Old 07-26-2021, 09:32 AM   #1
halfwaytobedlam
Drives: 2014 Toyota 86 GTS
Melted brake pads after track day?
Hi all, had a track day over the weekend and saw that a hard, black substance that seems a little rubbery had formed on the brakes. Here are the details:
- The brake pads are Dixcel ES brake pads. I had not bedded them in and instead street drove with it for a couple months as the website suggested. Brake grease was placed on the pad surface contacting caliper.
- The track has lots of left turns and I braked from 170+ kmh to 80kmh on the first corner. I'm pretty new so i may have braked deep as I was turning
- The substance formed heavily on right front wheel, less on left front and none on rear
- Brakes were smoking lightly when i came into the pits
- Braking feel didn't change throughout the day as I continued lapping*. Car still tracked straight. I tried not to brake too hard and didn't observe any other substance buildup.
*after testing it in the skidpad
Trying to get an idea of what it might be before I send it to the mechanics to check it. Thanks in advance!
Attached are photos:
halfwaytobedlam is offline   Reply With Quote
Old 07-26-2021, 11:01 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
@halfwaytobedlam
I don't think that rubbery substance is brake pad. When pads melt, they smear onto your rotor and form marbling on the metal surface. Pads don't sling off like that; it's not possible (they aren't made of anything that would be rubbery)
If I had to guess, there are a few possible culprits:
  1. You picked up some rubber marbles from your own wheels, other cars, or the track
  2. Brake pad grease
  3. Caliper pin grease
EndlessAzure is offline   Reply With Quote
Old 07-27-2021, 01:59 AM   #3
psychore0
Drives: Lambofeetes
My guess without seeing anything else is axle grease.
psychore0 is offline   Reply With Quote
Old 07-27-2021, 08:40 AM   #4
halfwaytobedlam
i suppose if grease from whereever gets ejected like that its probably a bad thing isnt it... but can grease harden up like that?
Old 07-27-2021, 09:48 AM   #5
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
It does look like axle grease a bit, and axle grease is pretty thick. Still, I'm not sure how axle grease would get flung onto the outside facing part of the brake rotor.
I second EndlessAzure's theory of it being rubber from track marbles. Especially since you reported that braking performance didn't change/deteriorate.
Also what tires are you running?
Old 07-27-2021, 10:12 AM   #6
It is not grease. Grease at the temperatures reached would be runny and spread out on the rotor from rotation. No way it would be nice raised chunks.
It is rubber.
Ultramaroon (07-27-2021)
Old 07-27-2021, 10:17 AM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
100% not brake pad.
I had the same thing this last weekend. It was pieces of my fender liner.
Old 07-27-2021, 10:42 AM   #8
WolfpackS2k
It's worth mentioning that on my previous car (Cayman) the axle grease overheated and flung out all over the place during a track event. The boots were intact - no issues. But apparently Porsche doesn't use a high temp axle grease on their sports cars...
Either way, none of it was on the brakes/any rotating assembly.
Old 07-27-2021, 11:05 AM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
As somebody who has smoked about 5 front hubs, I can say I have never seen any grease come out of any of them.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Tcoat (07-27-2021), Ultramaroon (07-27-2021)
Old 07-28-2021, 10:58 AM   #10
halfwaytobedlam
100% not brake pad.
I think this may be it. my fender liners are pretty chewed up from the previous owner but I had a closer look on the inside and the hole was bigger and kind of melted. Seems theres a limit to how much zip ties can secure things
Thanks everyone for your input!
The Following 2 Users Say Thank You to halfwaytobedlam For This Useful Post:
NoHaveMSG (07-28-2021), Tcoat (07-28-2021)
Old 07-28-2021, 11:35 AM   #11
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
100% not brake pad.
Or pieces of other peoples fender liners and track boogers.
Do track owners have vacuum trucks, or are the renting orgs. responsible for cleaning up after themselves?
Old 07-28-2021, 01:03 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It depends on the track and event organizer but typically they have a sweeper and will clean the track off from time to time. Like before the start of the day, if someone has an off, maybe at lunch. OPR was a big issue for me last weekend, it was pretty bad and they cleared the track off a lot but there were about 80+ cars running for times so there where a lot of marbles off line.
Reco for brake pads for track use? ThaDonJsuan BRZ First-Gen (2012+) — General Topics 18 04-08-2021 03:33 PM
Brake Pads for track use ThaDonJsuan BRZ First-Gen (2012+) — General Topics 8 11-15-2020 05:35 PM
Brake Pads for Track/Street Use bumperhumper Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-17-2020 04:54 PM
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 03:31 PM
Brake pads for track days why Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-26-2013 07:42 PM
