| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: WR Blue Pearl 2022 Subaru BRZ
2nd Gen front side air intakes - what are the benifits
So I'm not fully versed on what's going with these front side air intakes. I'd really love someone who is well versed in this to add their thoughts.
I assume that its for break cooling, but how does it achieve that when it 'seems' to be just directly hitting the front tires. In fact, as yet I haven't seen anyone sticking things into it to show if there is any piping to direct that air right into the break. Could it be actually for tire cooling? I get that, at speed, the vents at the rear of the front tire will actually suck air away from the wheel area, and therefore cool the breaks, but is it a case of that it really needs that front side intake to be able to do that properly? |
#2 |
Drives: '15 BRZ RA
They were saying that it is basically for improving aerodynamic efficiency. Pretty useless for me on a street car under normal highway speed limits. Reminds me somehow the persistence to go with the big rear carbon wing in the BRZ tS. These solutions are just for the looks and adding to the wow effect (real vents!), but without much effect in reality. They can work only in race tracks like the Nürburgring Nordschleife where you can go top speed.
Brake cooling will be a small side effect of these vents, but without proper air ducts it won't be optimal at all. |
| The Following User Says Thank You to nikitopo For This Useful Post: | Tcoat (04-12-2021) |
#3 | |
With a bit more cold air to the breaks, the car might be better for those extended break cycles or it might just be all for show, as you say. |
#4 |
From the Subaru press release:
"The aggressive design flows into bold front fenders with a large side vent. The functional side vent reduces drag by ducting air from under the hood and fenders. The released air is directed to a side sill spoiler that creates downforce at speed" There will most certainly be at least a bit of cooling to the engine bay and possibly the brakes but their prime purpose (or at least explanation) is aero related not heat management. I am still of the opinion, that when you consider they are moving air from the bay and have added an oil cooler they are addressing a heat issue with the 2.4. Side vents are an expensive way to give a small aero effect.
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | Blighty (04-12-2021), BRZoomTX (05-04-2021), daiheadjai (04-12-2021), nikitopo (04-12-2021), spike021 (04-12-2021) |
#5 |
CAD monkey
Drives: '15 GT86 Giallo - Supercharged
I guess they will probably reduce the high air pressure build-up in the front wheel well.
Reducing the high P inside the well could lead to more air being sucked into the "brake area" thus providing a cooling effect for the brake system. Just a guesstimate
| The Following User Says Thank You to Boccaccio For This Useful Post: | CatDaddysBBQ (07-07-2021) |
#6 |
CAD monkey
| The Following User Says Thank You to Boccaccio For This Useful Post: | Blighty (04-12-2021) |
#7 |
The Dictater
Drives: '13 Red Scion FRS
Fuel economy by drag reduction is my bet. I've seen these start to pop up on some boring cars too. In fact they were so boring I forget what I saw them on.
| The Following 6 Users Say Thank You to Spuds For This Useful Post: | Ash_89 (04-13-2021), Blighty (04-12-2021), jcw99 (07-19-2021), spike021 (04-12-2021), Ultramaroon (04-12-2021), x808drifter (04-12-2021) |
#8 | |
The front side intakes aren't really explained. |
#9 | |
As Niki said earlier the aero effect will probably be totally valueless under most driving conditions. The cooling effect will be even less.
#10 |
Drives: -
Actually on some cars the vents behind the front wheels reduce drag enough to bump it up 1mpg on the highway, BMW made a big deal about it on the F3X 4 series.
#11 |
I can buy that.
#12 |
#13 |
Drives: _
It's for bugs to not die on impact. Instead, they could fly thru the vents and back out alive, safely to their families.
#14 | |
| LF front driver side headlight and front bumper 2013+ frs | crakajakz | Canada Classifieds | 2 | 01-31-2020 12:33 PM |
| WTB: Front end parts, stock intakes, radiators, headlights, etc | Dave-ROR | Want-To-Buy Requests | 6 | 03-03-2019 03:10 AM |
| WTB: Front end parts, stock intakes, radiators, headlights, etc | Dave-ROR | Southeast | 0 | 02-28-2019 12:37 AM |
| WTB> 2013 (WHITEOUT) OEM Front Bumper/Side Fender (Driver's Side) | eddieEndo | Want-To-Buy Requests | 0 | 06-20-2017 12:22 AM |
| WTB: Raven front bumper plus front underpanel and passenger side front fender liner | THEmailman | Want-To-Buy Requests | 1 | 04-20-2014 01:05 AM |
