Old 04-08-2021, 03:09 PM   #1
tommy5gun
Brz 2013 AT passenger side rattle
So I’ve been having this rattle or a TAPTAPTAP SOUND on the passenger side of the engine bay. It only appears when the car is warmed up. Most audible at low rpms. In the video I’m holding it at about 1500rpm. Regular mechanics say it might be lifters but I’ve seen that for some people the issue is vacuum pump. Please help !!!!!!
https://www.dropbox.com/s/4n9q3pr40y...le%20.mov?dl=0
tommy5gun is offline   Reply With Quote
Old 04-08-2021, 03:26 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The "lifters" in our engines don't really move, they pretty much just serve as a pivot point for the rockers and the valve lash specs indicate this is the case as well.
Does it change with engine temps, worse at low/high temps?
Old 04-08-2021, 03:42 PM   #3
tommy5gun
Yeah it sounds more audible when the car is warm , there’s no sound of that on the start up at all . Also gets faster with rpms.
Old 04-08-2021, 03:48 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Best thing to do is to isolate where the noise is coming from with a stethoscope, or a big screwdriver. Then work from there.
Old 04-08-2021, 03:53 PM   #5
tommy5gun
Yeah , that’s what the mechanic did and he said they’d have to take out the engine to
figure out what it is . Have u listened to the sound ?
Old 04-08-2021, 03:58 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, and to be honest it kind of sounds like an exhaust leak. But if the mechanic has already listened to it, he has likely determined that is not the case. It's really hard to tell through the video.
Old 04-08-2021, 03:59 PM   #7
tommy5gun
Should I give it to the mechanics at a Subaru dealership?
Old 04-08-2021, 04:54 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Sounds like it would be your best option. We can only speculate the issue online, it's much more difficult if you don't do your own work.
Old 04-08-2021, 08:18 PM   #9
Vacuum pump on the AT cars. Common issue
NoHaveMSG (04-09-2021), theneptune86 (04-09-2021)
Old 04-08-2021, 11:19 PM   #10
tommy5gun
Should I just try replacing it without being sure it is the problem ?
Old 04-09-2021, 07:42 AM   #11
Always confirm first but that sounds exactly like the booster pump. It is only an issue on the ATs.
Old 04-09-2021, 10:07 AM   #12
tommy5gun
Yeah I have AT , and I can’t really confirm the sound because every mechanic I go to says it’s the lifters.
Old 04-09-2021, 10:14 AM   #13
It does sort of sound like lifters if you don't have a comparison.
Old 04-09-2021, 10:18 AM   #14
tommy5gun
I guess I have an option either to spend money at diagnostics at the Subaru dealership or just replace the vacuum pump hoping that’s the problem
WTB clear side marker (passenger side) luluma Want-To-Buy Requests 4 09-15-2018 12:49 PM
WTB: passenger side amber side marker NJ-JDM Want-To-Buy Requests 4 05-18-2016 06:37 PM
WTB: Passenger Side Clear Side Marker Sheepdog Want-To-Buy Requests 0 08-03-2015 09:56 PM
WTB: Drivers side and passenger side fenders condition don't matter Hollwood_lives Canada Classifieds 5 07-30-2015 05:53 PM
WTB: orange OEM side marker (passenger side or both) Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 4 09-05-2013 05:46 AM
