, dpfarr
Old 07-30-2021, 07:12 PM   #4187
Hades
Hades's Avatar
Drives: 2013 Scion FRS
I'm considering finally pulling a trigger on a SC kit and this or JRSC is high on the list. A few questions about this one:
1) It seems the jackson racing dual radiator/oil cooler works with this - do I need a specific bracket or something? I currently have the N/A version installed
2) What supporting mods need to be done for 240-280whp to be track reliable? I'm more concerned with reliability here than power (but more would be nice of course) - I'm a little worried the high torque output of the PD supercharger is going to be more harsh on the engine/trans but I haven't heard much issues (outside e85 high boost)? Are temps a concern compared to something like JRSC - I know <240 oil temps seem to be the sweet spot for long term reliability; is that achievable here (or even with the rotrex unit for that matter)?
3) Seems like a lot of issues with CARB tune, is the consensus just to skip that and get the TIY kit?
Hades is offline   Reply With Quote
Old 07-30-2021, 07:40 PM   #4188
Hades
Hades's Avatar
Originally Posted by Nitro22
Initially, the natural idea was to relocate the cooler forward and below the crash beam to make room for the LTR. Reference Post Although this method is not completely unorthodox, the obstruction the oil cooler has become for the Edelbrock LTR is more substantial than expected. In cruising conditions, I was logging almost 40°F higher Intake Air Temperature (IAT) than ambient. Highest peak IAT during autocrossing in 82°F ambient was 153°F. This was costing me ignition timing and ultimately power.
Hmm does the JR dual radiator/oil cooler suffer from this same issue? I would think that wouldn't be the case since the JR dual replaces the radiator, but idk.
Old 07-30-2021, 07:45 PM   #4189
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Originally Posted by FrickingReallySlow View Post
https://www.jegs.com/i/Edelbrock/350/51-0157/10002/-1
Here ya go. But you should be able to buy just the cleaner from KN (not the oil spray) and clean your old one too. This one is kinda pricy
Ordered the dry filter from Jegs. Apparently it’s back-ordered due to supplier issues and should ship mid August.
Fine with me as I have yet to install my used kit yet. A fall project after track season.
Should I go with CSG or Delicious for my tune?
Muskoka800 is offline   Reply With Quote
Old 07-30-2021, 07:52 PM   #4190
Hades
Hades's Avatar
Personally I would avoid Delicious, I think CSG has their old tuner on their staff now FYI.
Old 07-30-2021, 08:11 PM   #4191
Auto_egr
Drives: 2017 CWP BRZ w/PP
CSG 100%. Zach is incredibly talented and has very safe base tunes. He also knows the failure points of this engine and ramps in boost/timing slowly to preserve it.
Auto_egr is offline   Reply With Quote
The Following User Says Thank You to Auto_egr For This Useful Post:
B T (08-02-2021)
Old 08-01-2021, 04:11 AM   #4192
FrickingReallySlow
Drives: 2015 FR-S
Do you guys know when Zach left delicious? I got v31.53 of the edelbrock tune from delicious in August 2020 and I’m wondering if it was tuned by him and has these safeguards. Also what do you guys mostly see as the performance differences between Delicious / HRI / CSG
FrickingReallySlow is online now   Reply With Quote
Old 08-01-2021, 07:29 PM   #4193
haohmaru
Drives: Red 2024 GR86 Trueno
Originally Posted by aKaGorganZola View Post
When i installed the grimmspeed cold air i ran into the same issue. I knew I was going FI eventually so I definitely wasn't not having the cooler so I went ahead and just ran the snorkel for a few days while I cut up the box.
I tig welded a cut out in the back side to clear the fittings and then painted it blank to match. Of course I just sold it so unfortunately I don't have any pictures of it but in total it only took me like 4hrs to fab it up and I'm not anything special when it comes to that.
I've already got the Grimmspeed CAI, so it's possible fit it to the supercharger?
haohmaru is offline   Reply With Quote
Old 08-02-2021, 11:31 AM   #4194
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Zach tunes for CSG now, I'd suggest contacting him there. He moved fairly shortly after your august 2020 tune. He has also made revisions to his base files in just the past couple of months.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
FrickingReallySlow (08-02-2021)
Old 08-02-2021, 05:00 PM   #4195
CSG Mike
CSG Mike's Avatar
Zach left DT in 2019, and is an equity partner at CSG
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
B T (08-02-2021), BrahmaBull1990 (08-02-2021), FrickingReallySlow (08-02-2021), sato (08-02-2021)
Old 08-02-2021, 09:21 PM   #4196
Calum
That Guy
Drives: 2013 asphalt FRS MT
The owner of Delicious was the tuner originally and still is from what I understand. I had tunes from DT before and after Zach joined them and had no complaints about either and would have no trouble going back to DT now.
I have no iron in this fire, and no educationed opinion of Zach's tunes. I'm just saying I've seen no reason to not use DT.
The Following User Says Thank You to Calum For This Useful Post:
Old 08-03-2021, 12:23 AM   #4197
Hurricane Nate
Drives: 2020 BRZ (Black)
I have the JR DROC, no special bracket required. Fits into the original location very nicely, no special mods required. My oil temps are never over 250, even when I flog the engine for extended periods. I have the CSG tune by Zack on my E-force SC, easily making around 280whp with no other mods on the engine besides the SC and DROC. It’s so smooth, and the graduated pedal feel that Zack provides really suits my daily driving habits.
Hurricane Nate is offline   Reply With Quote
The Following User Says Thank You to Hurricane Nate For This Useful Post:
Hades (08-03-2021)
Old 08-05-2021, 11:58 AM   #4198
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
I don't think so. At least it's not recommended from what I've read on here. I ran the cai when I was na bit I'm using the supplied intake from the kit.
aKaGorganZola is offline   Reply With Quote
Old 08-05-2021, 01:20 PM   #4199
Muskoka800
FedEx delivered the filter today. Really not much of a delay considering it had to clear customs as well. Thanks Jegs!
Old 08-05-2021, 01:37 PM   #4200
B T
The filter setup from edelbrock looks a bit ridiculous to me. Giant filter with a small opening letting air into it. I realize it reduces pressure drop, but does that small opening not limit the pressure to begin with?
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
