Old 05-04-2021, 12:59 PM   #323
SonnyMod
Drives: 2013 Scion FR-S (949 Racing)
Country - USA
State - California
Track Name and Configuration - Chuckwalla Valley Raceway CW
Time - 1:56.898
NA, Forced Induction, Swap - NA
Driver - Sonny Watanasirisuk
Setup -
Xida 500/500 with 949 Racing billet coaxial mounts
22mm Perrin front sway, stock rear
Renderos Racing 4-point roll bar
DIY Alumanite front splitter
APR GT250 wing + Singular endplates
-5.0° front camber
-2.5° rear camber
265/35R18 Goodyear SC3R (2 heat cycles)
18x10 +40 XXR CNC forged wheels
Delicious tune, 205whp on E85
SonnyMod is offline   Reply With Quote
The Following 3 Users Say Thank You to SonnyMod For This Useful Post:
DarkSunrise (05-04-2021), Goingnowherefast (05-05-2021), Racecomp Engineering (05-05-2021)
Old 05-04-2021, 02:42 PM   #324
redlined600
redlined600's Avatar
Drives: Fr-s
I'll throw my hat in for Autobahn full in IL. It was my first time there and I left tons of time on the table so I'm sure someone will be along shortly to crush this time.
Country - USA
State - Illinois
Track Name and Configuration - Autobahn Country club - Full
Time - 2:51.183
Driver - Ted
Setup - Below
Racecomp T2 f450/r500
Oem fr sway/ perrin rear sway
E85
Pirelli DHH
9lives wing/custom splitter
Data pulled from Aim solo II DL
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
Old 05-18-2021, 01:09 PM   #325
langjai23
Drives: 14 brz
Country - USA
State - Illinois
Time - 2:51.183
Driver - Ted
Setup - Below
E85
Pirelli DHH
next time around you should easily be under 2:50 especially with aero and e85
langjai23 is offline   Reply With Quote
The Following User Says Thank You to langjai23 For This Useful Post:
redlined600 (05-18-2021)
Old 06-20-2021, 11:01 AM   #326
deca
Drives: Halo 860
Very proud of this time, but now I need to get into the 17s. I know the car is capable as it is and have some ideas about where to pick up more time.
Ran 225 RS4s all last year and ended at an 18.9. Picked up the RPF1s for my first event last month, and ended up running them with the old RT615K+s they came with to very frustrating/disappointing results (consistent 20.2s). As soon as I got a fresh set of RS4s on the new wheels it was back to steady improvements, hitting a new PB on my first hot lap of the day and continuing from there.
I've attached a .csv and .kml of the lap from my Aim Solo logs.
Country - USA
State - Michigan
Track Name and Configuration - Waterford Hills
Time - 1:18.207
Driver - David Best
Setup -
OFT Stage 2+ 93
Borla UEL header
Tanabe Concept G catback
Jackson Racing dual radiator/intercooler
TRD lowering springs
Verus camber plates
-3.3° front camber
-2.2° rear camber
0.1° front toe out
0° rear toe
245/40R17 Hankook RS4
17x9 +35 Enkei RPF1
G-Loc R10
deca is offline   Reply With Quote
The Following User Says Thank You to deca For This Useful Post:
Goingnowherefast (06-21-2021)
Old 06-21-2021, 12:34 AM   #327
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Great time, Waterford is a very technical track. You'll be in the 17's by the end of the year no problem.
Here's mine for Waterford. It was the 5th lap of the day, but I had to end the session early for fuel starvation issues. That wouldn't have been the end, but the whole track was red flagged for my best friends Miata that got buried in the front concrete wall . Day was done for us after that. Optimal time was a 1:16.42 via AIM Solo II. Confident I'd break into the 16's if I had more than 5 laps that day.
Country - USA
State - Michigan
Time - 1:17.77
Driver - William Rori
Setup -
2017 Subaru BRZ w/PP
Delicious Tuning Stage 2+ ~E45 that day
Tomei UEL
HKS Single Exit
RCE Tarmac II
17x9 Wedsport TC105X
245/40/R17 A052 with ~20 heat cycles
Powerstop Track Day pads
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
The Following User Says Thank You to Goingnowherefast For This Useful Post:
deca (06-21-2021)
Old 06-21-2021, 05:43 PM   #328
deca
Drives: Halo 860
Originally Posted by Goingnowherefast View Post
Time - 1:17.77
Thank you! And likewise, that's a fantastic time. Where were you when I needed specific times to gun for lol
I think my next easy time gains will come from carrying more speed and forcing more rotation through T1, and then just continuing to be even braver on T5. If anything stood out to you in my video that I could work on I'd be happy to hear it.
If you have any datalogs you'd be willing to share that would be awesome as well, even just having GPS Speed for corner targets would be beneficial.
Old 07-09-2021, 07:24 PM   #329
Goingnowherefast
Well, take this with a big grain of salt because I believe we'd be the same time if our setups were the same but here's the biggest thing I see. Also unfortunately that was my first day with the Solo II and I don't think it saved any of the sessions, or at least I can't figure out how to export them.
