Old 05-15-2021, 05:55 PM   #1
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Ecu Tek pro cable and dongle
$250. Ecutek cable and dongle. No license.
I do have the ecu this was paired with though. Not positive on this but it might be possible to swap the ecu to avoid having to buy another license. Ecu was in a 2013 BRZ.
kask2_6.0 is offline   Reply With Quote
Old 05-24-2021, 03:44 PM   #2
RallyKeith
Drives: 2103 Subaru BRZ
Is this still available?
If I understand this all I need to tune my car if my ECU already has a license on it? If not I just have to buy the license.
Thanks,
Keith
RallyKeith is offline   Reply With Quote
Old 05-24-2021, 03:55 PM   #3
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
Yes, this is still available. This is all you would need to load tune files from your tuner to the ecu. Here is a better description of the hardware:
Originally Posted by COO86L View Post
Just to add, this is the write up I send confused customers (of which there are a few)..
There are 5 components of the ecutek end user/retail system.
1. EcuTek OBDII cable
2. EcuTek dongle/usb key or its correct name "DESkey"
3. ProECU software
4. License
5. Tune file
All of these are separate things. The software and license are both software items and aren't physical.
The OBDII cable is used for transferring data from the ProECU software/laptop to your cars ECU.
The DESkey is a software encryption key that allows you to open ProECU on your computer. It is like a password for a program but it is physical and impossible to crack/hack. It's purely used so you can't copy the ProECU software, kind of like how some games etc used a product key.
The license is a string of code that attaches to your ProECU software until you write it to the cars ECU. The license, once applied to an ECU, is no longer connected to your particular EcuTek programming kit. You are free to use whatever cable and dongle you wish, otherwise people would be locked to one tuner and one tuner only.
The tune file is created by your tuner. If they are doing it in person, you won't see a copy of it. If you are doing it remotely, they will compile it and "key" it to your dongle ID (DESkey ID). This allows you to flash it to your car but not allow you to open, view or change any mapping. This doesn't lock your ECU either, but using EcuTek means you are locked to EcuTek's software UNLESS you flash a stock tune file, which will allow different programs access.
Old 05-24-2021, 06:29 PM   #4
Rubedo
Miami to Montana
pm sent
11/26/2018 - 2016 Limited M/T Crystal White Pearl
Been lurking this forum since 2011 and finally bought one haha
Rubedo is offline   Reply With Quote
Ecutek Cable and Dongle tjed147 Engine, Exhaust, Bolt-Ons 1 06-30-2019 01:17 AM
WTB: Ecutek Cable & Dongle TheStig85 Want-To-Buy Requests 2 01-15-2019 08:26 PM
FS: Ecutek Cable and USB Dongle toeout Engine, Exhaust, Bolt-Ons 2 05-05-2017 01:34 PM
Wtb: ecutek cable/dongle ThisGuy919 Want-To-Buy Requests 1 02-14-2015 02:55 PM
ECUTEK Cable and Dongle JMPoole Engine, Exhaust, Bolt-Ons 5 07-18-2013 04:38 AM
