#85 |
Drives: BRZ Limited
#86 | |
The HU has 3 ports and my guess is they aren’t all treaded the same way. One probably handles USB storage while the other handles Android Auto/CarPlay. I never use USB storage so I would just connect the port that handles CarPlay to the OEM port. |
| The Following User Says Thank You to ermax For This Useful Post: | nwgabrz (05-03-2021) |
#87 | |
Drives: Asphalt FR-S
Sent from my Pixel 5 using Tapatalk |
| The Following User Says Thank You to Rican_D For This Useful Post: | nwgabrz (05-03-2021) |
#88 | |
Can you not pick which port goes to the factory plug? |
#89 |
Drives: BRZ Limited
Would like to know as well. It seems having the port, regardless of which one, connect to the factory plug is what causes it to crash (the adapter), from what OP seems to imply, but would like clarification as well.
#90 |
The USBs come as harnesses that plug to the rear of the head unit. They included one harness specific for our car to retain the factory USB. The other USB harnesses are female USB ports you can place wherever you want. I have it plugged to a USB hub in my glove box.
#91 | |
So this is a job for a soldering iron. No big deal. Thanks for answering all of our questions. |
#92 |
#93 |
#94 |
#95 |
Maybe the harness Teyes provides only feeds the outer pins (power) and not the inner pins (data). The OEM port for sure has data pins because you can plug in an iPhone and get full automation of your music library over USB (and better sound quality than BT). At least on my 2013 FR-S with touch screen.
#96 |
One question that I've seen conflicting answers for. Will it Bluetooth tether for data or is it strictly WiFi tethering? If it's WiFi only that will be a massive pain in the ass because on the iPhone you would have to manually go into the Personal Hotspot settings to activate the hotspot every time you get in the car.
#97 | |
#98 | |
Certs You Dont Care About
Drives: 2013 Galaxy Blue BRZ
Often times it is the cable quality not being able to transfer enough data for AA to run. Your best bet is to ensure you get a high-quality USB3.0 cable to run AA. It's very sensitive to that. |
| Android based stereo vs. stereo w/ Android auto | redlined600 | Electronics | Audio | NAV | Infotainment | 12 | 02-24-2019 03:53 AM |
| 200mm android head unit with android lollipop | rsingh | Electronics | Audio | NAV | Infotainment | 3 | 05-23-2016 09:48 PM |
| WTB: Android HU | tonypalomo | Want-To-Buy Requests | 0 | 01-12-2015 04:00 PM |
| Help|Best Android based HU | redsuns03 | Electronics | Audio | NAV | Infotainment | 14 | 07-28-2013 09:30 AM |
| Android vs iOS vs BB os...which is best? | Raiden | Off-Topic Lounge [WARNING: NO POLITICS] | 19 | 02-02-2011 11:37 PM |
