Old 03-16-2021, 04:48 AM   #1
dethzombi
Drives: Neptune Blue A6
2019 Toyota 86 Aftermarket Head Unit
Just recently bought a Pioneer DMH-2660Nex and just was wondering everything I need in order to keep all factory controls. According to crutchfield I would need to purchase an iDatalink Maestro RR, but is there any other way? Any help would be appreciated.
dethzombi is offline   Reply With Quote
Old 03-16-2021, 09:08 AM   #2
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
When I swapped the headunit in my FA5, I was actually glad the Maestro exists. It's super easy to install and helps bridge that gap for things like steering controls without having to dig through and splice a bunch of wires. Is there a reason you don't want to grab one?
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 03-16-2021, 09:50 AM   #3
Same here. The Mastro made it very easy to retain the steering wheel controls in my '04 Suburban when I installed a Pioneer headunit in it about 3 years ago.
Old 03-16-2021, 08:51 PM   #4
dethzombi
No reason, just wanted to know if there was any cheaper option out there, but if there's not I wouldn't mind grabbing the Maestro RR to slap in there. Was it a pretty easy install? I plan on getting the wiring harness to connect my backup camera to the head unit as well and I'm curious as to if that's going to work differently with the Maestro.
Old 03-17-2021, 08:10 AM   #5
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Super easy install. The only thing I didn't like was the need to plug into OBD for the backup camera to work in [a] manual [car] BUT I ended up just hard wiring the two wires in for that. Easy peasy and freed up my OBD port.
The Following User Says Thank You to Wally86 For This Useful Post:
timurrrr (03-18-2021)
Old 03-17-2021, 04:07 PM   #6
dethzombi
Perfect, really the only thing that bothers me about the install is the harness for the backup camera, I'm pretty sure it's going to distort the image since it'll go from like a 2.5" display to almost a 7" display, do you think it would be easier to just purchase a different backup camera and run that like a normal camera to the radio?
Old 03-17-2021, 04:09 PM   #7
So, maybe I missed this, but do newer 86/BRZ have a standard 2-DIN radio in them rather than the older "toyota sized" radio?
Old 03-17-2021, 04:23 PM   #8
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
2017 has the somewhat-odd 200mm nose piece.
LimitedSlip is offline   Reply With Quote
Old 03-17-2021, 07:53 PM   #9
dethzombi
I'm pretty sure it's about the same size, I know that a 2017 86 fit an Alpine ilx-107 which is a 2-din radio.
does 2019 BRZ head unit fit 2017 BRZ? stlgrym3 Electronics | Audio | NAV | Infotainment 3 05-20-2021 09:51 PM
2019 86 Head unit Recommendation Frankz54 Electronics | Audio | NAV | Infotainment 0 11-29-2020 02:10 PM
Maps not loading (2019 head unit) N_Raged Electronics | Audio | NAV | Infotainment 7 01-28-2020 01:54 PM
Which Aftermarket Head Unit to get ? TRD_86 Electronics | Audio | NAV | Infotainment 9 10-10-2013 08:41 AM
OEM mic with aftermarket head unit phenom86 Electronics | Audio | NAV | Infotainment 13 05-10-2013 12:20 AM
