Old 07-07-2021, 04:12 PM   #323
ozafar
Drives: 2015 Scion FRS Release Series 1.0
It really does look amazing. But aren't you worried about suspension travel? A good handling setup needs a few inches of suspension travel to corner properly. I may be mistaken, but it looks like the rear wheels have very little room to move up before hitting the bodywork.
Omer
ozafar is offline   Reply With Quote
Old 07-07-2021, 10:15 PM   #324
DIY
DIY's Avatar
Drives: BRZ, WRX
Omer
Thank you.
The current bodywork is only temporary, I will be making new panels from composite material (fiberglass or carbon).
The first step is getting the car sitting at the proposed lowest ride height which meant cutting away some metal since the car is now so low and the wheels are very big.
After this I will be re-shaping the body into something I can take moulds from.
Lay up the composites in the moulds to make the new panels, cut away old panels and install new panels.
That's the current plan.
Follow me on Instagram: @brzdiy
My Build Thread
DIY is offline   Reply With Quote
The Following User Says Thank You to DIY For This Useful Post:
Dzmitry (07-08-2021)
Old 07-08-2021, 06:27 AM   #325
DIY
DIY's Avatar
Drives: BRZ, WRX
I have been working on the front end, trying to make the panels fit over the new wheels by trimming away metal and plastic from the front fenders and bumper.
This photo shows how low the car is and also that I have extended the wheelbase by 35mm by moving the front wheels forward.
After some trimming I could get the panels back on, you can see I need to remake the panels with a new shape.
I also had to seek some clarification on the rules as one section said I could cut away any metal necessary for bump clearance and another section said I could only make changes to the shock towers solely for suspension geometry changes.
After getting the go-ahead from the technical director I did the minimum amount of trimming to the strut towers so the tyres would no longer make contact.
I have also been trimming away some metal around the wheel wells to help with air evacuation, I post some photos of that once its done.
My Build Thread
The Following 7 Users Say Thank You to DIY For This Useful Post:
Ash_89 (07-17-2021), Dzmitry (07-08-2021), Irace86.2.0 (08-24-2021), NoHaveMSG (07-08-2021), RToyo86 (07-21-2021), sid_g (07-08-2021), tintumz22 (07-08-2021)
Old 07-17-2021, 05:44 AM   #326
DIY
DIY's Avatar
Drives: BRZ, WRX
I've been in lockdown the past few weeks and it probably won't end any time soon. Luckily this has given me plenty of extra time working on the car.
Most of the work has been around getting all the front end panels mounted onto the car. I bought some 16mm x 1.2mm 4130 chromoly tube and a very cheap manual bender from ebay. The bender snapped during the first bend but I was able to modify it to mount in my vice and now it works surprisingly well.
The tube structure I'm building is very light and will be removable by taking out several bolts. First step was to make a rear mount on the chassis.
This is how all that turned out, one on each side.
Then it was just a matter of bending some tube and making some tabs to hold the fenders in place.
The whole thing is rather basic but it is surprisingly sturdy.
This is it after finishing both fender mounts. More tube which I have already bent up will continue around the front and attach to the top of the bumper. I have left that bit off for now and started work on the main reinforcements to the front chassis rails.
My Build Thread
The Following 14 Users Say Thank You to DIY For This Useful Post:
Arthur-A (07-20-2021), Ash_89 (07-17-2021), Busybee (07-24-2021), Dzmitry (07-20-2021), flippy (10-29-2021), Irace86.2.0 (08-24-2021), J95 (10-07-2021), Jdmjunkie (07-18-2021), jflogerzi (07-18-2021), Kaleb765 (07-20-2021), Lonewolf (07-21-2021), MotoX16 (10-27-2021), RedReplicant (09-17-2022), RToyo86 (07-21-2021)
Old 07-20-2021, 11:31 PM   #327
Kaleb765
Kaleb765's Avatar
Drives: 2015 Scion FR-S Raven Black
Just so you know, your build thread is the only reason I check this forum any more amazing car, can’t wait to see the end result!
Kaleb765 is offline   Reply With Quote
The Following 2 Users Say Thank You to Kaleb765 For This Useful Post:
DIY (07-21-2021), MemphisR (07-21-2021)
Old 07-21-2021, 06:25 AM   #328
DIY
DIY's Avatar
Drives: BRZ, WRX
Thanks mate
My Build Thread
Kaleb765 (07-21-2021)
Old 07-21-2021, 06:27 AM   #329
DIY
DIY's Avatar
Drives: BRZ, WRX
I was playing around with the bodywork today, nothing serious, just kicking around some ideas.
