Old 05-20-2021, 11:25 AM   #183
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Man! That's impressive.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 05-20-2021, 12:10 PM   #184
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
soundman98 (05-20-2021)
Old 05-22-2021, 07:56 PM   #185
p1l0t
p1l0t's Avatar
Here you go sir. On a closer inspection, the rod is bent to the side. It is subtle, but it is there. This bending is 90 degrees to the direction it was spinning. This suggests the bending wasn’t a consequence of spinning around and tearing through the block. Like nunchucking through the block happened, and it probably finished the rod off, but I bet the bend caused the internal stress on the piston and ripped the bottom of the piston to pieces and then it all went downhill from there.
Well there's your problem right there..
zberz (05-22-2021)
Old 05-24-2021, 07:41 PM   #186
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Well if nursing doesn’t end up working out for you, you can always become a hand model.
*Edit*.....or you can always PRETEND to be a hand model working at Vandalay Hand Modeling Agency.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following 3 Users Say Thank You to FR-S2GT86 For This Useful Post:
B T (05-26-2021), Irace86.2.0 (05-24-2021), soundman98 (05-24-2021)
Old 05-24-2021, 07:58 PM   #187
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Originally Posted by FR-S2GT86 View Post
Ouch! I know you had a lot into that build. Sorry man. But at least I know now not to move up to the 75mm pulley.
You could always keep the twin and wait until there's a crate electric motor available.
A crate electric in this platform would be sweet. 200hp would be like 400hp with electric motor torque.
jeepmor is offline   Reply With Quote
The Following User Says Thank You to jeepmor For This Useful Post:
botbs (05-25-2021)
Dustin's UltraMarine FR-S (Engine Blew - LS3 Time) DustinS Member's Car Journals 800 04-13-2024 09:23 AM
Engine Blew, any shop recommendations? tian105 Southern California 11 08-16-2020 11:35 PM
Engine blew on 4psi? Causes? soccerk18 Software Tuning 26 08-10-2019 11:18 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 11:43 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 02:50 PM
