#155 |
Drives: Q5 + BRZ + M796
The FA20 can lick my balls. Such a bitch. Block halves aren’t ease to completely separate when the rod caps need to be removed because the pistons can’t fall through the cylinders like inline engines. The rod caps aren’t easy to remove when the engine is all seized up and the rod bolts are a bitch to get to. I know this is typically done on a bench to ease the process, but I helped it with an angle grinder, since the block was toast and this was only about discovery.
All the other rods looked decent besides the one that broke. I didn’t notice any spun bearings or anything. Bearings had some scratch marks, but it was more consistent with contamination after the fact than excess wear of spinning a bearing. The rod that snapped off also broke the head of one of the rod bolts off. Was this failure from detonation, preignition or just too much power? The rod clearly peppered the cylinder wall. I didn’t have time to finish checking it all out. I’ll finish Sunday.
#156 |
ProCrastinationConsultant
Isn't that the same piston others have had spin the bearing? I'm still wondering if it's an oiling/cooling issue
#157 |
#158 |
Engine Blew!
#159 |
I’ll add some pictures, but I may need to use an angle grinder to cut off more parts to find out. I forgot I’m going to meet family Sunday for Mother’s Day. I may not get to things until next week.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | bcj (05-08-2021) |
#160 | |
This is important stuff, mom can wait! Hahaha. I’ll be with fam tomorrow too.
| The Following User Says Thank You to ermax For This Useful Post: | Irace86.2.0 (05-08-2021) |
#161 |
is this where i sign the petition for adding another weekend to every week?
| The Following 4 Users Say Thank You to soundman98 For This Useful Post: |
#162 | |
I Love custom Turbo kits
Drives: Limited BRZ
You can get a fully built V8 long block for $20k that holds 1400HP.
#163 | |
Drives: Limited BRZ
Steve99 has a topic with the ECU swap programming steps with all the info in the software/tuning section. Edit: I see now that Steve99 had answered you in another post already. I will keep my answer here so others curious and reading this topic can see it too.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Irace86.2.0 (05-08-2021) |
#164 |
Here are the last of the pictures. The crank journals and bearings looked decent, but clearly were infected post destruction from contaminated oil, which is why there are small pits. The rod journals didn’t look terrible, even on number two cylinder, but the rod bearings on the number two cylinder were trashed, as you could see in the comparison. None of the other cylinders had any bent valves, worn journals, worn bearings, bent rods or anything. Number two was so annihilated that it is hard to tell what happened.
The damage: —Two valves were bent. —The piston rings were bent up. —The top of the piston only had two minor impact marks. —The piston skirt and bottom was destroyed. —The rod was snapped and missing much of the middle. —The cylinder was peppered with pits/strikes. —The block was destroyed and tore through. —Rod bearings on #2 were scratched up and pancaked, but they were in position and freely moving, not overlapping and not seized. What do you guys think?
| The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post: | grumpysnapper (05-16-2021), p1l0t (05-15-2021) |
#165 |
Drives: 2015 Lightning Red BRZ
Sent from my SM-G950U using Tapatalk |
| The Following 4 Users Say Thank You to zberz For This Useful Post: | BrahmaBull1990 (05-16-2021), Irace86.2.0 (05-15-2021), mike_b (05-15-2021), Trueweltall (05-21-2021) |
#166 |
| The Following 6 Users Say Thank You to Irace86.2.0 For This Useful Post: | bcj (05-16-2021), BrahmaBull1990 (05-16-2021), Capt Spaulding (05-16-2021), Dadhawk (05-16-2021), grumpysnapper (05-17-2021), NoHaveMSG (05-16-2021) |
#167 | |
The bearing caps don’t need to literally spin for the rods to start knocking like hell. The bearing in your picture looks bad to me. You’ve gone through a few layers of material on them. You also say they are pancaked which isn’t good at all. I doubt this was the cause for throwing a rod through the block but I’m surprised your haven’t been hearing rod knock before this incident, especially on a cold start. |
| The Following User Says Thank You to ermax For This Useful Post: | Irace86.2.0 (05-16-2021) |
#168 | |
The oil was recently changed and good, but it may have been too cold, and I could have sloshed the oil going through the 'S' curve of the left, right, right turn, but I typically need to wait for the car to clear the bucked asphalt at the apex of the corner, or the car just will lose traction. Typically, I would hit the bump then wait a second for the car to straighten out before getting on it, and that seems to be mostly the case, so while it is possible the oil starved because of lateral movement, mixed with cold temps, I just don't know. Here is the thing: I have been listening to the video over and over. Unfortunately, the video is just from a dash camera from inside the car, and there is music and loud road noise. I used Audacity to try to isolate the sound, and when I did the best I could, I can swear I hear a squeal/whistle before the engine explodes. The squeal/whistle could be the tires breaking loose a little, but this is unlikely, as that would have decreased the stresses on the motor, so it is more likely that the squeal/whistle could be bearing surface contact. Maybe there was too much force and not enough oil to protect the surface, and once the surface made contact under high load, it set off a chain of events that caused the failure. Listen to the audio. There is a squeal right before the destruction. Still, I don't get how the rod tore through the bottom of the piston and then disintegrated in half, or did it disintegrate and then stick the piston? Who knows?
| Dustin's UltraMarine FR-S (Engine Blew - LS3 Time) | DustinS | Member's Car Journals | 800 | 04-13-2024 09:23 AM |
| Engine Blew, any shop recommendations? | tian105 | Southern California | 11 | 08-16-2020 11:35 PM |
| Engine blew on 4psi? Causes? | soccerk18 | Software Tuning | 26 | 08-10-2019 11:18 AM |
| Help! New Car Engine Blew Up. What are my rights? | Obsidiank | Scion FR-S / Toyota 86 GT86 General Forum | 53 | 12-11-2014 11:43 AM |
| So my engine blew up.... | alliedcam1 | Engine, Exhaust, Transmission | 57 | 12-28-2013 02:50 PM |
