#281 | |
The Dictater
Drives: '13 Red Scion FRS
1. Their marketing, for years, has been describing their (not that great) level 2 system as if it were a level 3+ system. The use of FSD is evidence of that. 2. They give the car too much leeway to make it's own decisions without adequately communicating those decisions to the operator, especially regarding timing and maneuvers. The car can suddenly do something unexpected requiring instantaneous reaction from the driver. This actually makes the "machines react faster than humans" cause the opposite problem. Hence the unguarded left tun videos from a while back. Anyway, it totally ruins the concept of redundant control authorities. The human is out of the loop until the car actually does something, and then control authority takes too much time to switch. |
| The Following 3 Users Say Thank You to Spuds For This Useful Post: |
#282 | |
Drives: Q5 + BRZ + M796
https://www.tesla.com/support/autopilot 2. That makes sense, and if the car is not warning people before a dramatic input by the computer or warning the person to assume control fast enough then that is definitely on Tesla. I also believe Tesla should be actively trying to fix these issues because there needs to be redundant systems like recognizing the neighborhood or something than just allowing these occurrences to happen. A driver could intervene, but if they ever want to get to robotaxis for 4/5 autonomy then these type of issues need to be sorted, but these issues are far different than users being morons with their possessions. I'm more of the mind that "guns don't kill people, people kill people", as it applies to these idiots, but I can get behind the sensible things you just mentioned. https://www.extremetech.com/extreme/...rate-to-85-mph
#283 | |
I go back to my example about summon mode. Do you think Tesla is willing to accept blame if that inadvertently runs over an infant, or even a stray black cat laying on the black tarmac who somehow doesn't get picked up by the sensors, or is the fault of the car owner? At that point, Tesla is driving the car. As far as the tweet, yes, I agree it's Tesla's responsibility to protect their user's data. I also think it is a perfect example of how Musk is using the situation for his own purposes, rather than addressing the concern. So, if the car wasn't on Autopilot, did the phantom driver just leave the car? Did Autopilot turn itself off right before the accident so technically yea, it wasn't own when it hit the tree but is was on 5 seconds before? Show me another manufacturer that is having these same issues with a similar type system and I'll agree, yea, they are being irresponsible. Like it or not Tesla, and Musk, are being irresponsible at this point, IMO.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | soundman98 (04-20-2021), Spuds (04-20-2021) |
#284 | |
Once the warrant is served then the police will get the specifics, but Tesla shouldn't volunteer anything in my opinion until then to protect our amendment rights. I'm curious as well. If I read the article carefully enough, it sounds like they were test driving the car. I don't know if this was from a private seller or from an used car dealership, but it sounds like they were told the car could drive itself, so they were in the front passenger and rear seat. Was there a driver ever and did the person move to the passenger seat, or did someone leave the scene? I don't know. Were tricks used and warnings dismissed to allow the car to drive without a driver? Most likely. I think Musk is saying something to handle the negative PR, while not giving more, so he doesn't get into a 4th amendment issue, which both seem reasonable. Well, following my point before, it would be good to be logically consistent across all manufactures and all systems, and not special plead to Tesla or to just driving assistance packages, but to answer your question, Tesla's system has been on the market for a much longer time, and unless I am mistaken, it is available for use in many more locations. Is Supercruise, for instance, only available on certain roads or certain highways that have been lidar mapped? I don't know if Tesla's systems are directly comparable. How many Supercruise vehicles are on the road and how limited are their capacities? Maybe that is a pro for your point, but it seems that Tesla's approach is about less babysitting and less regulations and less nannies, kind of like my gun ownership example or other driver/pedestrian protection and limitation examples. https://gmauthority.com/blog/gm/gene...-super-cruise/ I'm curious if Tesla has settled cases or if they are just lucky to not lose lawsuits, but I am unaware of a case where the systems were found at fault. Is that telling, or is that just a case of Tesla paying off the plaintiffs? I don't know. All I am aware of is the Germany lawsuit that said the language in Musk's Tweets is misleading, partially because his timelines are off like saying the system will be fully autonomous by a given date, but that didn't happen, or by not being clear enough with his tweets what level the systems are actually capable of.