Take a look at the racing line Alexander Doss takes entering Bluff Bend starting at @0:29 (
Note how he holds the far left side where he brakes and downshifts to 2nd. I've marked his line (roughly) in blue. You (and honestly I need to get better at this too) take more of the red line when braking, downshifting and entering the slow skeet-house turn. I believe taking his line would decrease time, being that you can carry significantly more speed going into and out of Bluff by holding the left edge instead of going over to the right.
Let me know if that seems clear.
*Edit* Also, I'd go much wider going into the front straight seen at like ~1:20 in your video. You should be on or near the rumble strips on the right side (Alex doss does the faster line at like ~1:27 in the video I posted above).
deca (07-10-2021)
Old 07-10-2021, 01:26 PM   #330
deca
Drives: Halo 860
Oh this is a really good point, and I wasn't really thinking about this area at all while looking at potential time gains. That makes a lot of sense since you're entering T3 so slowly regardless. I've always approached bluff purely as a setup to my line through T3, I'll definitely give this a shot the next time I'm there.
That's a good point on the front straight as well. I think I have a tendency to underestimate speed differences between lines in areas where I'm at WOT regardless, but I managed to pick up time last year by widening my line out of the esses in a similar way.
Thank you for the feedback!
Old 07-23-2021, 06:21 PM   #331
deca
Drives: Halo 860
Time - 1:17.77
I kind of feel bad posting this because it's so close, but I'm also very proud of this improvement since my last time at the track. I made a last minute decision to attend a friend's private rental just days after running all weekend in the SCCA Time Trials at Gingerman. My intention was just to take it easy and have a relaxed afternoon after the stress of the weekend, and I set this time on my very first flying lap of the day.
Thank you again for the recommendation on T3, the line immediately made sense and I believe it helped both pace and consistency. I think the biggest improvements came from all of the high speed cornering practice I've had at Gingerman since the last time I ran Waterford. Pushing hard on T8+9 at Gingerman really improved my confidence carrying more speed into T1 and T5 at Waterford.
Country - USA
State - Michigan
Time - 1:17.74
Driver - David Best
Setup -
OFT Stage 2+ 93
Borla UEL header
Verus camber plates
-3.3° front camber
-2.2° rear camber
0.1° front toe out
0° rear toe
17x9 +35 Enkei RPF1
CSG C2 pads
I also had an opportunity to run a friends car and am now VERY eager to get a set of coilovers and dial them in. After feeling them out first hand I believe that they may be able to push my car into 16s, especially with some stickier tires.
Old 08-20-2021, 07:53 PM   #332
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Originally Posted by SonnyMod View Post
Country - USA
State - California
Time - 1:56.898
Setup -
-5.0° front camber
-2.5° rear camber
Dyno'd Blub this week. Had not been run since it came off the track at this event. Made 186whp. Motor is done. Felt down on power at high RPM but I didn't realize it was this bad. Wonder how much faster it would go with the 200whp it was making in 2019 when we first tuned it.
949 Racing is offline   Reply With Quote
Old 10-06-2021, 12:33 PM   #333
ROADRACER
Drives: unlimited cheap build N/A track car
How many track miles have you got on your engine? Mine seems to be running the same after around 4000 miles.
ROADRACER is offline   Reply With Quote
Old 10-06-2021, 07:06 PM   #334
949 Racing
949 Racing's Avatar
~90k unknown miles from Carmax. About 95k now I think, mostly track. Still runs fine, just doesn't make the power it did to years ago when we first tuned it.
We're rebuilding it with forged bits. Kswap too rich for or blood.
Old 10-07-2021, 01:25 PM   #335
Goingnowherefast
No worries! Man, I wanted to get out there and run 16's this year but the cards just didn't fall into place (lots of weddings to attend). So it looks like you'll be holding that record here for a while! I'm parting the car out now, so let me know if you want anything off it.
Old 10-07-2021, 03:40 PM   #336
gcranston
Drives: 2015 Subaru BRZ Limited DGM
Originally Posted by lutfy View Post
Watkins Glen NA: 2.10:149
Super thanks to Mike Paisan and the AZT install crew for helping me achieve this goal. You guys rock.
https://racehero.io/events/nasa-watk...ults/536871261
You got a build thread and/or a video? This I've got to see!
gcranston is offline   Reply With Quote
lap record, lap time, race track, track record
Anything going on with 86/brz platform? Vr4gasmtt Scion FR-S / Toyota 86 GT86 General Forum 19 06-12-2016 02:55 PM
Indigo Dash cam that records you? Packofcrows Electronics | Audio | NAV | Infotainment 3 08-23-2015 08:54 PM
FS: 2004 Toyota Matrix - Dealer Serviced, Full Records! that_guy Canada Classifieds 1 09-23-2014 11:43 AM
Can Toyota use the 86/FR-S/BRZ platform for anything else? gymratter Scion FR-S / Toyota 86 GT86 General Forum 83 04-24-2014 07:41 PM
You don't break track records by settling! Custom Valved BC Coilvers and Carbotech XP Element Tuning Brakes, Suspension, Chassis 24 07-23-2012 10:35 PM
