Old 03-29-2021, 03:24 PM   #15
86league
Drives: '13 BRZ Limited
xp10's are safe bet, will be trying ds1.11 after I finish the carbotechs, I like my ds2500's but they're not fit for track duty.
I have had issues with XP10s and uneven pad transfer leading to fairly severe brake shudder. I replaced rotors and tried to be very careful bedding them in, and had the problem occur again. Talking with people at track events and vendors they say it's pretty common with Carbotech/G-loc compounds. Several people I know (BRZ/Miata owners) have moved away from carbotech due to the issue.
Carbotech pads do work for a lot of people.
I'd like to try the ds1.11, but at $531 for the front set (brembo calipers) I'll try some other options first. PFC08s will be the next pad I try ($189/set).
86league is offline   Reply With Quote
Old 03-29-2021, 03:25 PM   #16
CSG Mike
CSG Mike's Avatar
Originally Posted by Jstyle View Post
So I did my first track day in a car and I LOVED it. I had so much fun out there and my instructor (Ben) was fantastic. Having the car completely stock with just GT Radial SX2’s did me just fine. The morning sessions were in the rain and while I loved the learning opportunity of driving on the track in the rain for sure, I enjoyed the last session in the afternoon where the rain was finally cooked off.
The only thing that I feel like I need before my next track day is a new set of pads. I was thinking the CSG CX2, W5, XP10’s or Hawk HP+. This car will see really minimal street time and almost exclusively track time and I’m still at the early stages of learning. My main goal is that I want a pad that won’t fade in 20 minute track sessions and won’t eat a rotor. I’d also love a somewhat quiet and low dusting pad but those don’t matter so much.
Also I’m pretty sure the stock rotors are still on the car. Even with some pretty hard braking sessions they don’t feel warped so I don’t know if I HAVE to change the rotors. If I do, I was thinking about just going cheap and getting the Centric’s but I’m also thinking about the StopTech Slotted... But again open to opinions.
Thanks all!
My question to you would be, do you want something "enough for now", but may (will) outgrow, or do you want something that will basically be good for you forever, regardless of how fast you get?
Definitely do good brake fluid, an oil cooler, and some camber bolts as well.
That's really all you need to enjoy the car!
Note that all of these mods are sustainability mods; none of them are "go fast" parts, but rather "go longer" parts.
Old 03-29-2021, 03:37 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Every race pad is hard on rotors cold!
Yeah, I was just surprised by how much more wear. Still worth it.
I had the same experience with XP10's. I would smear them pretty badly even driving at damp slightly raining track days, could never get them to work for me. I also didn't like their spongy feeling threshold breaking.
CSG Mike (03-29-2021)
Old 03-29-2021, 03:53 PM   #18
Jstyle
Jstyle's Avatar
Drives: 2020 86
I have the braided brake lines along with Motul 660... Just need pads that can take the abuse of the heat that the brake delivery gives them
I'm prolly gonna check out an oil cooler soon as well. Next time I'll plug my obd2 scanner in there and see what the temps look like. This one wasn't bad because of rain and more rain... plus additional rain.
The CSG C2's look super tempting but damn that's pricey.
Jstyle is offline   Reply With Quote
Old 03-29-2021, 03:55 PM   #19
CSG Mike
CSG Mike's Avatar
Sounds to me like you're overheating the XP10. It's a great beginner's pad, and you've likely exceeded their capacity, based on your feedback.
You'll likely prefer the other pads you've mentioned, but I'd also recommend giving the C2 a shot, if you're considering DS1.11 money. You'll easily make up the cost in life alone.
Due to the extremely high limits of the C2, you may have difficulty burnishing the pad on a NA car without sticky tires, unless you do long sessions to build enough heat.
Old 03-29-2021, 04:10 PM   #20
86league
Thanks for the feedback. I thought about moving to XP12s or higher but I had enough trouble bedding the XP10s on the street.
I'll see how I get along with the PFCs (already purchased) and then probably try something different.
What are the expected differences between the CSG Sprint (C2) and the Track-day pads (CX1) besides price? Wondering how they compare to each other.
Old 03-29-2021, 04:12 PM   #21
CSG Mike
CSG Mike's Avatar
The CX1 is offered in a BRZ PP compatible shape, but is not recommended due to lack of a matching rear. It's listed purely because it's used on other platforms.
I'd recommend C2 front and rear.
Old 03-29-2021, 05:19 PM   #22
Jstyle
Jstyle's Avatar
Drives: 2020 86
So you'd recommend the Cx2 if I'm only doing track days not the C2 right?
Old 03-29-2021, 06:57 PM   #23
CSG Mike
CSG Mike's Avatar
C2, not CX2 or CX1, for track days.
-Mike
Old 03-29-2021, 08:23 PM   #24
jflogerzi
jflogerzi's Avatar
Get 2 different set of pads. I use Carbotech 1521's on street and XPS 10/8 for Track on the same rotors. Works great for my uses.
2013 Series 10 FRS #553
Old 03-29-2021, 08:27 PM   #25
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Second track day gonna need coils
Third track day gonna need header and tune
Fourth track day gonna need sticky tires
Welcome to the rabbit hole
Coaching will be your best use of funds
TommyW is offline   Reply With Quote
The Following 4 Users Say Thank You to TommyW For This Useful Post:
CSG Mike (03-29-2021), jflogerzi (03-29-2021), jkamelo (04-09-2021), MrSkubi (04-02-2021)
Old 03-29-2021, 10:42 PM   #26
jflogerzi
jflogerzi's Avatar
Fifth Track Day: Aero
sixth Track Day: Insert anything else you can think of
The Following 3 Users Say Thank You to jflogerzi For This Useful Post:
CSG Mike (03-29-2021), finch1750 (04-07-2021), jkamelo (04-09-2021)
Old 03-30-2021, 08:35 AM   #27
M0nk3y
Yeah DS1.11s must have shot up on cost (I remember when I could get a whole set for both axles for $400 shipped).
Boy those days are gone. Might also be just the PP Pad shape which is driving the cost, which well also makes no sense.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
strat61caster (03-30-2021)
Old 03-30-2021, 11:41 AM   #28
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Probably financial coaching based on this!
SCCA T4 - FRS
The Following 3 Users Say Thank You to rice_classic For This Useful Post:
NoHaveMSG (03-30-2021), Pat (04-01-2021), Racecomp Engineering (04-07-2021)
Bed-in? DD >< Track Pads Muskoka800 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 03-13-2020 05:59 PM
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 03:31 PM
WTB: Track Pads Whooosah Want-To-Buy Requests 3 05-03-2016 07:09 PM
FS: Hawk Hp+ Track Pads NorCal_Guy Brakes, Suspension, Chassis 3 09-08-2014 03:05 PM
Track pads available? ubersoph Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-18-2012 01:20 PM
