Old 05-03-2021, 01:42 PM   #85
nwgabrz
Drives: BRZ Limited
Originally Posted by Rican_D View Post
Android Auto works great with that carlink app. Just can't use the factory USB port for it.
Sent from my Pixel 5 using Tapatalk
How do you connect Android Auto? Is there a USB connection that comes out from somewhere? Can we connect that to the factory USB port?
nwgabrz is offline   Reply With Quote
Old 05-03-2021, 02:05 PM   #86
ermax
ermax's Avatar
The HU has 3 ports and my guess is they aren’t all treaded the same way. One probably handles USB storage while the other handles Android Auto/CarPlay. I never use USB storage so I would just connect the port that handles CarPlay to the OEM port.
The Following User Says Thank You to ermax For This Useful Post:
nwgabrz (05-03-2021)
Old 05-03-2021, 02:28 PM   #87
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
It comes with USB ports. It comes with the the adapter that retains the factory USB port. You also have the extra ports. I've tried Android auto using the factory port, but it crashes. I use the other USB port and it works just fine. No adapters needed.
Rican_D is offline   Reply With Quote
The Following User Says Thank You to Rican_D For This Useful Post:
Old 05-03-2021, 04:08 PM   #88
ermax
ermax's Avatar
Can you not pick which port goes to the factory plug?
Old 05-03-2021, 05:46 PM   #89
nwgabrz
Drives: BRZ Limited
Would like to know as well. It seems having the port, regardless of which one, connect to the factory plug is what causes it to crash (the adapter), from what OP seems to imply, but would like clarification as well.
Old 05-03-2021, 06:10 PM   #90
Rican_D
Rican_D's Avatar
The USBs come as harnesses that plug to the rear of the head unit. They included one harness specific for our car to retain the factory USB. The other USB harnesses are female USB ports you can place wherever you want. I have it plugged to a USB hub in my glove box.
Old 05-03-2021, 07:53 PM   #91
ermax
ermax's Avatar
So this is a job for a soldering iron. No big deal. Thanks for answering all of our questions.
Old 05-03-2021, 08:42 PM   #92
Rican_D
Rican_D's Avatar
Why would you need to solder?
Old 05-04-2021, 08:09 AM   #93
ermax
ermax's Avatar
To take a working USB port and splice it into the OEM port.
Old 05-04-2021, 08:12 AM   #94
Rican_D
Rican_D's Avatar
Oh, so you can use that port for Android auto? Seems like the factory port can't handle the data.
Old 05-04-2021, 10:45 AM   #95
ermax
ermax's Avatar
Maybe the harness Teyes provides only feeds the outer pins (power) and not the inner pins (data). The OEM port for sure has data pins because you can plug in an iPhone and get full automation of your music library over USB (and better sound quality than BT). At least on my 2013 FR-S with touch screen.
Old 05-04-2021, 10:49 AM   #96
ermax
ermax's Avatar
One question that I've seen conflicting answers for. Will it Bluetooth tether for data or is it strictly WiFi tethering? If it's WiFi only that will be a massive pain in the ass because on the iPhone you would have to manually go into the Personal Hotspot settings to activate the hotspot every time you get in the car.
Old 05-04-2021, 10:52 AM   #97
Rican_D
Rican_D's Avatar
No, it feeds data. I've played music files and done updates through the factory plug. That's why it leads me to believe it's the factory plug itself. Android auto loads on there but it shuts down right after it loads. Maybe since my car is a 2013 the USB port may not be as good. Not sure about that, just making a guess.
Old 05-04-2021, 11:07 AM   #98
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
I have used the factory USB plug on an aftermarket unit for both CarPlay and AA without an issue. The factory USB is not the issue.
Often times it is the cable quality not being able to transfer enough data for AA to run. Your best bet is to ensure you get a high-quality USB3.0 cable to run AA. It's very sensitive to that.
sharpsicle is offline   Reply With Quote
Android based stereo vs. stereo w/ Android auto redlined600 Electronics | Audio | NAV | Infotainment 12 02-24-2019 03:53 AM
200mm android head unit with android lollipop rsingh Electronics | Audio | NAV | Infotainment 3 05-23-2016 09:48 PM
WTB: Android HU tonypalomo Want-To-Buy Requests 0 01-12-2015 04:00 PM
Help|Best Android based HU redsuns03 Electronics | Audio | NAV | Infotainment 14 07-28-2013 09:30 AM
Android vs iOS vs BB os...which is best? Raiden Off-Topic Lounge [WARNING: NO POLITICS] 19 02-02-2011 11:37 PM
