Old 04-05-2021, 08:20 AM   #1
SCFD
SuperPro 22mm Front Sway Bar
I was looking for a stiffer front sway bar that wouldn't potentially overburden the tires and settled on the SuperPro 22mm front sway bar.
There was no noticeable change in NVH but the car seems to have gained extra compliance over bumps and feels like it rides better than stock. I'm not sure if this is due to a different geometry with this bar or the use of poly bushings.
I also took some quick measurements (bathroom scale only good for 0.5lb increments).
Stock: 6lbs, 18.50mm (2017+ BRZ)
SuperPro: 8.5lbs, 22.19mm
I would've taken more photos but my endlinks put up a fight. https://www.instagram.com/p/CNQtauun4FO/
SCFD is offline   Reply With Quote
The Following User Says Thank You to SCFD For This Useful Post:
nathand (04-06-2021)
Old 04-07-2021, 01:46 PM   #2
nathand
Drives: 2016 HyperBlue
Did you get the hollow 22mm bar or solid?
On many vendor sites it is not clear to me if it is hollow or solid.
I have seen two different part numbers.
RC0015FHZ-22
RC0015FZ-22
I wonder if they stopped making the hollow bar?
I don't see it on the mfg site.
nathand is offline   Reply With Quote
Old 04-07-2021, 07:33 PM   #3
SCFD
RC0015FHZ-22
RC0015FZ-22
The part number on the packaging was RC0015FZ-22 but I can't confirm if it's hollow or not. I would guess that it's hollow but if somebody can chime in what the Perrin 22mm bar weighs then that might give us an indication whether it's solid or hollow.
Old 04-13-2021, 09:41 AM   #4
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I'm surprised you went with a 22m for D street without being able to do other modifications like springs/coilovers. From what I've read, 22mm (solid) might pushing it in the front without tailoring the rear or other components.
I'm looking for my front sway size and generally see 20mm is a good size given the stock is 18mm. That 2mm jump really increases the stiffness.
I have large 24mm bars on my WRX, both front and real. I felt the car actually handled worse with them. They're almost too stiff, wheels pick up a lot at autox, front and rear.
Although after seeing some pictures from this weekend, I really need to get one for the BRZ. I'll at least keep 22mm in mind.
cmiovino is offline   Reply With Quote
Old 04-13-2021, 07:05 PM   #5
SCFD
I went for the SuperPro sway bar under the impression it was a 22mm hollow bar. However, after digging around, I think it might be a solid bar since I found the Tanabe 22mm hollow bar weighs in at 6.5lbs and the Eibach 25mm weighs in at 7.5lbs.
I was hoping to get something like the Tanabe with increased roll resistance but minimal weight gain. I haven't had a track/autocross event yet but I don't think a 200TW tire will have too much trouble coping with this bar.
[SOLD] FS: Strano 22mm Front Sway Bar 6MTGirl Brakes, Suspension, Chassis 1 08-18-2020 07:49 PM
FS: Strano 22mm Front Sway Bar toeout Brakes, Suspension, Chassis 0 04-25-2017 06:47 PM
FS: NY - Whiteline 22mm front sway bar w/ endlinks TallTerror13 Brakes, Suspension, Chassis 2 02-20-2016 07:28 PM
FS: Strano Parts 22mm Front Sway Bar NYC BRZ Brakes, Suspension, Chassis 2 10-28-2013 10:03 PM
22mm Tubular Front Sway Bar $130.00 AX FRS Brakes, Suspension, Chassis 2 03-04-2013 06:14 PM
