Old 08-07-2021, 09:30 AM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Suspect starter gone
Or maybe I hope so, compared to what else it could be. Horn honks with headlights on, indicating battery is OK. A couple times in the past week it has been slow to start. Both times I charged battery and it was OK, but now the starter makes a couple bleats but doesn't turn it over. Since I apparently have a fully charged battery now, I think I can rule out a parasitic drain. Boy I hate those. I'm just hoping there's a starter in the country somewhere.
Qwimby1 is offline   Reply With Quote
Old 08-07-2021, 11:48 AM   #2
WNDSRFR
Drives: FR-S,GTI
The horn honking with the headlights on DOES NOT indicate the battery is good. It takes a whole lot more current to turn the starter. Before you run out and buy a starter, at least try to jump the battery first. If that doesn't work, check all the connections. Especially the grounds.
The Following 2 Users Say Thank You to WNDSRFR For This Useful Post:
humfrz (08-09-2021), Qwimby1 (08-07-2021)
Old 08-07-2021, 12:04 PM   #3
Grady
Grady's Avatar
Check voltage of battery when you try to start it. If the voltage stays stable(10v or more) it could be the starter. If not then could be the battery.
The Following User Says Thank You to Grady For This Useful Post:
Old 08-07-2021, 12:41 PM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Agreed. It’s a guessing game trying to diagnose vehicle issues without the proper tools. Invest in a decent quality multi-meter and jumper pack and try again.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
Old 08-07-2021, 01:25 PM   #5
Qwimby1
Thanks for the good advice from everyone. I'll take another look at it.
Old 08-07-2021, 02:22 PM   #6
Qwimby1
I have a couple multi meters, but I'm pretty sure it's the battery now anyway. I charged it yesterday but it wouldn't go this morning. I just put a brief fast charge on it and it started. I was fooled originally because I took it to Goodyear a few days ago hoping for a load test, but they don't do those. All they found was that it was fully charged, and that's because I had it on a slow charge overnight.
Goodyear has a battery I can get today. Thanks again to everyone. This forum is a great resource.
The Following User Says Thank You to Qwimby1 For This Useful Post:
theneptune86 (08-16-2021)
Old 08-07-2021, 05:11 PM   #7
Qwimby1
New battery is in.
Old 08-08-2021, 12:35 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
now to the elephant in the room.
why is your battery constantly draining down?
batteries don't just go dead.
Old 08-08-2021, 01:20 PM   #9
WNDSRFR
Drives: FR-S,GTI
Batteries certainly do go dead.
It takes usually at least a couple years. But, then they just go dead.
Used to be they would slowly die. But lately it seems like they're good one day and dead the next.
If you know of a battery that doesn't go dead, I want one. I'll pay extra for it. Here in Florida my battery usually lasts for about two to three years. Then it just goes dead. Just like that.
humfrz (08-09-2021), Ultramaroon (08-08-2021)
Old 08-08-2021, 03:39 PM   #10
soundman98
soundman98's Avatar
ah, i misread the first post that he had replaced the battery twice, and it still wasn't starting correctly.
Old 08-08-2021, 04:37 PM   #11
Monitoring electrolyte levels? That seems awfully quick.
Old 08-08-2021, 05:26 PM   #12
Qwimby1
To clarify, the battery I just replaced was 3 years and 3 months old. The problems started about 3 weeks ago when I left the trunk cracked open overnight and had a dead battery the next day. I put an off-and-on slow charge on it and it worked fine for the next few days. My charger doesn't have an automatic cutoff so I didn't want to leave it charging overnight. It seemed OK, but would sound a bit weak at times, until it wouldn't start one morning again. I put a slow charge on it all day and took it to Goodyear the next day hoping for a load test, but they don't do those. All they gave me was a fully-charged report and said the battery was good. After sitting unused in the garage for two days, it wouldn't start again. That's when I suspected a starter. You guys got me straightened out on that. I gave it a quick fast charge, started it and drove to get a new battery yesterday. It started fine this morning.
My automatic test has always been to honk the horn with headlights on, but you guys got me straightened out on that too. I tend to drive cars for a long time, and thus don't keep up on new developments. My previous two Miatas I drove for about 10 years each.
I haven't done any instructing for about 8 years due to business stuff, so I realize I'm going to have to get current on a lot of developments so I can answer student's questions. I'm hoping to have the FRS track ready by fall when it gets cool enough here. I'll be hitting the books in the meantime as well.
humfrz (08-09-2021)
Old 08-08-2021, 08:00 PM   #13
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Always remember that once you drain a lead-acid battery down completely, permanent damage is done to it and the battery will never be the same as it was before. And newer batteries are not of the same quality as older ones. It seems that they are all built cheaply now versus how they were 20 or even 10 years ago.
Old 08-09-2021, 02:45 AM   #14
It's Florida - what can I say -
soundman98 (08-09-2021)
starter motor gcranston Engine, Exhaust, Bolt-Ons 5 03-24-2022 11:42 AM
Remote starter on frs? Brianbajnauth Scion FR-S / Toyota 86 GT86 General Forum 2 01-09-2014 07:31 PM
ONR Starter Kits u/Josh Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-05-2013 12:47 PM
Considering a FRS as a starter car for auto-x. MR_X Tracking / Autocross / HPDE / Drifting 48 08-16-2013 03:52 PM
self-starter jarviz Engine, Exhaust, Transmission 16 09-15-2012 12:45 AM
