Old 07-25-2021, 12:01 PM   #2843
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
So got my Ryzen 9 yesterday. Plugged her in and didn't get a post, so I figured I'd need to update the bios. Did that this morning and everything started out great, but once windows started to boot, it froze half way. I can get into the bios no problem, but it won't let me get into windows. I tried a slightly older bios file and same thing happened. Any thoughts? It's an MSI B550i btw.
MS, CSCS, TSAC-F, CPT
Old 07-25-2021, 12:09 PM   #2844
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Any PC Gamers Around?
Are you going from Zen2 to Zen3? You may need to update the bios with the Zen2 CPU installed.
Edit: unless the board has a bios flashback feature, then you can do it without a cpu at all.
Old 07-25-2021, 12:23 PM   #2845
weederr33
weederr33's Avatar
It's zen3 to zen3. Ryzen 5 to Ryzen 9. I did the bios flashback since the stock bios didn't post. But now it's giving me that wired freeze. Got into safe mode but that's not really useful for me.
The Following User Says Thank You to weederr33 For This Useful Post:
Yoshoobaroo (07-25-2021)
Old 07-25-2021, 12:32 PM   #2846
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If you can get into safe mode it's probably something that's auto loading at startup.
Turn everything off and see if it boots.
taskmanager>startup
and everything not MS in MSCONFIG
The Following User Says Thank You to x808drifter For This Useful Post:
weederr33 (07-25-2021)
Old 07-25-2021, 12:44 PM   #2847
soundman98
ProCrastinationConsultant
soundman98's Avatar
You're using a preconfigured copy of windows?
A processor change has always required reloading windows for me to get all the appropriate drivers/locations sorted out.
Spuds (07-25-2021)
Old 07-25-2021, 12:46 PM   #2848
weederr33
weederr33's Avatar
I've swapped MOBO and processors a couple times now with the same NVME with windows set up on it, and it's never done this before.
Old 07-25-2021, 12:50 PM   #2849
weederr33
weederr33's Avatar
Im wondering if doing the clear CMOS will help?
Spuds (07-25-2021)
Old 07-25-2021, 01:02 PM   #2850
jflogerzi
jflogerzi's Avatar
Yes should have been your first step
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 07-25-2021, 01:55 PM   #2851
cjd
cjd's Avatar
Drives: 2017 BRZ
Make sure there weren't bios changes - a flash nearly always resets it but try a clear anyway.
UEFI on/off for example, though I'm not sure you'd get safe mode if that were set wrong - haven't tried it though. That assumes you know how it used to be configured.
My bet if you were to swap back to the other CPU with no other changes is you'd still not boot.
The Following User Says Thank You to cjd For This Useful Post:
Old 07-25-2021, 02:24 PM   #2852
Yoshoobaroo
TRACKBREAD
I would clear CMOS and then load optimized defaults in the bios, see if that boots.
If that doesn’t work I would swap the old processor back in just to make sure that still boots. If it does at least you know it’s either a configuration problem or a hardware issue with the new processor.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Old 07-25-2021, 03:21 PM   #2853
weederr33
weederr33's Avatar
Ok, cleared CMOS with R9 still installed: fail
Swap R5 in: fail
Updated BIOS with R5 in: fail
So... at least I know it wasn't the expensive R9.
Damn you MSI!
I'll try a few other tips if anyone has anything, otherwise might revert back to an Asus B550i
Old 07-25-2021, 03:57 PM   #2854
cjd
cjd's Avatar
Drives: 2017 BRZ
Swap R5 in: fail
Damn you MSI!
It's bios a setting which was not the default and/or where the default changed, causing your OS issues. I'd take a look at UEFI on a whim, as I think that was not shipping as default for a long time, but recently has been. Do you know if your OS drive boot sector is GPT or MBR? Some settings depend on GPT. Could be >4gb access or something like that as well.
Old 07-25-2021, 04:01 PM   #2855
weederr33
weederr33's Avatar
Lol I know nothing of what you are saying. Until this past Christmas I'd never built a PC before.
Old 07-25-2021, 04:09 PM   #2856
Where in the process is it failing? Do you have any indication?
pc master race, u no have 3080
gamers lounge Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 25 01-21-2014 05:32 PM
GT Acadamy Gamers Banned from Britsh GT Pro-Am WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 16 02-11-2013 07:37 PM
