Old 04-06-2021, 07:02 PM   #15
bfeeney
Drives: 2015 Scion FR-S
Thanks for the replies everyone. Maybe I should have started with a different question rather than a question about a solution. Does anyone else feel the steering starting to get loose at 80mph? It feels like the front end is lifting a tiny bit and I start loosing that tight steering feel
bfeeney is offline   Reply With Quote
Old 04-06-2021, 07:47 PM   #16
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
how hard or sharp are you turning..? I regularly take highway loops at 80+ and I don't feel like I'm losing control of the front end even when it goes over uneven expansion joints...plus naturally steering feel should get lighter at higher speeds or am I missing something here.
HKz is offline   Reply With Quote
Old 04-06-2021, 09:33 PM   #17
bfeeney
No turns, just straight line 80+. If that's the way cars are suppose to be then maybe I was missing something. It just feels a little less grippy up there. Maybe I'll just drive slower lol
Old 04-07-2021, 07:50 AM   #18
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Toss a front splitter and some canards on, that should add the downforce you're looking for at high speeds.
Old 04-07-2021, 06:04 PM   #19
86league
Drives: '13 BRZ Limited
If it's feeling noticeably less grippy at only 80, I'd make sure the basics are right before adding downforce.
How's the alignment?
86league is offline   Reply With Quote
The Following 3 Users Say Thank You to 86league For This Useful Post:
cjd (04-10-2021), NoHaveMSG (04-07-2021), Overdrive (06-08-2021)
Old 04-07-2021, 06:19 PM   #20
RayRay88
Drives: 2017 86 860 Special Edition
Lets start with alignment specs, tire pressures and tires.
RayRay88 is offline   Reply With Quote
The Following User Says Thank You to RayRay88 For This Useful Post:
Old 04-07-2021, 08:43 PM   #21
Ernest72
Originally Posted by jflogerzi View Post
I am starting to get all the pieces for a flat bottom why because racecar. So far I have the following
Splitter up front
OEM Under Panels
Verus Trans Tunnel and rear Suspension covers
Just need the diffuser and diff cover
If you are tracking some of those panels could lead to heat building up in your rear diff because it does not get any air, do a search on it. On the street it’s not likely an issue,
Old 04-07-2021, 10:17 PM   #22
bfeeney
I just got the car a few weeks ago, so I haven't really done anything to it yet. It came with 235/40-18 up front and 265/35-18 in the back. I forget the name of the tires, but they're brand new and Z rated. Stock suspension, TRD swaybar.
Old 04-08-2021, 01:38 AM   #23
Pat
Pat's Avatar
Drives: 2023 BRZ
Well there's your problem. Put the same size tires on all four corners and report back.
The Following User Says Thank You to Pat For This Useful Post:
MICHAEL450f (04-09-2021)
Old 04-08-2021, 11:08 AM   #24
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I bet that car had other mods and they returned it to mostly stock before selling. I’d start with alignment.
Old 04-09-2021, 07:47 PM   #25
bfeeney
It did come with the wheels, TRD swaybars, TRD catback, Crawford intake spacers and HKS air filter. I'll get an alignment here soon.
Old 04-09-2021, 08:25 PM   #26
86TOYO2k17
Drives: 2017 toyota 86
They are same diameter. Just different width.
Old 04-09-2021, 08:29 PM   #27
86TOYO2k17
I had the following, did wonders for high speed stability.
Greddy Gracer Front Lip
Beatrush Undertray
JDM Aero Underpanels
OEM 86 Rear Spoiler
Verus Front Wheel Deflectors
Verus Trans Tunnel Covers
Verus Rear Aero Spats
FT-86 Speedfactory Rear diff covers
FT-86 Speedfactory Rear Diffuser
TRD Front Fender Fins
TRD Trunk Stabilizer cover
TRD Aero Turbulator
STI Side Skirts
The rear diff is still relatively exposed, but i did have rear diff cover with extra capacity and “heatsink fins”
Old 04-10-2021, 02:26 AM   #28
Pat
Pat's Avatar
Drives: 2023 BRZ
Beatrush Undertray
OEM 86 Rear Spoiler
TRD Aero Turbulator
STI Side Skirts
High speed stability can be achieved with exactly zero of those modifications. That said, I would love to drive a car with all of those modifications to compare it directly to one without. I'm skeptical I would feel any difference.
Fiberglass underbody panel upgrade? YamahaR86 Cosmetic Modification (Interior/Exterior/Lighting) 10 01-14-2020 12:04 PM
"duct" panel near underbody is loose and rattling Spacemane969 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 01-01-2020 03:12 PM
WTB underbody panel EvolutionRevolution Want-To-Buy Requests 0 10-23-2019 09:49 PM
Effectiveness of a Lightweight pulley DrifterX Engine, Exhaust, Transmission 94 12-11-2016 02:10 AM
Window tint/ Air 80 Effectiveness Da Brz Cosmetic Modification (Interior/Exterior/Lighting) 0 07-11-2016 11:15 AM
