Old 04-04-2021, 02:30 PM   #1
bfeeney
Drives: 2015 Scion FR-S
Underbody Panel Effectiveness...
Hi everyone. Happy Easter! I'm new to the forum here, and new to these cars. I was wondering if anyone has done a full underbody panel kit with diffuser with a stock (height) suspension? Do they have a noticeable effect with that height? I know that an underbody kit works better the lower the car is, but for a DD I don't think I want to go that low. To back up, my last car was a '99 Prelude SH on Tein coilovers and was set to have about 3" clearance to the lowest point. The car looked cool, but it has its draw-backs. #1 I scrapped the ground a lot (of course), #2 I couldn't go through a car wash because I would bottom out on the guide rail. My plans for my FR-S is to do a full underbody kit to increase the downforce at interstate speeds, but I still want to go through the wash and I dont want to destroy the $600 diffuser every time I back out of my driveway. Has anyone done these aero mods with a stock height? Thanks everyone
bfeeney is offline   Reply With Quote
Old 04-05-2021, 02:01 PM   #2
norcalpb
norcalpb's Avatar
Not stock height but was on STi springs (only 10mm drop) with my diffuser/suspension covers/unbody panels, I never scraped the diffuser. You should be totally fine.
Also you won't be adding downforce but rather reducing lift and drag.
Old 04-05-2021, 02:23 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The Following 4 Users Say Thank You to NoHaveMSG For This Useful Post:
alphasaur (04-05-2021), churchx (04-08-2021), Jdmjunkie (04-05-2021), Mike_ZN6 (04-05-2021)
Old 04-05-2021, 02:56 PM   #4
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Smoothing the air below and lowering pressure underneath the car, maybe?
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 04-05-2021, 03:07 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
Does our "sports" car generate enough momentum to kick-start underbody aero-shenanigans?
Old 04-05-2021, 03:07 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
All the info:
https://www.verus-engineering.com/informative-packets
bmacfrs (04-05-2021), Cephas (05-23-2021), Grady (05-26-2021), jeepmor (10-05-2021)
Old 04-05-2021, 04:39 PM   #7
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Oh dang. According to those CP charts, yeah, lowering pressure underneath definitely does help.
Old 04-05-2021, 05:19 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It is also quite efficient.
Old 04-05-2021, 07:38 PM   #9
bfeeney
That's good to know. I would hate to damage such a pretty piece like a diffuser. I might get a set of TRD springs at some point, they have a 1" drop. That can't be any worse than the Prelude lol. Thanks
Old 04-05-2021, 07:39 PM   #10
bfeeney
That's awesome. Thanks
Old 04-05-2021, 07:45 PM   #11
bfeeney
I know I'm not going to get F1 effects here. Those panels start working right about where I'm having troubles, so every bit will help. I have an Electro-Mechanical degree, not Aeronautical.
The Following User Says Thank You to bfeeney For This Useful Post:
JD001 (04-06-2021)
Old 04-05-2021, 07:58 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
1" drop is pretty mild, you should be okay everywhere but the steepest driveway entrances/exits. I'm at around -2.5" right now with a splitter and diffuser and as long as I am paying attention, I don't scrap.
Old 04-06-2021, 08:28 AM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
Aero engineer here. For sure way way less effective at stock ride height. If you look at the Ventus stuff you see their model is slammed. Also, the application is for cruising at freeway speeds? A smidge more downforce/less lift is going to make no real difference for you. If you want it for looks that's fine. But it's not going to be doing anything useful for you, I don't think...
The Following 4 Users Say Thank You to ZDan For This Useful Post:
Bonburner (04-06-2021), NoHaveMSG (04-06-2021), SCFD (04-07-2021), Wally86 (04-06-2021)
Old 04-06-2021, 06:28 PM   #14
jflogerzi
jflogerzi's Avatar
I am starting to get all the pieces for a flat bottom why because racecar. So far I have the following
Splitter up front
OEM Under Panels
Verus Trans Tunnel and rear Suspension covers
Just need the diffuser and diff cover
2013 Series 10 FRS #553
Fiberglass underbody panel upgrade? YamahaR86 Cosmetic Modification (Interior/Exterior/Lighting) 10 01-14-2020 12:04 PM
"duct" panel near underbody is loose and rattling Spacemane969 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 01-01-2020 03:12 PM
WTB underbody panel EvolutionRevolution Want-To-Buy Requests 0 10-23-2019 09:49 PM
Effectiveness of a Lightweight pulley DrifterX Engine, Exhaust, Transmission 94 12-11-2016 02:10 AM
Window tint/ Air 80 Effectiveness Da Brz Cosmetic Modification (Interior/Exterior/Lighting) 0 07-11-2016 11:15 AM
