go_a_way1
Old 12-07-2020, 11:38 PM   #4999
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by staples323 View Post
Is there a rough ride height estimate for 2.2-2.5 degrees of rear camber on stock LCA's? Trying to not take the .5 hit in NASA TT5 for replacing control arms.
About an inch lower than stock. Whatever that is....
Old 06-15-2021, 04:58 PM   #5000
EB86
Drives: GT86
Is this a worth while addition to protect the inner joint from exhaust heat long term?
https://www.nengun.com/cusco/drive-shaft-heat-shield
EB86 is offline   Reply With Quote
The Following 2 Users Say Thank You to EB86 For This Useful Post:
Stonehorsw (07-21-2021), timurrrr (06-15-2021)
Old 06-15-2021, 07:34 PM   #5001
CSG Mike
CSG Mike's Avatar
Yes!
Old 06-16-2021, 08:23 AM   #5002
EB86
Drives: GT86
thanks
I did search but couldn't find many people talking about it, or complaining of inner CV joint failure due to grease heating next to the exhaust.
Old 07-12-2021, 04:46 PM   #5003
Kelse92
At the track
Drives: '14 FRS - Former e92 M3
Is there a factory OEM vehicle that runs the pad shape of the AP Sprint Kit? If so which ones? Looking around and not seeing much info other than posts saying that it's a readily available pad shape...
Kelse92 is offline   Reply With Quote
Old 07-13-2021, 02:14 PM   #5004
CSG Mike
CSG Mike's Avatar
There is not.
If you want a commonly used shape, check out the CSG spec Brembo BBKs. They share pad shapes with the factory PP Brembos, but are entirely different in caliper.
Note that the CSG spec Brembo BBKs were released before the 2017+ PP was even announced.
Old 07-13-2021, 02:24 PM   #5005
Kelse92
At the track
There is not.
Thanks, I found a cheap enough deal on a used AP Sprint kit and jumped on it already so that's what I have but was just trying to figure out how to cross-reference the pad shape. Took me longer than I'd like to spend digging but realized the pad cross-references with a Willwood pad that's more common so I got it squared away
I was going to try and find some 2017 PP Brembo's off a crashed car or something and take advantage of the Update/Backdate in the TT5 rules to get the big brakes without taking the penalty but it's too cost/time prohibitive so just opted to go with what I could find the best deal on.
Old 07-13-2021, 02:56 PM   #5006
CSG Mike
CSG Mike's Avatar
You have all the right resources immediately available to save you that time!
I believe C2's are available for the 8250 shape as well.
The car should be awesome in TT5.
Kelse92 (07-13-2021)
Old 07-21-2021, 11:38 AM   #5007
CallMeAl
Drives: 2015 FRS
I'm new to this and looking to do an event this weekend. I have a Bell motorcycle helmet with 'ECE 22.05' on the back. SCCA's rules state 'ECE R 22.05 certified helmets are also allowed' (mine does not have the R). As far as I can tell these are the same thing. Is my helmet compliant?
CallMeAl is offline   Reply With Quote
Old 07-22-2021, 09:08 PM   #5008
CSG Mike
CSG Mike's Avatar
They are not the same.
Do not use a Motorcycle helmet in a car.
Old 07-23-2021, 04:49 PM   #5009
3k1n
3k1n's Avatar
Drives: 2017 BRZ limited PP WRC Blue
Hi Mike, Question for you. I have a 2017 BRZ for which I plan to autocross 5-10x a year. I'm getting an alignment soon and plan to have -4 degrees of camber in the front and -2.5 in the rear with 1/16th toe in in the rear. I plan to do a handful of track events a year, so my question for you is, will that much negative camber in the front significantly negatively impact acceleration and braking performance?
From my understanding most guys that track their BRZ/FRS don't dial in more than -3.5 degrees in the front.
3k1n is offline   Reply With Quote
Old 07-23-2021, 07:00 PM   #5010
racingfool
racingfool's Avatar
Drives: Miata
Acceleration? No. Braking? Perhaps.
racingfool is offline   Reply With Quote
Old 07-23-2021, 07:09 PM   #5011
CSG Mike
CSG Mike's Avatar
Acceleration? No unless you get wheelspin.
Braking? possibly. Depends on the rest of your setup.
Old 07-24-2021, 12:45 AM   #5012
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
thanks
Most people don't drive their car in a way that put enough heat into things or have a 3" exhaust pipe right next to things either.
I addressed it in my T4 build and a cost effective way of addressing it.
https://www.ft86club.com/forums/show...&postcount=134
The heat presents 2 risks: 1) it bakes away the grease causing it to deteriorate and eventually fail and 2) sudden change in temperature (like going 10/10ths immediately on a cold morning) can cause the boot to balloon and explode.
I was on the phone with Driveshaft Shop talking about axles and they confirmed my practice which is cover the 3 bases: Good Grease, Breathable boot and keep unnecessary heat away.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
EB86 (07-25-2021)
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
