Old 03-11-2021, 04:20 PM   #1
alone1i
Not pro yet
Drives: 2020 Toyota GT86
Why FA20 engine is noisy?
Is it because the way it is designed? Or its a characteristics of any Boxer Engines? Does WRX STI (ej20/24) also noisy like this one?
alone1i is offline   Reply With Quote
Old 03-11-2021, 04:28 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Dual injection, horizontal, over head cam, thinner exhaust manifold material, less sound deadening everywhere, etc.
The Following 9 Users Say Thank You to DarkPira7e For This Useful Post:
alone1i (03-11-2021), BrahmaBull1990 (03-11-2021), Busybee (03-12-2021), HachiRokuX (03-11-2021), JesseG (03-12-2021), joro2 (03-13-2021), JusTheG (03-12-2021), spike021 (03-11-2021), Spuds (03-12-2021)
Old 03-11-2021, 04:55 PM   #3
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
small tractor engine
HKz is offline   Reply With Quote
The Following 7 Users Say Thank You to HKz For This Useful Post:
alone1i (03-11-2021), Busybee (03-12-2021), JesseG (03-12-2021), NoHaveMSG (03-11-2021), Silviacrazed (03-18-2021), soundman98 (03-11-2021), theneptune86 (03-11-2021)
Old 03-11-2021, 05:05 PM   #4
alone1i
Not pro yet
How about STI's engine?
Old 03-11-2021, 05:13 PM   #5
Ohio Enthusiast
Drives: 2018 BRZ
Pretty sure it's the Twins which are noisy, not the engines. All engines are noisy, they are just sound-insulated better. But sound insulation adds weight and reduces the raw feeling of the car, so the Twins don't have much.
I'm sure if you up the sound insulation on a Twin to a similar level as a regular commuter you'd get similar noise levels. Alternately, compare a running engine with the hood open across different engines to see if the FA20 is really any louder.
Ohio Enthusiast is online now   Reply With Quote
The Following 7 Users Say Thank You to Ohio Enthusiast For This Useful Post:
alone1i (03-11-2021), Busybee (03-12-2021), HachiRokuX (03-12-2021), JesseG (03-12-2021), JusTheG (03-12-2021), SuperTom (03-07-2022), Tcoat (03-11-2021)
Old 03-11-2021, 05:14 PM   #6
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Sound tube, minimal noise insulation to reduce weight.
The Following 3 Users Say Thank You to nikitopo For This Useful Post:
alone1i (03-11-2021), SuperTom (03-07-2022), Tcoat (03-11-2021)
Old 03-11-2021, 05:17 PM   #7
Same thing. You just hear it more in the Twins because of the dual injection and lack of soundproofing.
Most cars are so soundproof now that they just hide the sound that they all make.
You want to hear noisy take a base model 60s Dodge Dart with steel door panels and dash with no factory carpeting for a spin! The Twins are like driving a Rolls in comparison.
The Following 10 Users Say Thank You to Tcoat For This Useful Post:
alone1i (03-11-2021), Busybee (03-12-2021), DarkPira7e (03-11-2021), HachiRokuX (03-12-2021), Jdmjunkie (03-11-2021), JesseG (03-12-2021), NoHaveMSG (03-11-2021), spike021 (03-11-2021), Ultramaroon (03-11-2021), x808drifter (03-11-2021)
Old 03-11-2021, 05:31 PM   #8
Ohio Enthusiast
Drives: 2018 BRZ
Isn't port injection only added at low and high RPM? Wouldn't then the bulk of operation be direct injection only? I remember seeing a graph detailing the breakdown between direct and port injection, but can't find it now...
Old 03-11-2021, 06:05 PM   #9
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
I recall seeing that one too. Can't find it either.
IIRC, the car starts on port (maybe because the DI pump needs a moment to ramp up fuel pressure? It's mechanical, right?), and then always uses DI as soon as it becomes available. Port is only active as a complement below roughly 4 500rpm. Past that, it's DI only.
Some Ford engines are the opposite, using a majority of port with DI as a performance complement. Which allows them to idle on the quieter port system.
But as others pointed out, the FA20D's a fairly agricultural engine with a rather high degree of complexity (4 cams & 8 injectors on only 4 cylinders), plus the car lacks deadening and is running on a platform that wasn't created for luxury.
I *think* the EU cars are a little quieter due to a more restrictive rear muffler and more hood sound deadening, though I guess it mutes them more than it refines them.
alex87f is offline   Reply With Quote
The Following 2 Users Say Thank You to alex87f For This Useful Post:
alone1i (03-11-2021), JesseG (03-12-2021)
Old 03-11-2021, 06:24 PM   #10
Yep. And you can really easily hear when they kick in and out.
Ohio Enthusiast (03-11-2021)
Old 03-11-2021, 07:40 PM   #11
alone1i
Not pro yet
I love mechanical noises and it gives me a feel of owning a sports car. But they are so loud and every single days I believe I can hear new types of noise. Due to lack of automotive mechanical knowledge, it just scare me and push me to believe something is wrong. On the other hand, many peoples told me the engine doesn't feel like pickup truck engine rather than sports car engine.
Old 03-11-2021, 09:01 PM   #12
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
They have so much horsepower the sound slices through the engine bay
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following 3 Users Say Thank You to BrahmaBull1990 For This Useful Post:
JesseG (03-12-2021), Tcoat (03-11-2021), x808drifter (03-11-2021)
Old 03-11-2021, 09:02 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
my 2015 Legacy at cold startup, is louder inside the cabin than when I had my BRZ stock under the same conditions.
sometimes you have to quantify what exactly is "noisy", because context matter.
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
alone1i (03-11-2021), Tcoat (03-11-2021)
Old 03-11-2021, 09:45 PM   #14
alone1i
Not pro yet
I have excluded anything related to rattling including cabin. I have compared it to my friends 180SX, my 86 has 3 times louder noise than him.
WTB: 14-16 FRS/BRZ/FA20 engine Thrilryder Great Lakes 0 08-22-2020 01:25 AM
LF: FA20 Engine darko Canada Classifieds 8 01-28-2019 04:00 PM
WTB> FA20 engine VeganGirl Want-To-Buy Requests 2 08-30-2017 04:01 PM
Subaru BRZ Engine extremely loud and noisy after tune morswestford Engine, Exhaust, Transmission 37 11-05-2016 05:32 PM
Engine is quite noisy Rob_g Issues | Warranty | Recalls / TSB 9 10-14-2012 09:41 AM
