Old 02-21-2021, 10:14 PM   #1
BitusB
BitusB's Avatar
Drives: 2020 BRZ rs
Do dealerships replace “cricket” fuel pumps under warranty?
I’m in western Canada about to pull the trigger on a brz or 86. Has anybody in Canada had any luck getting either Subaru or Toyota to replace the stock pump under warranty?
BitusB is offline   Reply With Quote
Old 02-21-2021, 10:43 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Depends on the model year and mileage/age of the car.
There is no guarantee that switching pumps will make the crickets go away. It's usually due to interactions with the fuel, mainly ethanol content and additives and how they impact fuel lubricity.
EndlessAzure is offline   Reply With Quote
Old 02-21-2021, 10:46 PM   #3
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
Buy Shell, you won't have no more crickets.
CB750F is offline   Reply With Quote
Old 02-21-2021, 11:02 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I run shell and have crickets
Jfheisenberg (03-03-2021)
Old 02-22-2021, 12:15 AM   #5
BitusB
BitusB's Avatar
Drives: 2020 BRZ rs
Gotcha, so after market stereo is the way to go. Just adjust the volume until you can’t hear any crickets or anything else aside from sweet tunes!
The Following User Says Thank You to BitusB For This Useful Post:
ToySub1946 (02-22-2021)
Old 02-22-2021, 12:04 PM   #6
Vital
Drives: 2015 BRZ
Yep, if the TSB shows that your is car affected by the fuel pump chirp and your car is still under factory warranty they will replace it. I had mine replaced years ago without a problem.
The Following User Says Thank You to Vital For This Useful Post:
Dadhawk (02-23-2021)
Old 02-22-2021, 12:19 PM   #7
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
....or drive? crickets are only vocal when you're idle.
HKz is offline   Reply With Quote
Old 02-22-2021, 12:29 PM   #8
And a decent exhaust to cover them up.
Like the guys said the fuel pump replacement is a Service Bulletin not a recall so the car has to still be in warranty for it to be no charge.
Old 02-22-2021, 01:13 PM   #9
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
I thought crickets were a result of crappy gas and the direct injection pump? My car was doing it and switching to Chevron premium helped. It is still a bit noisy in the morning, but I just accepted it as a fact of owning the car; I didn't know they would replace it.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 02-22-2021, 01:22 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Crickets are a function of this high pressure direct injection pump period. Who knows what the exact cause is. Could be the check valve making the noise, be cavitation, could be the clearances allowing some blowby, there could actually BE a cricket in there. They all seem to do it, it is not detrimental to the function of the car.
BrahmaBull1990 (02-22-2021)
Old 02-22-2021, 02:15 PM   #11
StraightOuttaCanadaEh
Wes
It's just a sound, there's nothing harmful happening. I've been filling up with Petro 94 since day 1, and it chirped but it either stopped or I'm used to it, 75000 km later I don't even think about it.
Instagram: @gt86ws
Old 02-22-2021, 03:28 PM   #12
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
Fuel quality is a factor in hearing the crickets or not. For me, they show up in the winter, and go away in the summer. I always use 93 octane. So I wouldn’t say it’s only because of poor quality fuel, but a combination of that and temperature. For me anyway.
Oh one other thing I noticed. When I bought my car, I heard the crickets at idle. I’m guessing they threw in the least expensive 89 octane fuel. After getting a full tank of 93 in there, the crickets disappeared.
JesseG is offline   Reply With Quote
The Following User Says Thank You to JesseG For This Useful Post:
Old 02-22-2021, 06:16 PM   #13
That is the total opposite of what I had. I had them in the heat of summer no matter what fuel I ran. When it got cold they went away.
This is why it is so hard to narrow down cause and affect. No two people seem to have the same results no matter what fuel, temperature, additives, driving style, etc. etc they tried. The good news (for me) is that I have never had a peep out of the 2020!
Oh and 89 octane fuel is no poorer quality than 93 no matter what marketing you wish to believe. It is just a difference in in knock resistance not a measure of quality
JesseG (02-22-2021), pope (02-22-2021)
Old 02-22-2021, 09:14 PM   #14
JesseG
JesseG's Avatar
I was just thinking that also, I’ve had the crickets at random times even when it’s warm out. So there isn’t much rhyme or reason to it. Typically with winter fuel I get the crickets more, but it’s random.
That’s really good news the 2020 doesn’t have it. They must be using a different high pressure fuel pump, or different internals.
crickets fix, warranty
Parallel Fuel Pumps RedFR-s Forced Induction 31 03-16-2022 05:50 PM
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 03:26 PM
FS: OEM Fuel tank with pumps MicheleAbbate Exterior Parts (Aero, Lighting, Etc.) 3 06-02-2016 04:08 PM
Aeromotive 325 fuel pumps 1stGenBRZ86 Forced Induction 12 05-05-2014 07:22 PM
Please read if swapping fuel pumps Dipstik-sportech Forced Induction 5 06-17-2013 03:39 PM
