#225 |
Drives: 13 ZN6
WOW. Congratulations. I hope the winning bid on cars and bids not only exceeds your reserve but exceeds it by a large margin as it is well deserved. Your STI TS build brought me lots of inspiration for my car!
#226 |
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Been capturing some videos for the Cars & Bid auction. Ive got some exhaust videos to share which people in the community might find helpful.
Setup: Catless EUL(Gruppe-s), Tomei Over Pipe, Stock Front Pipe, Stock Mid Pipe, JDM STI Axleback Cold start: Normal Idle: 5k Rev: |
| The Following User Says Thank You to Elliotw For This Useful Post: | RToyo86 (05-17-2021) |
#227 | |
2013 Series 10 FRS #553
#228 |
| The Following User Says Thank You to Elliotw For This Useful Post: | jflogerzi (05-17-2021) |
#229 |
might be replacing my MXP SP with the CSG touring cat back.
#230 |
It finally arrived!
| The Following 8 Users Say Thank You to Elliotw For This Useful Post: | beltax90 (05-20-2021), BrahmaBull1990 (05-19-2021), Code Monkey (05-19-2021), jflogerzi (05-20-2021), KMA KiCKz (05-20-2021), MrSkubi (05-20-2021), NoHaveMSG (05-19-2021), Thefalls (05-28-2021) |
#231 |
| The Following User Says Thank You to jflogerzi For This Useful Post: | Elliotw (05-20-2021) |
#232 |
Drives: Crapcan
Damnnnnnnnnnn!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Super jealous. So how much time have you spent just sat in it blipping the throttle and listening to that exhaust note?
#233 |
Exhaust is the best part of the car so far. At 4,000 RPM when the valves open up it just sounds amazing. It has a sharkwerks bypass on it
| The Following User Says Thank You to Elliotw For This Useful Post: | NoHaveMSG (05-20-2021) |
#234 |
Drives: 2010 corolla
whoa! white on red is too good
#235 |
We need some revs and a POV drive on a good road
#236 |
Spoiler off!
Looks the tS is getting cleaner air!
#237 |
Drives: Crapcan
The airflow stays pretty well attached to the back of the cabin, so they are really both getting pretty solid airflow. The GT3’s twisted wing design also compensates for being low mounted.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Elliotw (05-24-2021) |
#238 |
Bid Early & Often!
https://carsandbids.com/auctions/KY5...-subaru-brz-ts Last edited by Elliotw; 05-28-2021 at 03:49 PM. Reason: english is heard |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 08:52 PM |
| [B is for Build] BRZ resurrection build | im_topher | Member's Car Journals | 49 | 03-05-2018 10:41 AM |
| HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions | Corradooo | Engine, Exhaust, Transmission | 2 | 11-25-2017 08:16 PM |
| Superpenguin's "Not Another Build Thread!" Build Thread | superpenguin | Member's Car Journals | 7 | 06-17-2015 05:00 PM |
| No build date on passenger side sticker, how to determine build date? | BBYZILA | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 01-20-2015 11:14 PM |
