| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Toyota 86
Possible brake pad drag?
Hi guys, so I recently installed the AP racing sprint BBK and everything seemed fine for the past week or so, swapped to new ferodo ds1.11 pads for an upcoming track day and was driving it around today and noticed a low rumbling/humming sort of sound when going around 60-80km/h.
Could've been the road or just my imagination but after coming off the freeway I put my hand on the caliper/lug nuts and the driver's side (RHD) was definitly hotter than the left, don't think it was a huge amount (wasn't like one side was cold and the other was smoking, but don't have a temp gun so who knows). Couldn't smell the brakes, the car wasn't pulling to one side when driving and it didn't feel like the car was low on power or anything. What could be causing the right side to be hotter than the left? I do have the HKS fender mount oil cooler but I doubt that would make it that much hotter. Put the car on stands and I could rotate both wheels and they felt the same. Is there a possible issue with the brakes or could the new pads be a little too thick/needs to break in a bit? |
#2 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
One easy thing to check is runout on the disk.
A bit of warp might do that.
"I gotta rock." -- Charley Brown |
#3 |
ProCrastinationConsultant
did you properly bed the pads?
| The Following User Says Thank You to soundman98 For This Useful Post: | thomasmryan (06-28-2021) |
#4 |
Could be a caliper is sticking -
#5 |
Drives: Toyota 86
just an update, bedded the pads, the noise and vibrations seemed to be reduced quite a bit. After that drove the next day and noticed a very small amount of noise still. Reseat the pads (retracted pistons fully, put wheels on then pumped brakes).
Thought that the noise may have partially been due to the disc not seating properly because maybe one side of the pads were pushing more on the disc than the other if that makes sense? Anyways, the noise is pretty much gone now, no longer feel one side of the caliper/wheel is hotter than the other |
| The Following User Says Thank You to GCFSA For This Useful Post: | humfrz (06-28-2021) |
| Drag | IsaiahW | BRZ First-Gen (2012+) — General Topics | 5 | 06-07-2021 02:22 PM |
| June 7th after Perrin meet drag racing at Portland Raceway or watch us drag! | stockysnail | Northwest | 15 | 06-08-2014 02:08 PM |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-25-2013 12:26 AM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 11:20 PM |
| 86 Drag car?!?! | MtnDrvr86 | Other Vehicles & General Automotive Discussions | 5 | 01-14-2010 07:35 PM |
