View Poll Results: Turbocharger or Supercharger?
Turbo 19 30.65%
Super 43 69.35%
Voters: 62. You may not vote on this poll
Old 02-28-2021, 08:54 AM   #1
series420
Drives: '13 Toyobaru BRZ
turbo or super
as the title says, turbo or super charge? and why?
thanks all
series420 is offline   Reply With Quote
Old 02-28-2021, 08:56 AM   #2
Howaitoguru
Howaitoguru's Avatar
Drives: 2016 Subaru BRZ
thanks all
There’s literally a million posts on this. It’s all subjective.
Howaitoguru is offline   Reply With Quote
The Following User Says Thank You to Howaitoguru For This Useful Post:
x808drifter (02-28-2021)
Old 02-28-2021, 09:00 AM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Both because why not.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
Jaden (03-11-2021), JesseG (03-02-2021), NoHaveMSG (02-28-2021)
Old 02-28-2021, 10:09 AM   #4
Grady
Grady's Avatar
Once again the only correct answer is “Yes”!
The Following 2 Users Say Thank You to Grady For This Useful Post:
JesseG (03-02-2021), x808drifter (02-28-2021)
Old 02-28-2021, 11:05 AM   #5
x808drifter
LMGTFY
That's the reason we have two separate injection systems right?
One fore each form of FI.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
JesseG (03-02-2021), Wally86 (03-03-2021)
Old 02-28-2021, 11:14 AM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
thanks all
If you want it to feel NA like you have a bigger displacement motor with more immediate response where you still have to rev it out then get a supercharger. A supercharger will also be more forgiving on the internals because there is less low end torque. There
If you want more drama, sound, efficiency, tuning control and low end torque then get a turbo.
Old 02-28-2021, 11:56 AM   #7
x808drifter
LMGTFY
With a centrifugal? YES.
With a Positive displacement? NO.
A PD blower will give that TQ from just about idle.
Also low end tq can be minimized or enhanced based on size of turbo (pulley for SC) and tuning (Wastegate for Turbo).
airrick (03-03-2021), JesseG (03-02-2021)
Old 02-28-2021, 12:19 PM   #8
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
https://www.google.com/search?client...e-gws-wiz-serp
Here are the other 1000 threads on the same subject.
The Following User Says Thank You to RToyo86 For This Useful Post:
Old 02-28-2021, 12:31 PM   #9
x808drifter
LMGTFY
I voted turbo because I feel poll thread should be even.
Old 02-28-2021, 05:36 PM   #10
Irace86.2.0
At redline I hit a bar of boost (14 psi). At 3,750 I'm half that, so 7 psi. Half that at 1,875, and I am at 3.5 psi (a turbo could hit full boost by then). At half that at 950ish rpms (idle) I might be making 1-2 psi. Even a PD supercharger is RPM dependent instead of load dependent. Yes, a centrifugal supercharger will make even less low end torque, but any supercharger will still be safer in general. Safer because they aren't making as much low end torque, and I'll add that they are safer because there is no chance of over-boosting anywhere, but especially down low.
Supra dyno showing full torque at 2k
Different torque curves, showing PD supercharger still building torque
Yes, a larger and slower spooling turbo will have less low end torque than a smaller turbo, and yes, a tuner could do boost by rpm to avoid low end torque and to ramp up boost. Someone could definitely design their torque profile to match a supercharger's torque profile. Most don't do that.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
series420 (03-01-2021), x808drifter (02-28-2021)
Old 02-28-2021, 08:05 PM   #11
86TOYO2k17
Drives: 2017 toyota 86
Turbo if you know what you’re doing and/or want the most whp to crank hp ratio.
Supercharger if you don’t known what you’re doing and/or don’t care about whp to crank hp ratio.
Old 02-28-2021, 11:06 PM   #12
Irace86.2.0
Also, do a turbo if you want to do boost-by-gear, boost-by-rpm, multiple boost maps, etc. It is also easier to run a turbo with FlexFuel/E85, especially when E85 is not always available; I would need to swap pulleys if I couldn't get E85 or drive around without going into boost or something, but a turbocharged car could just do boost-by-fuel by either limiting boost or just running a completely separate map. Finally, you can always swap to a different sized turbo or vary exhaust and compressor sizes if you are not happy with your turbo profile. You can swap superchargers too, but it isn't always as easy or an option. The JRSC has the C30 and C38, but the Edelbrock kit doesn't offer a different sized blower. It is typically much easier to option a turbocharger of your desire during an initial purchase, and it is easier to make a swap later--typically.
Old 03-01-2021, 12:51 AM   #13
PulsarBeeerz
Drives: JRSC BRZ SOLD
Seems like there is just overall less to go wrong with a SC vs turbo and they have greater consistency to throttle inputs as it is directly driven off the crank.
PulsarBeeerz is offline   Reply With Quote
Old 03-01-2021, 01:41 AM   #14
Irace86.2.0
Definitely less could go wrong. Worst case scenario is being stranded with a snapped belt. Throttle response is also more predictable, even if the power isn’t as good.
Another benefit of a turbo is more power at varying altitudes. A supercharger at altitude will achieve less psi at a given pulley size than at sea level, but the turbo will just suffer from more lag, but still hit full boost.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
WTT: Pandem v3 widebody for FI kit (turbo or super) IceMeister Want-To-Buy Requests 3 10-03-2018 01:06 PM
Super vs turbo aslanteye Forced Induction 29 06-16-2015 01:30 AM
Turbo+super firl21 Forced Induction 8 04-16-2013 12:51 PM
would you turbo or super charge your BRZ/FRS? chenshuo Scion FR-S / Toyota 86 GT86 General Forum 45 03-04-2013 11:13 AM
Turbo or Super Charger Ryan86 AFRICA 7 11-21-2012 09:14 AM