My Build Thread
The Following 4 Users Say Thank You to DIY For This Useful Post:
Ash_89 (07-27-2021), Code Monkey (07-31-2021), Dzmitry (07-21-2021), Irace86.2.0 (08-24-2021)
Old 07-21-2021, 06:43 PM   #330
Lonewolf
Lonewolf's Avatar
Drives: Moped
I want to see this car completed so badly!
Old 07-24-2021, 05:25 AM   #331
DIY
DIY's Avatar
Drives: BRZ, WRX
Work has begun on bringing the strength back into the front end, much more to come.
https://www.instagram.com/p/CRs-gwPH...dium=copy_link
My Build Thread
Code Monkey (07-30-2021)
Old 07-30-2021, 06:30 PM   #332
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Excellent progress, this is really taking shape!
- WORKS Team
WORKS is offline   Reply With Quote
Old 07-30-2021, 10:45 PM   #333
jflogerzi
jflogerzi's Avatar
When your done I would like you to build me one all in seriousness this one if my favorite builds on the boards
2013 Series 10 FRS #553
Old 07-31-2021, 04:48 AM   #334
DIY
DIY's Avatar
Drives: BRZ, WRX
Thank you guys!
Here is a little update on the work I'm doing to stiffen up the front end, it's really coming together now!
What I've done is bring tubes from the roll cage into the engine bay in a triangulated 3d structure that should prevent flex in any direction.
You can see the tubes are coming from the top and bottom of the A-pillar and then coming back to an additional mounting point in the center of the transmission tunnel.
close up of the notched junction
There will be another brace across the front of the engine but first I am going to take the engine back out and weld everything I've done so far. I also need to make a bracket and mount the dry sump oil pump to the engine to make sure there will be no clearance issues with the brace at the front.
My Build Thread
The Following 6 Users Say Thank You to DIY For This Useful Post:
Ash_89 (08-02-2021), Code Monkey (07-31-2021), Dzmitry (08-05-2021), Irace86.2.0 (08-24-2021), Jdmjunkie (07-31-2021), RToyo86 (07-31-2021)
Old 08-03-2021, 10:31 PM   #335
DIY
DIY's Avatar
Drives: BRZ, WRX
New video showing the progress with the front end
https://www.instagram.com/p/CSGkeSdH6E0/
My Build Thread
The Following 3 Users Say Thank You to DIY For This Useful Post:
Busybee (08-04-2021), Dzmitry (08-05-2021), RToyo86 (08-03-2021)
Old 08-12-2021, 11:54 PM   #336
DIY
DIY's Avatar
Drives: BRZ, WRX
Big Update
Lots of work has been happening but I've had trouble getting the photos to upload to Imgur off my phone so this update is a bit overdue.
The final pieces in the puzzle went in to the front end. These short lengths of tube join the new structure to the frame rails.
With that work done I needed to get my dry sump oil pump mounted onto the engine so that I could finish the bracing across the engine bay without any potential clearance issues.
If you recall I bought the dry sump not as a kit so I have had to fabricate my own oil pan and mounting bracket for the oil pump, this saves lots of money.
I started with a piece of scrap 6mm steel plate.
The alignment of the oil pump to the crank pulley is critical and there is a specific distance between the pulleys.
I used different clamps to the one in the photo above, a large square and lots of measuring before getting the final position. Once I was happy I used transfer punches to mark the holes out for drilling.
The final product had some attempt to reduce weight with a step drill and carbide burs.
The end result was spot on. Below you can see me test fitting some of my accessories before returning the engine to the car.
Of special note is the starter motor which was specifically designed for the Honda K-series by Carwood Brise. Compared to the OEM starter it is twice as powerful, 25% lighter and more compact. As an added bonus I was able to mount it with my BMW ZF320 5-speed without modification to the transmission as this starter runs a twin nose bearing design which means there is no large snout over the cog that would normally foul on a RWD trans configuration.
https://brise.co.uk/honda-k-series.html
I got the engine back into the car and everything fits perfect, no clearance issues.
The steering rack is close but that's how I designed it.
So that's where I'm up to for now.
My electric water pump arrived yesterday so I will be looking at places to mount that. I am going to start building the final brace across the engine bay which incorporates extra bracing for the steering rack.
I still need to order a turbo but I'm having trouble deciding which one to get. Turbo and steering column/shaft are the next two things that need to be ticked off as they both occupy the same space. Also the radiator/intercooler needs doing.
My Build Thread
The Following 8 Users Say Thank You to DIY For This Useful Post:
Ash_89 (08-13-2021), Busybee (08-12-2021), Code Monkey (08-13-2021), Dzmitry (08-13-2021), Irace86.2.0 (08-24-2021), Jdmjunkie (08-13-2021), RToyo86 (09-08-2021), Thefalls (08-13-2021)
