Old 02-24-2021, 10:36 AM   #155
Racecomp Engineering
The front springs are wound and done! Yes!
We're now waiting on the rear springs...which of course is a different work order...and why isn't that immediately after the front springs? Dunno! I'm sure there's a reason. But we know it's coming up very soon. Really excited to have the end in sight!
- Andrew
The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post:
beanswv17 (02-24-2021), Cosworth_0686 (03-01-2021), grumpysnapper (02-25-2021), Spankopotomous (03-02-2021), Spawn_Of_Creation (02-24-2021), WolfWings (03-09-2021)
Old 03-12-2021, 05:19 PM   #156
HAVE A GOOD WEEKEND EVERYONE!
*production springs will not be yellow. that would be...uhh...problematic with our other springs. i'm excited about the color we've chosen for the production springs.
The Following 12 Users Say Thank You to Racecomp Engineering For This Useful Post:
beanswv17 (03-13-2021), BigTuna (03-12-2021), churchx (03-13-2021), Cosworth_0686 (03-17-2021), Dzmitry (03-15-2021), grumpysnapper (03-13-2021), Jdmjunkie (03-12-2021), RToyo86 (03-13-2021), Spankopotomous (03-17-2021), Spawn_Of_Creation (03-14-2021), Stonehorsw (04-02-2021), Ultramaroon (03-18-2021)
Old 03-12-2021, 05:28 PM   #157
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
BigTuna is offline   Reply With Quote
The Following 2 Users Say Thank You to BigTuna For This Useful Post:
Capt Spaulding (03-12-2021), Racecomp Engineering (03-12-2021)
Old 03-13-2021, 08:20 AM   #158
beanswv17
beanswv17 is offline   Reply With Quote
The Following User Says Thank You to beanswv17 For This Useful Post:
Racecomp Engineering (03-13-2021)
Old 03-17-2021, 09:43 PM   #159
Update:
We've got the prototype springs on and we're doing some testing! You may have seen pictures of the springs in the Bilstein thread. I'm not going to share pics of ride height yet because that will at least change slightly. Spring rates I think we're spot on and they feel awesome especially with the Bilsteins (and still very good with the OEM dampers).
Remember these are just prototypes. And they won't be yellow. The good news is we'll be able to go production pretty quickly when we sign off. More updates when I can...busy days over here.
- Andrew
The Following 7 Users Say Thank You to Racecomp Engineering For This Useful Post:
beanswv17 (03-18-2021), Cosworth_0686 (03-19-2021), Grawlix (03-18-2021), Spankopotomous (03-18-2021), Spawn_Of_Creation (03-18-2021), spike021 (03-18-2021), TimeForLove (03-18-2021)
Old 03-18-2021, 09:37 AM   #160
TimeForLove
Drives: 2013 BRZ 2001 Impreza RS
Interested! Rallycross season is fast approaching!
TimeForLove is offline   Reply With Quote
The Following User Says Thank You to TimeForLove For This Useful Post:
Racecomp Engineering (03-18-2021)
Old 03-21-2021, 06:08 AM   #161
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
I'm pretty much ready for these to drop.
Ive got Bilstein B6 shocks, with new top hats, boots and rear bump stops, 1" Subtle Solutions aluminum lift kit + 1.5" rear alignment kit, SPL Camber Bolts, Whiteline rear LCA, and Method MR502 16x7 +30 wheels.
Still need to put the tires on, but going with 215/65/16 General Grabbers.
I picked up the Chuhatsu springs a while ago in case these fell through, but I'd really prefer these.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
The Following 2 Users Say Thank You to Spawn_Of_Creation For This Useful Post:
BigTuna (04-04-2021), Racecomp Engineering (03-21-2021)
Old 03-30-2021, 06:46 PM   #162
Update: waiting on second set of prototypes. The spring rates on the first are spot on and feel great, but as mentioned the ride height was not exactly what we specified. We'll get another set in here soon. That should move quickly. Prototypes aren't usually "off" the specs like this but at least we have another good data point.
Testing with all OEM parts as well as Bilstein B6 with Pedders offset top mounts.
- Andrew
The Following 10 Users Say Thank You to Racecomp Engineering For This Useful Post:
beanswv17 (03-30-2021), BigTuna (04-04-2021), Capt Spaulding (03-31-2021), Cosworth_0686 (03-31-2021), Dzmitry (03-31-2021), Spankopotomous (03-31-2021), Spawn_Of_Creation (03-30-2021), spike021 (04-08-2021), Stonehorsw (04-02-2021), Turdinator (03-30-2021)
Old 04-07-2021, 02:10 PM   #163
Plumpywing
Plumpywing's Avatar
Drives: 2014 Scion FR-S Asphalt
- Andrew
Would you be selling a complete set up with b6, the springs, and the pedders front mounts?
very interested in seeing how this setup does for people doing mild rallyx and winter driving
Plumpywing is offline   Reply With Quote
The Following User Says Thank You to Plumpywing For This Useful Post:
Racecomp Engineering (04-07-2021)
Old 04-07-2021, 08:22 PM   #164
That's the plan! I'm testing them in that configuration and we currently also sell the Bilsteins. We need to set something up with Pedders but we'll get there.
Also, even though the ride height isn't where we want it with these first prototypes, the spring rates are and they are hysterical fun with Bilsteins on 195 winter tires around town. Also testing with 225/45/17 Michelin Pilot Sport 4s though...
- Andrew
BigTuna (04-08-2021), Capt Spaulding (04-08-2021), grumpysnapper (04-08-2021), scuzzy (04-07-2021), Spankopotomous (04-09-2021), Spawn_Of_Creation (04-07-2021)
Old 04-07-2021, 08:28 PM   #165
scuzzy
Drives: 22 BRZ limited MT
Following this with great interest!
scuzzy is offline   Reply With Quote
The Following User Says Thank You to scuzzy For This Useful Post:
Old 04-08-2021, 11:30 AM   #166
BigTuna
BigTuna's Avatar
Between this setup coming out and Speed Academy building a safari FRS... I'm so torn between a traditional track build vs a RallyX car.
grumpysnapper (04-09-2021), Racecomp Engineering (04-08-2021)
Old 04-09-2021, 12:22 PM   #167
grumpysnapper
grumpysnapper's Avatar
Go dirt.... you will have an absolute ball, and the setups work really well on real world (back) roads too.
grumpysnapper is offline   Reply With Quote
The Following User Says Thank You to grumpysnapper For This Useful Post:
Racecomp Engineering (04-09-2021)
Old 04-09-2021, 02:26 PM   #168
BigTuna
BigTuna's Avatar
I did one RallyX event 2 years ago and had an absolute blast. However, I cracked my bumper (more than it already was) and ripped out a fender liner, so I haven't been back. But the bug is still inside me!
The Following User Says Thank You to BigTuna For This Useful Post:
Gauging interest for an OEM exhaust in GTA StraightOuttaCanadaEh Canada Classifieds 5 06-08-2017 02:00 PM
Gauging interest in ACE 150- Type B olsonpg Canada Classifieds 3 07-12-2016 08:10 PM
Gauging Interest ISC Suspension Announcements, Contests, Giveaways 17 04-03-2014 10:44 AM
Jdm headlights - gauging interest Hawk77FT Exterior Parts (Aero, Lighting, Etc.) 7 03-31-2014 10:38 AM
Gauging Interest Rear Diffuser SunkenFRS Cosmetic Modification (Interior/Exterior/Lighting) 20 10-07-2013 05:28 AM
