Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 07-23-2021, 02:31 PM   #43
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Originally Posted by Kona61 View Post
Well yes that's true, but standard equipment also seems much better for the new 86. So, for me I say the comparison would lie somewhere between the old base and old limited. Regardless, the pricepoint is very reasonable to me.
Actually I'd suggest the BRZ is slightly higher spec.
The interior door handles are shinier (legit actually they are better).
Blighty is offline   Reply With Quote
Old 07-23-2021, 02:46 PM   #44
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
Originally Posted by ToySub1946 View Post
What about Brembos and Sachs ?
And no fuel economy figures so far ?
Is the brake booster being electric a similar design as Ford's idea for the Bronco Sport ?
See: 16mins, 34 sec above.
No. I did look on the pictures of the engine bay and the Brake Booster + Master cylinder combo is still there.
An eBooster is a totally different layout (which can integrate even the ABS/ESC module on it), with a brake by wire system (plus push rod for safety reasons)
Stonehorsw is offline   Reply With Quote
The Following User Says Thank You to Stonehorsw For This Useful Post:
ToySub1946 (07-24-2021)
Old 07-23-2021, 03:03 PM   #45
Blighty
Originally Posted by Sasquachulator View Post
If people can notice the torque dip in every speed condition, the 5hp increase, and any other butt dyno statistics, then they will notice 20kg difference EASY!!1
everyone's an internet vehicle R&D expert.
Well the car will feel lighter, actually.
Old 07-23-2021, 03:31 PM   #46
Blighty
Originally Posted by mazeroni View Post
If that's the case, then that partly explains the weight loss.
From https://www.ft86club.com/forums/showthread.php?t=7881
OEM spare tire with liner foam= 25.8 lbs.
OEM trunk tools, jack, tow hook= 5.8 lbs.
That is 31.6 lbs alone.
That explains why the increase is 30kg from the 86 (1240kg for the 17 inch wheel spec).
Old 07-23-2021, 03:33 PM   #47
Blighty
Originally Posted by GraysonGreene View Post
Hope they have an accessory subwoofer again! I love my Subaru Accessory 10" Kicker.
Also kinda miffed about the lack of the spare tire. I'd rather have a slightly heavier car and remove the spare at the track . I know barely anyone has to use their spare, however, when you loose a tire 100+ miles away from home and the tow bill is $100+ you'll be wishing you had that spare.
surprised they didnt increase the cargo space with the removal of the spare tire.
Typical of manufacturers though, they just fill the spare tire well with a foam block with tools and a fix-a-flat kit.
They may have well kept a slot for it. Last time they kept the wheel well and had the tools there with a cover over the top.
Old 07-23-2021, 05:04 PM   #48
HaltNCatchFire
Drives: Subaru WRX
Found a video (albeit in Japanese) where someone looks underneath the trunk floor cover in a GR86:
A little after 16:30, you can see they kept the wheel well space below. Personally, I would remove the foam insert and put in a donut/temporary space saver spare from the previous 86/BRZ.
HaltNCatchFire is offline   Reply With Quote
The Following User Says Thank You to HaltNCatchFire For This Useful Post:
Blighty (07-23-2021)
Old 07-23-2021, 07:50 PM   #49
mazeroni
Drives: 2013 Scion FR-S Series 10
Interesting. I suppose one could take it out of the current gen before trading it in. Easy swap.
mazeroni is offline   Reply With Quote
Old 07-23-2021, 08:07 PM   #50
Blighty
The good news is that you can do it yourself, because they have kept the depression.
The Following User Says Thank You to Blighty For This Useful Post:
timurrrr (07-23-2021)
Old 07-23-2021, 08:47 PM   #51
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
It will need a threaded location to secure it down with a typical bolt. You don't want a spare flying around in an accident.
trippinbillies40 is offline   Reply With Quote
Old 07-23-2021, 09:25 PM   #52
Am I missing something or can you only "reserve" a 2022 you can't build and price one? All I see under build and price is the 2020.
Old 07-23-2021, 10:42 PM   #53
trippinbillies40
Drives: '22 WRB
You can head to a Subaru retailer and tell them exactly what you want as far as color, trim, and port-installed accessories. They can put in a sold order for you. I'm sure Subaru.com will update in the next few days to allow you to build one, but likely waiting on accessory photos.
I have my order in already and have a VON.
The Following 3 Users Say Thank You to trippinbillies40 For This Useful Post:
Dadhawk (07-24-2021), DAEMANO (07-28-2021), timurrrr (07-24-2021)
Old 07-23-2021, 10:45 PM   #54
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I see what appears to be an amplifier on the OPPOSITE side now.
Or is that the CORRECT side on a right-hand drive or JDM model?
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
Yoshoobaroo (07-24-2021)
Old 07-24-2021, 01:54 AM   #55
PMok
Codename: Stitch
PMok's Avatar
this -- why is there no mention at all about Performance Package?
and what about Homelink and auto-dimming mirror packages?
Old 07-24-2021, 02:45 AM   #56
D1cker
Drives: B9 S4/ND2
There won't be a performance packge for a while. Gotta hold onto that for the mid cycle refresh.
Homelink/auto dim is a port installed accessory for about $350, I ordered my 22 with it yesterday
D1cker is offline   Reply With Quote
The Following User Says Thank You to D1cker For This Useful Post:
PMok (07-24-2021)
HKS Supercharger Power and Pricing Released! ZC6BRZ Forced Induction 128 05-29-2019 03:14 PM
**Echelon Autosports** AFE Takeda Air Intake .... Low Intro Pricing on all Pre-Orders Echelon Autosports Engine, Exhaust, Bolt-Ons 0 07-26-2012 01:58 PM
New Zealand BRZ Pricing released lazyluka AUSTRALIA 30 04-25-2012 06:54 AM
Canadian pricing released 25,990 Mather CANADA 1 03-31-2012 01:01 PM