#285 | |
Super-Cruise is limited to measured and tested highways. And, yes, I do think that is a better system at least as a start down this path. It also is much more proactive in its monitoring of the driver, even in inadvertent distraction (looking down too long, falling asleep, etc). As you, unsure about the legal cases.
| The Following 3 Users Say Thank You to Dadhawk For This Useful Post: |
#286 | |
This article is interesting. They tested hands-on reaction times with an engaged driver issued a warning compared to hands-off reaction times with a poorly engaged or typical driver. Times were worse. I actually rarely drive with cruise control on because of this very fact. If I am normally driving, and I need to stop suddenly, then as I lift off the accelerator the car starts decelerating and then it decelerates faster, as I press the brake, but during basic cruise control, my foot is on the floor like it would be on the accelerator, and I have to move it to the brake. The reaction time is similar, yet it is typically longer and clumsy because my foot is on the floor and not poised next to the brake, but the effect is that there is a more abrupt transition from throttle input to immediate braking, and there is slightly more distance traveled by the car. This is compounded if I was driving with my knee while on cruise control, or if I had a hand on the radio or shift knob, and the evasive maneuver requires two hands. I don't know if the delay is as bad as an extra two seconds, but it is definitely greater than normal. This article suggests that all systems will inherently be worse when the driver has their hands off the wheel, and especially if they are disengaged from facing the road. I don't know how sensitive Supercruise or Subaru's driver monitor system is at warning the driver to look at the road. With these systems coming around for driver assistance packages, it makes me wonder if they will use them all the time, even when the system isn't activated, so it can reduce distracted driving, or if these systems will be limited to hands-off driving or only when assistances are on. https://www.caradvice.com.au/699131/...actions-study/
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Dadhawk (04-20-2021) |
#287 | |
As far as Super-Cruise it uses an infrared camera to monitor a person's position in the car, including where your eyes are pointing. https://www.consumerreports.org/car-...20road%20ahead.
#288 | |
The Dictater
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | Dadhawk (04-21-2021), Irace86.2.0 (04-21-2021) |
#289 |
ProCrastinationConsultant
i will say, tesla is the only car maker that has ever required i learn the definition, interpretation, and operation of an aviation system in order to understand their usage of the terminology in a ground-based a vehicle system.
i feel like i'm halfway to being a pilot now!
| The Following User Says Thank You to soundman98 For This Useful Post: | Dadhawk (04-21-2021) |
#290 | ||
Interesting article. Supercruise seems well made for a very limited scope of abilities. I wonder why GM doesn’t monitor the driver when Supercruise is not engaged for distractions and engagement. It will be interesting to see if Supercruise will be able to keep up with Tesla’s system in performance or function in the future if they have to lidar map all roads for it to work everywhere. Also interesting that Tesla scored low on driver monitoring, but scored higher on emergency driver monitoring, as if it had the capacity to do more monitoring, but it chooses not to, and this seems like differences in state laws about gun laws or things such as open carry. Seems other manufacturers are doing what Tesla is doing. Maybe the media just enjoys reporting on Tesla. Good click bait. Quote:
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Dadhawk (04-21-2021) |
#291 | |
https://en.m.wikipedia.org/wiki/Supercruise
#292 | |
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | Spuds (04-21-2021) |
#293 | |
I mean if the software can't do something as simple as pulling out of a garage without failing, is it really ready for a Walmart parking lot?
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". Last edited by Dadhawk; 04-21-2021 at 10:03 AM. |
| The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | Irace86.2.0 (04-21-2021), Spuds (04-21-2021) |
#294 | |
It isn’t perfect like how no one is perfect. Maybe it was in beta then it was at the driving level of a geriatric driver and maybe now it is better. I don’t know. With millions of Teslas in the world, there will likely forever be content on YouTube of the system failing, just like humans. This doesn’t give us a metric of the rate of failure. With trillions of searches a year, Google sees a lot of searches, yet for years they have been saying somewhere are 15% of searches are unique. In a similar way, neural networks will improve and improve, but there will likely always be something unique that throws it off. If it isn’t already there, systems like summon will likely outperform humans in having less incidents, but they don’t need to outperform humans or be perfect; they need to not be worse. I can’t really speak for the video. I don’t know if this was a beta or when it was taken. I don’t know if there was a glare on the pavement that looked like an obstacle or some lines on the driveway that tripped up the cameras or what. It almost looked like it was trying to avoid the garage in front of it, but it is hard to see from that angle. I also feel like this was a woman-behind-the-wheel scenario because the second the car started pointing itself away from me, I would have stopped it, but she just kept going. That part of it is odd. Maybe her GPS location/signal was jumping around if that confused the car, but all I can do is make baseless conjecture.
| Tags |
| youguysneedlives |
| Planet Earth: The Car Enthusiast | sniffpetrol | Other Vehicles & General Automotive Discussions | 1 | 02-03-2018 11:54 PM |
| Planet Eclipse Geo2 | Gt86_nick | Miscellaneous | 0 | 11-01-2014 11:53 PM |
| Planet Audio 2250D amplifier | Noob4Life | Audio/Visual, Electronics, Infotainment, NAV | 1 | 09-16-2013 08:33 AM |
| Like saving the planet? read this | carbonBLUE | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 02-14-2013 07:09 PM |
