wrx dit, maybe as a single direct only fuel system it having to run very hard to supply the extra fuel ( maybe the dit tuners are increasing the di pump pressure targets )where as our cars with port and direct systems it not pushed as hard but thars just wild guess. |
#25 |
e85 "rotation" necessary ...
I’ve got about 3 years on E85 exclusively. The only time I would consider swapping is if you go long periods without out driving the car. For example I wouldn’t put my car away for the winter with E85 in it due to the way it collects water.
| FS: TRD "D oval" exhaust, OEM engine mounts, "STi" Radiator Cap cover | Dave-ROR | Engine, Exhaust, Bolt-Ons | 1 | 05-18-2020 04:34 PM |
| FS: Avant Garde M310 Matte Black 18" x 9" and 18" x 8" w/ Michelin Pilot Super Sports | NvSnickers | Wheels and Tires | 2 | 04-04-2017 11:30 PM |
| "Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 03:30 PM |
| "My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) — General Topics | 48 | 08-09-2013 07:34 PM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 06:23 PM |
