#421 | |
Drives: 2014 DMG BRZ
Is there any way to reduce the PS cut? It's not super heavy, just kinda freaked me out a bit when it cut during a slide up the hill. |
#422 | |
Drives: Crapcan
Not that I am aware of. It’s some kind of high load protection for the eps motor. Sent from my iPhone using Tapatalk
#423 |
Drives: rocketship
apparently the new re-surfacing at the Ridge is super grippy!! Buddy who went to a 2fast day over the weekend said it felt crazy fast!
#424 | |
Also managed to trigger a first misfire cel
#425 | |
Drives: Crapcan
It’s about 2 seconds is what the general consensus. The curb transitions are also much smoother. Sent from my iPhone using Tapatalk
#426 |
Senior Misanthrope
#427 |
Drives: Crapcan
Yeah you should, would be cool to catch you out there again and see how the mini wagooon does.
#428 |
Drives: rocketship
I'l be out at the ridge next weekend. Currently registered for the Audi weekend both days. but thinking of doing a 3 day weekend and sign up for HOD as well on Friday.
I'll be back at the Ridge end of may on 2 wheels with TrackTime |
#429 |
Drives: Many
I'm gonna do the Turn2 day at the Ridge on May 22nd I think.
#430 | |
Drives: Whiteout track car; lava donor
Should be a fun time! |
#431 |
Anyone doing alignments at the track? I know my alignment is out after attacking the curbs at PIR and ORP this past weekend.
I'm looking for guidance on what to buy to do my own alignments. I don't have the budget for scales. I'm typically maxed out on camber, so mostly need to check and adjust toe after a day of 40 minutes per hour, all day, running hard on track. One on topic note: Exit of 13 at the Ridge, those alligators are STILL very harsh. All the other Ridge curbing is benign. |
#432 | |
Drives: Crapcan
#433 |
Drives: Many
Front toe doesn't change very much at all when you change camber, fwiw. I went from 2.5* to 4.5* on the alignment rack and the toe barely changed. I take out camber for long transits in my autocross car (Vegas, Crow's Landing, Fontana) and I wanted to see how bad the toe was changing -- it's negligible.
#434 | |
Drives: Nevermorange FRS
Here's the easy button and you don't need scales unless you're corner balancing. Getting on level ground is helpful for doing camber unless you have an electronic gauge that can be reset to "zero" at any angle. To establish level - I recommend buying a 360 Laser level on Amazon like this one: https://www.amazon.com/dp/B07H3P8H8B...517NM2F68HQTE4 Then you can put planks/boards/shims whatever under each tire to level. This allows you to easily check camber with bubble gauge like the one I have from Longacre https://www.longacreracing.com/produ...gnetic-Adapter For front toe, the toe plates are the super easy button. https://www.longacreracing.com/produ...Magnets-(pair) For the rear toe - since they are not connected by a rack, the toe plates aren't an ideal tool. Rear Toe: Measure track width of the front and then measure the track width of the rear to get total difference and then divide by 2 - this is the amount you need to space the string off the front tire in order to properly set the rear. EXAMPLE: My rear track width is exactly 7/8th inch total wider than my front (7/16ths per side). So what I do is wrap a string around the car, set the front tire straight ahead and perfectly equal and then put 7/16ths spacer between the string and the front of the front tire AND THEN I have a accurate way to measure and set rear toe. It works PERFECT. My car is currently level on scales with a string wrapped around it as I type this so I can facetime you this evening if you need a better visual explanation.
PRO86 | STL | LuckyDog
| My BRZ at The Ridge Motorsports Park | alliedcam1 | Northwest | 2 | 08-30-2014 04:33 AM |
| The Ridge this weekend with NASA NW anyone going? | VIPwryann | Northwest | 6 | 08-24-2014 01:38 PM |
| Trail Ridge Road in my FR-S | Brett | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 07-12-2013 10:43 PM |
| AJ BRZ at Ridge Motorsports Park ! Take 2 ! | AJ PwR | Tracking / Autocross / HPDE / Drifting | 0 | 05-30-2013 05:05 PM |
| BRZ at Bay Ridge Subaru | Pakjk89 | NY / NJ / CT / PA | 0 | 03-27-2012 02:26 PM |
