Old 06-30-2021, 01:22 PM   #1
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Posting for friend, mechanical issues
Hello all, my car is a 2013 Subaru BRZ/Scion FRS with 166K miles. Car has not been running well, it sometimes feels like its about to stall out in idle and drops to 500RPM and engine shakes. When I give the car some gas the RPM jumps up and down. I replaced intake manifold gasket, gaskets for fuel injectors all replaced, fuel pump & fuel filter, mass air flow sensor, PCV valve, spark plugs & ignition coils replaced... I don't want to keep replacing parts and guessing at this point. Only code that pops up is for a p0172 for running rich. When I go for a test drive to test it sluggish at acceleration. Any suggestions would be helpful. Thanks everyone!
spcmafia is offline   Reply With Quote
Old 06-30-2021, 02:25 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Only doing it with AC on? Auto or MT?
Old 06-30-2021, 03:45 PM   #3
spcmafia
spcmafia's Avatar
I don't think mentioned if the AC was on. But it seems to happen if the vehicle is just idling. I'll ask him about manual or auto. I believe is just his O2 sensor being dirty it it could also be his MAF.
Old 06-30-2021, 04:22 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This and the torque app are good to have. You can read codes as well as see what the sensors are outputting.
https://www.amazon.com/gp/product/B0...ref_=pd_gw_unk
For sure can be an O2 sensor. There was an idle instability tech bulletin that required a reflash. Being it has been so long and so many miles until the issue I doubt that the TB is it. Reading your first post it says he replaced the MAF.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Dzmitry (07-01-2021), spcmafia (07-01-2021)
Old 06-30-2021, 04:26 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
Your friend's mechanical keyboard broken??
Old 06-30-2021, 09:38 PM   #6
Grady
Grady's Avatar
Maybe his “friend” has a burning sensation when he urinates also?
Old 07-01-2021, 03:18 AM   #7
Any power mods?
Recent tune change?
Old 07-01-2021, 10:32 AM   #8
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Yes, I would think the first thing he should have looked at was the O2 sensor, as when this doesn't work properly or at all, it can cause quite a few symptoms including the one you he describes.
Dzmitry is offline   Reply With Quote
Old 07-01-2021, 10:37 AM   #9
spcmafia
spcmafia's Avatar
I would assume, I literally just copied and paste his IM message haha.
The Following User Says Thank You to spcmafia For This Useful Post:
JD001 (07-01-2021)
Old 07-01-2021, 10:38 AM   #10
spcmafia
spcmafia's Avatar
Is mostly some rashes on the tip.
Old 07-01-2021, 10:40 AM   #11
spcmafia
spcmafia's Avatar
Any power mods?
Recent tune change?
My first question to him was that, if he messed around with his tunes because he mentioned having OFT with uncatted headers. Other than that he has an inlet tube and Invidia N1. I read all that and the first thing that popped in my mind was the MAF or O2.
humfrz (07-01-2021)
Old 07-01-2021, 10:42 AM   #12
spcmafia
spcmafia's Avatar
Exactly, he ordered a new O2, so I might go to his house and see what else we can look at. But like I said, is definitely his O2, that's a lot of miles so It would only make sense.
Old 07-01-2021, 10:48 AM   #13
Dzmitry
Dzmitry's Avatar
Well the O2 is usually a good check, but more times than not (at least from my personal experience), a fairly beat catalytic converter is the real culprit - in which case the O2 picks up readings that aren't standard and you get the code. So see first if the O2 fixes it and then go from there.
EDIT: Just noticed you mentioned he has un-catted headers.
Old 07-01-2021, 10:54 AM   #14
spcmafia
spcmafia's Avatar
I believe he's running catless headers. But we'll see.
Differences in driving feel/mechanical issues w/different clutch types? Elmacanite Engine, Exhaust, Transmission 9 07-28-2020 08:27 AM
Posting? Packofcrows Site Announcements / Questions / Issues 10 04-11-2016 07:12 PM
Need help posting pics Ridgerunr Site Announcements / Questions / Issues 2 10-28-2015 01:19 PM
Took my best friend for a ride, post up your best friend!! track_warrior Scion FR-S / Toyota 86 GT86 General Forum 19 07-13-2012 12:37 AM
My friend's blog posting about my FR-S avusblue Scion FR-S / Toyota 86 GT86 General Forum 0 07-10-2012 11:44 PM
